Question about Craftsman Garden
I have a riding lawn mower & need to check underneath to see if the drive belt is broken but I've been told that if you tip the mower up it will blow the motor up....is that true?
  • 843 Answers
No, but it's better to lift the mower up than tip it over because the gas will leak out and cause a serious fire hazard. But if you can empty the gas first, then no problem. Also, you might get a little oil leaking from the filler cap, but you can tie a rag around it to minimize the mess, and don't leave it tipped over for days. Once you put it back down, give the oil 30 minutes to run down where it should be, and no problem. Thanks for using FixYa, and good luck
Posted on Apr 29, 2010
  • Al Kupchella
    Al Kupchella Apr 29, 2010
    I almost forgot! Take the battery out before you tip it! You don't want battery acid leaking all over!!!
1028 rear engine riding lawn mower model # 927046 is not moving when in gear. Was told I needed a drive box unit for it
check to see if the key in the axle is in place or if you put it in gear the axle turns in the wheel . is the pulley in place and not loose. the belt is good you said. but the pulley may be stripped. (axle key, belt, pulleys, or belt off of pulley)
Nov 19, 2016 | Garden
How do i replace v belt on ltx 1040 cub cadet.
Nolan, Check the attached links,instruction and guides for belt replacement on Cub Cadet. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change the Deck Belt on Cub Cadet Riding Lawn Mower Using Model...
How To Install or Replace Drive Belt on Lawn Mower Cub Cadet
How to Change the PTO Belt on Cub Cadet Riding Lawn Mower
cub cadet belt replacement diagram Google Search
Jun 30, 2016 | Garden
Need a manual for Manual for Signature 2000 Elite 42' riding lawn mower, if not I need a drive belt as the one on it has broken. A re-order number would be great
Scott, Check the attached links, Good luck
http://ww2.justanswer.com/uploads/gandorph/2010-03-09_214653_133P670G000.pdf
Mar 21, 2016 | Garden
WHAT SIZE DRIVE BELT I NEED FO 30" RIDING LAW MOWER ? MODEL NO P01230lt SERAL NO.011310A001123 model no PO12530lt 12.5 HP
We do not have any info on this site
Just a chat room
Take you info to a small equipment
dealer/repair shop & they can look it up
for you
Jul 06, 2014 | Poulan Pro Lawn Tractor 2006 and Newer...
Weedeater we261 riding lawn mower
Check your drive belt on the bottom of the engine.. that is what drives the machine forward.. if it has slipped off or broken, it will not go.
Apr 27, 2013 | Weed Eater WE-ONE 26-Inch 190cc Briggs &...
I cannot get my Poulan riding lawn mower to go into gear. What am I doing wrong?
Check your drive belt underneath the engine (on a crankshaft pulley) and make sure it is connected to the drive pulley on the transaxle (this area is under and probably just behind the seat. Don't confuse this drive belt with the belt that runs the blade mandrells on top of the cutting deck.
Apr 13, 2011 | Poulan Garden
Cub cadet riding mower blade won't turn on. when you pull the blad to turn it on you can here a click but the blade won't turn on and start spinning.
If the click you hear is the electric PTO engaging, then your deck belt is broken or off a pulley some where. Check the belt & then clarify if needed
Aug 21, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
