Question about Whirlpool AD25BBR Dehumidifier
It is icing up and i do not see any screen to clean what else could be the problem
  • Whirlpool Master
  • 43,501 Answers
Esco Oasis 2700L dehumidifier ices up. Is there a filter to be cleaned and if so, how to I get to it?
The most common cause of frost and ice buildup on a dehumidifier is because the unit is operating in temperatures that are too cold. Many dehumidifiers are not equipped to run at temperatures below 65 degrees Fahrenheit.
To fix this problem, Position the dehumidifier in an area where there is at least one foot of clearance around the unit in order to allow for proper air circulation during its operation. Close all windows, doors and other outside openings to make sure your unit isn't attempting to remove moisture from areas outside of the immediate room. Determine the temperature of the room by checking a nearby thermostat or by using a hand-held thermometer.
Check the filter for dirt and buildup. Unplug the unit from the electrical source and check the filter by opening the filter compartment. If the filter is dirty, it will restrict airflow through the unit and lead to freezing. Soleus recommends lightly vacuuming the surface of the filter to remove dirt. The filter also can be washed in warm water if it is extremely dirty. Once clean, place the filter back in its compartment. Allow for the ice to melt and then restart your dehumidifier.
Jul 03, 2011 | Dehumidifiers
Our dehumidifier has formed a sheet of ice amongst the coils and will no longer pull moisture from the air. The hole from which the water drips is completely iced over. It is 70degrees in the room and...
Turn the unit OFF and unplug it from the wall. Allow it to thoroughly thaw and remove the humidifiers cabinet to expose the cooling coils. Clean those thoroughly and coat with a very light coating of WD40. Reassemble the humidifier and turn it ON. Set your humidity control at 50% and allow the unit to run for at least one hour. Check for water collection in the bucket and for any signs of icing, after one hour. If water is in the collection bucket and no signs of icing, lower the humidity to 45% and continue. If you not any signs of icing, watch the unit, as you need to know if it automatically goes into defrost mode. The compressor should shut off, but the fan will continue to run until defrosting is completed. If it doesn't the auto defrost sensor has failed and will need to be replaced.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
May 08, 2011 | Dehumidifiers
Ice on the back screen after it's been running for an hour.
Cleaning the air filter should go a long way in solving the icing problem. Just allow the unit to thaw out completely, before trying to remove the filter. Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet.
Apr 10, 2011 | GE ADER65LN Dehumidifier
Dehumidifier element icing up
Unit is low on charge...
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
May 29, 2010 | Maytag M7DH45B2A Dehumidifier
Ice forming on the top
pls. check air filter, first clean the air filter, by this time heat the evaporator coil for remove ice. After cleaning start it.
Aug 21, 2009 | Dehumidifiers
Whirlpool dehumidifier icing up
low air flow coil could be dirty or if not then low on freon it gets colder when leaking out
Jul 19, 2009 | Whirlpool AD50DSL Dehumidifier
Ice build up
I would say you need a humid control on your unit.it may be running more then normal.
May 08, 2009 | Goldstar DH504EL Dehumidifier
Dehumidifier ices up
Might it be that the unit simply needs a full thorough cleaning including the tiny spaces between fins? Dust can gather and block air passage on many of the components of a dehumidifier not only on the filter. in some extreme cases, the unit could be undercharged (insufficient) coolant. A service shop engaged in the business of cleaning and repairing air conditioners should also be able to work on your unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 22, 2008 | Goldstar DH504EL Dehumidifier
Whirlpool AD25BBR Dehumidifier Logo
46 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
