Question about Brother IntelliFax-2820 Laser Fax
Have lost instruction book and am having problems sending long distance faxes, have been told that i need to lower somthing down ??????
leroyal
  • 2120 Answers
SOURCE: need some help
Go to www.brother.com. They might have your manual available for download.
Posted on Oct 19, 2008
goalie39
  • 469 Answers
SOURCE: need access code to fax long distance, just started happening.
That would usually be your telephone service provider not the fax machine, if it is a business line, the permissions may have been changed. Check with your business communication administrator, or your local phone service provider.
Hope this is of some help.
ed
Posted on May 18, 2009
goalie39
  • 469 Answers
SOURCE: I lost my instructions book for fax Sharp ux-p105
This link will get you the manual you are looking for.
http://www.sharpusa.com/products/TypeManuals/0,1083,24,00.html
Hope this helps
Ed
  • 105 Answers
SOURCE: Lost the instruction book for FAX-T78 need a PDF
http://www.brother-usa.com/ModelDocuments/Consumer
Posted on Aug 03, 2009
FixinFax
  • 3085 Answers
SOURCE: black line down paper
Pull the doc feeder open and clean the scanner glass
Posted on Feb 11, 2010
My problem is that I have just purchased Vonage as a VOIP phone line. I have a HP LaserJet 3055 printer/fax and I am trying to send faxes but it does not work. I was instructed to lower the baud rate,...
Configuring the V.34 setting to Disable (Enable is the default setting) to lower the speed.
Voice over IP (VoIP) services provide normal telephone service, including long distance service through a broadband Internet connection. These services use packets to break up the voice signal on a telephone line and transmit it digitally to the receiver, where the packets are reassembled. The VoIP services are often not compatible with fax machines.
If you continue to have problems faxing, contact your VoIP provider. Because the installation process varies, the VoIP service provider will have to assist in installing the all-in-one fax component.
Although a fax might work on a VoIP network, it can fail when the following events occur:
• Internet traffic becomes heavy and packets are lost.
• Latency (the time it takes for a packet to travel from its point of origin to its point of destination) becomes excessive.
Feb 15, 2011 | HP LaserJet 3055 All-In-One Printer
How does I fax something from my Canon MX320?
Follow these steps :
Prepare the document that you want to fax.
Prepare a fax cover sheet, if desired.
Open your fax software - such as Microsoft Fax or Microsoft Exchange.
Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item.
5
Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed.
6
Indicate whether you wish to send a cover sheet.
7
When asked to attach the file, follow instructions to attach the file that you want to fax.
8
When ready, click Send. The fax will begin to compile the information and, when ready,
9
When the connection is made, the fax will be sent.
Oct 26, 2010 | Canon Office Equipment & Supplies
We are having problems with our Muratex F110 fax machine. It won't send long distance faxes. the phone company says it is not on their end. any suggestions?
Well technically it's not on thier end. Let's remember that a fax uses a normal home style phone line.
So ask yourself these questions.
#1 Do I have long distance service on this phone line?
#2 If I do have long distance service do I need to do any kind of special dialing sequence to access long distance? Like a 9 or an 8 or any other number before dialing outside of your local area.
In some cases( businesses usually) a special code needs to be entered after dailling the number.
Most fax machines have a hansdset on them. Do this simple test. Lift the handset and dial a known long distance number and listen to what the operator message says. If all else fails call your phone company and ask them if this line has long distance capability.
Sep 22, 2009 | Muratec Office Equipment & Supplies
Fax problem. Trying to send international fax to France. I can hear the fax number being dialed ok, but no connection after 12 rings. Calling fax number from phone hooked up through mp530 connects ok! ...
Hi ...
It might be possible that the line is loose or the long distance calling code is incorrect. Follow the below instructions which might resolve the problem.
Sending Using a Long Distance Calling Code The telephone company or PBX system may use long distance calling codes on a phone line as a means to manage long distance calls. This service may extend to a fax phone line and for local phone calls as well. To use a calling code for faxing, enter a pause (or pauses, as necessary) in the dialing sequence to allow time for the phone system to distinguish between the phone number and the calling code. For example, if the calling code has to be entered after the phone number, press <Redial/Pause> after the long distance number and then enter the calling code.
Here is an example of a couple of variations that may be used by the phone company / PBX system. (For details on time sequence between the long distance number and when you must enter the calling code, please contact your phone company or telecommunications specialist.)
Long distance number: 212.555.1212
Calling code: 123456
Scenario One: 12125551212p123456 Scenario Two: 123456p12125551212
Note: The above scenarios include a pause (p) in between the dialing sequence. This pause may be necessary to allow the phone system to detect each set of dialing sequences. The pause length can be adjusted from one to nine seconds, the default is two seconds.
Tips to help you send a fax using a calling code.
  1. To send a fax using a calling code, it may be necessary to add a pause(s) before the next string of dialing digits. The above example shows how a calling code is used to dial a long distance fax number. To provide time before the calling code number is dialed and avoid misdialing, a pause should be added.
    Example: 12125551212p123456
    The number of pauses will depend on the phone / PBX system.
    It is suggested to confirm if the time before the next set of digits is dialed will always be constant. This way you can always use the same number of pauses for that dialing sequence. If needed, you can also change the pause [Pause time] length from its default 2 seconds.
  2. Connect a telephone to the fax machine.
    1. Connect a line cord from the telephone wall jack to the [L] jack (or item <1>) on the fax machine.
    2. Connect a line cord from the extension telephone port on the fax machine (top jack (or item <2>)) to an external telephone.
  3. To send a fax using a calling code, it is recommended to dial using the attached telephone.
    1. Press the <FAX> button on the operator panel.
    2. Insert the documents face-up on the ADF.
    3. Pick up the handset of the attached telephone and confirm you hear a dial tone.
    4. Dial the fax destination number on the attached telephone.
    5. When you are prompted to enter your calling code, dial it on the attached phone.
    6. When you hear the remote fax machine's high-pitched receive tones, press <Color> to send a color fax or <Black> to send a black and white fax. The audio signal heard from the handset will be cut off.
    7. Hang up the handset.
    8. When the transaction is complete, the fax machine will return to standby mode.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA® MP530 All-In-One Printer
Problems sending to a particular number
Try sending your fax to a lower baude rate to 14,000 bps, I had this problem before and I solved it by sending to a lower sending speed bacause the line was very noisey.
Mar 16, 2009 | Canon LaserCLASS Fax 710 Printer
Can't send a fax.
This can be tricky and sometimes requires some playing around with to get the settings you need. Here is a document that HP created for just your situation. You may need to try it a few times to get the timing right but once you figure it out you should be able to use the same formula for all other fax calls long distance.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu01821&cc=us&lc=en&dlc=en
Jan 15, 2009 | HP Officejet 5610 All-In-One InkJet...
I can't send faxes aut of my phone area.
there is no problem unless you do not have long distance you can only send a fax to a non local number if have long distance without it your not going to go far
Jun 30, 2008 | Brother MultiFunction Center MFC-440CN...
Using a calling card for a long distance fax
It will surely help if you are using a calling card that has a pinless dialing feature where you don't need to dial your pin. I use Onesuite.com calling card and it has that feature and sending a fax through regular fax machine is easier than having to dial your pin midpoint.
Apr 19, 2008 | HP Photosmart 2410 All-In-One InkJet...
Receiving Fax Line always 'busy'
Installing fax software can be tricky, particularly if you want to import phone-book listings from an existing database or PIM, such as Microsoft Outlook. But WinFax Pro proves easy to configure. A series of introductory screens walks you through installation; you just click Next to accept the default configuration. In our tests, WinFax Pro accurately detected our fax modem and seamlessly imported our contacts from Microsoft Outlook. By comparison, competing fax programs either don't import directly from Outlook or make the process trickier than it needs to be. you can try to look on website and there will explain to you. http://reviews.cnet.com/e-mail/winfax-pro-10-0/4505-3536_7-1536745.html
May 28, 2007 | Symantec WinFax Pro 10.0 for PC
Brother IntelliFax-2820 Laser Fax Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
