Question about Zanussi F1045W Front Load Washer
What function does the golfball size plastic ball in the rubber drain hose between the wash drum and pump serve. Will the machine operate effectively if it is removed ?
    Novelist:
  • 145 Answers
If that ball is in that location I would assume its being used as a means of back flow prevention to prevent dirty water from backing up into your drum. You can try removing it and see what happens, but the things you need to consider are, 1. Does the ball have a hole through it. If so, its not a means of back flow prevention and definitely needs to stay in there. And does the ball move freely back and forth in the tube because the machine may also be using it as some means of pressure regulation. Either way I wouldn't recommend taking it out unless its harming something because the manufacturer put it there for a reason.
Posted on Apr 29, 2010
Whirlpool AWM6120 - small ping pong size ball found in black drain part????
The ball is supposed to be there. It should be in the drain hose at the bottom of the drum. It is part of the eco system of the washer. In the service manual its called an "eco lock"
Oct 13, 2012 | Whirlpool AWM6120 Front Load Washer
Really bad smell from drum?
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the hose to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting. Being the first time you shd note what you doing, what goes where. You certainly don't need techs for this; and techs who come are useless anyway.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Pl give me a ‘very helpful’ rating for the free help, thanks!
Mar 08, 2010 | Hotpoint WMA64 Front Load Washer
Wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
M/c won't spin
Take off top and rear half of machine cover
remove belt and spin drum by hand, (does it spin freely?)
make sure pump and drain hose are ok (clear)
there is a plastic ball (about egg size) in hose from drum to pump.
check motor brushes are at least 3cm long
if you have checked all these but the fault persists email me on andynj42@yahoo.com
Feb 09, 2010 | Zanussi F1245W Front Load Washer
MY Whirlpool AA1400 5145 I had remove bottom drain and there is some blocking then I don't know whow comes first the ball or the rubber. Regards, OA
Hi
I hope I understood your question properly.
When you take off the drum drain pipe, you have a plastic ball and plastic ring inside the cup shaped hose which fits on the bottom of the drum.
When putting it back on, first put the plastic ring inside the cup-shaped hose. Then put the plastic ball on top of it.
Secure the hose to the bottom of the drum with the metal clamp. Make sure it is on correctly and will not pull off.
Also make sure there are no kinks in the hose leading to your drain filter.
Start a quick cycle and monitor the machine to make sure there are no leaks.
Best Regards
Ash
Nov 15, 2009 | Whirlpool AWM5145/2 Front Load Washer
WATER LEAKING FROM POWDER TRAY AND AROUND DOOR
There is a ball return valve that wants cleaning. Disconnect the appliance from water and mains. Turn machine on its side and look underneath. At the bottom of the white plastic drum you should see a black rubber hose about the size of a mug fastened by a hose clip. Remove hose clip and extract the hose from the drum and look inside. You should see a white plastic cone about the size of a paper cup with a plastic ball inside, remove and clean of any debris and replace. Be careful when reattaching the black how to the drum or you will get a flood if not properly attached.
Hopefuly that will solve your problem.
Apr 27, 2009 | Washing Machines
No spin
And rate me plz……………………….
Apr 10, 2009 | Washing Machines
Not draining properly
To clean your filter: It is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip.
Check out your pump too, there may be something clogging it, prevents pumping water out.
Mar 18, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Drum outlet hose assembly
Hi trevor it is just a eco ball it is not needed it will cause you more problems when it is in the machine dont worry just leave it out
Aug 01, 2008 | Whirlpool AWM8103/1 Front Load Washer
Zanussi F1045W Front Load Washer Logo
212 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
