Question about Nikon D90 Digital Camera with 18-105mm lens
I was using active viewing on the back screen when the battery went flat. I put in the new battery but the mirror is still down, so it shows an error message when I try to take a photo now. The mirror has remained up as in cleaning position.
  • 4,924 Answers
Put the batteries on and close the mirror first ...and after that it will work ..It do not takes picks cause it is in the view mode..so ...before you put any batteries on ..place the button in the view position and than start it ...I suspect that you changed in the shooting mode with batteries out ..
So ..be sure it is in the view mode..and insert the batteries..when it powers up..change the mode to take pictures..and the mirror should close..and it will function proper..
Posted on Apr 29, 2010
Hi, I have inherited by dad's old Nikon FM camera - well I think it's a FM! It has not been used for centuries and I was able to take one picture before it the view screen went black. I have taken...
The mirror has locked up, blacking out the viewfinder. Mirror lock up is usually due to flat batteries, so replace them as soon as possible. Extended lock up is bad for the camera.
The FM uses a pair of SR44 batteries, you can use the cheaper LR44's but the voltage characteristics are different and exposures will be a little off, but if you're using print film then you're unlikely to notice any problem.
The batteries are very widely available, the link I've provided is for the mail order supplier I use in the UK. Even if the supplier is of no use to you the information they provide shows you most of the other names that the identical batteries are sold as by various manufacturers.
If new batteries don't fix it then the camera is effectively beyond economic repair.
Aug 21, 2011 | Nikon FE 35mm SLR Camera
My glass mirror only is missing on my 2000 buick lesabre what can I do?
I assume you are talking about the rear view mirror inside the vehicle. Did it fall down or is it actually missing. Seeing as you said missing - Buy a replacement mirror and buy a package or rear view mirror adhesive that contains glue and an activator. Follow directions on package. If it fell down, follow steps other than buying a new mirror.
Mar 26, 2011 | Buick LeSabre Cars & Trucks
Just bought a new LG Axis smart phone today and after loading some applications from the application market on the phone, whenever I went to view an application I kept getting an error message that the...
A Hard Reset might help. it will bring lost file/folders back.
Also to turn on phone in safe mode, but not if cannot get passed initial Android screen.
Pull Battery to power off phone.
Hold Up Volume button, and power on button simultaneously until green android guy and DOS window open.
If Home key is solid button, then also hold
up vollume button, home button, power button.
use volume up and down to scroll.
Scroll down to Reset Manufacure Settings.
Use power button to select OKay.
Then select reboot system.
Mar 27, 2017 | Cell Phones
Just put new batteries in. No film. I looked at the view finder and snapped a pic then the screen went black. I took the lens off and the mirror is sideways.
You have two main possibilities. The new batteries are incorrectly inserted or the batteries are faulty.
If not those, then it's a camera fault (it's definitely faulty if the mirror is actually sideways and not merely halfway up) and as you can get N75's for free these days (my last two have been boxed and nearly unused from FreeCycle) then it's simply uneconomical to repair it unless the mirror can simply be removed and correctly re-fastened. Spare parts availability is already very poor for the n75.
Aug 03, 2010 | Nikon N75 35mm SLR Camera
My canon eos 100D wont's show the image on the screen. it will take the picture when looking through the view finder, but i would like it to appear on the screen. pleae help
Unlike compact point and shoot cameras, Canon's range of EOS D-SLRs don't have the LCDs stay on all the time. The design of the SLR camera involves a mirror in front of the sensor. The mirror in its normal position inhibits the image to be captured by the image sensor. When you shoot, the mirror flips up for a split second and back to its rest position.
To use "Live View" (composing shots with the LCD), there is an option in the Menu to enable it. Once enabled, press the centre "Select" button behind the camera to activate the LCD. However, the camera can't Auto Focus for you in Live View mode so manual focusing input is required of the photographer.
Apr 17, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Remove/replacing side view mirror on a jeep grand cherokee
    Remove the Old Mirror
  1. Step 1 Disconnect the negative battery cable before you take off the grand Cherokee front door trim panel. Remove all screws and clips.
  2. Step 2 Detachthe window trim cover screw, and control lever screw beforedisconnecting the entire mirror trim cover. Remove the rubber coverinside the mirror cover, and disconnect the electrical wire.
  3. Step 3 Remove three nuts from the power mirror using a Torx® star-shaped screwdriver.
  4. Step 4 Pull out the outside rear view mirror. Guide the power wire through the hole in the door.
  5. Install the New Mirror
  6. Step 1 Replace the old mirror. Put the new power mirror in place. Push the new wiring through the hole in the door.
  7. Step 2 Install and tighten the three retaining screws you took off when removing the old mirror.
  8. Step 3 Connect the power mirror wiring to the connection located on the door panel. Replace the rubber cover and interior mirror cover.
  9. Step 4 Put the front door trim panel back in place by securing all clips and tightening all screws.
  10. Step 5 Connect the Subaru Outback's battery cable to restore the power.
i will recommend i site where you will get all the information you need to remove and replace your side mirror
http://www.wjjeeps.com/mirrors.htm
Sep 10, 2009 | 2004 Jeep Grand Cherokee
Replacing a rear view mirror
You have to CAREFULLY ( probably wise to wear safety goggles ) and with a flat blade screwdriver, pry out ALL the broken mirror glass wearing gloves. Now with the 2 adhesive strips, align mirror glass and adhere to base. Hope this helps
May 13, 2009 | 2008 Subaru Forester
Unable to take picture
I don't know if there is a mirror lock up button on this camera or not. Some have it for slow exposes. Nikon does have a technical phone number or place on their website to contact them. I had a D100 that had the ERR message show up on it, and it cost $400 to repair. But look for the mirror lock button.
Mar 18, 2009 | Nikon N60 35mm SLR Camera
Unable to shut down device - "Bad Track" error msg
You may need to hold down the button for up to 30 seconds in order for your MP3 player to turn off.
Sep 17, 2007 | SanDisk Sansa E280 MP3 Player
Nikon D90 Digital Camera with 18-105mm lens Logo
32 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
