Question about Acer Aspire One PC Notebook
Hard drive problem
Sent it in to get fixed because hard drive was making noises, got it back and a month later its making noises again.
    Sergeant:
  • 279 Answers
I suggest replace it with the new one since it has to be in maximum performance for storing important data and operating system.
Posted on May 04, 2010
Visio 1080p screen went light
Our Visio 42" flat screen TV did the same thing. It didn't happen that often but sometimes it would go darker or the sound would go off until I changed the channel or turned TV Off then back On. I contacted Visio through my warranty and they sent me a flash drive to install info on my TV. Did not fix the problems. A year later before warranty ended I contacted Visio again. They sent a huge box for me to pack my TV in to send to the warehouse where they fix everything. It took about 2 wks. to get it back. Worked fine for about 4 months and the problems continued. I will not buy another Visio TV. I found out that they had many problems with several models.
May 03, 2014 | Televison & Video
Loud random humming noise coming from near my glove box
Blower motor ? Take the glove box , plus lower panel ! When it happens , investigate the noise . You don't say what make , model , year vehicle . Don't know whats back there .
Jan 15, 2018 | Cars & Trucks
Wd external hard drive
Hi Regin, I used to have a WD drive and one day I started having all sorts of formatting issues. The WD was very sensitive and then a week or so later, it started making clicking noises, and then a day later it died.
I returned it and got a new WD but in less than 8 months, I lost all my data again! I never bothered asking WD for a new one, and used it as a door stopper for a year or more! Eventually, I threw it away about a year ago.
I recently read that someone whose WD drive crashed threw it in the freezer and left it there for a couple days and then it was fine!!! I am telling you the truth, i read that here on FixYa!
In any case, be care, be tender. Dont think that just because you have a back up drive that you are protected! My experience suggests that there is something wrong with a number of WD drives! We should all get our money bacK!
I would use another kind of back up system, personally.
Jul 16, 2012 | Western Digital 2TB WD ELEMENTS USB...
No response freez making funny noise
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Is it an external drive?
If it is, open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
Lastly, if its not an external drive, the same applies because, its still all about hard drive.
I wish you all the best.
Jan 08, 2010 | LaCie F.A. Porsche (301177) Hard Drive
My hard drive doesn't start. I was on vacation for a month, before leaving I unplugged it and now I returned, plugged, but it makes noises, but no lights or info...
is it an external hard drive? If its not an external hard drive, the same solution still applies because its still about hard disk.
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
Jan 07, 2010 | Computers & Internet
My pump is making a loud humming noise and when I turned it on would not come on , just hummed. Tried again later and eventually came on but still making noise. Do I need a new pump. It is about 5 years...
My Sunterra pump made that noise and I had a problem getting it to come back on after unpluggin to clean pre-filter each time. It was not long after that the plastic impeller sheared in pieces (the pump was only 1 year old and thankfully under warranty) My guess is that this is fixing to happen to yours as well. You are lucky to get 5 years. There was no reason for mine to come aparts. Uunterra sent me a replacement pump which had been slightly re-designed of the same 2000 gl size and the new one jsut did the same thing (only 2 1/2 months old) I called them again which in the meantime will mean my pond going witout filtration once again. I am getting very upset about this and will be looking for a good deal on a different brand pump.
Oct 05, 2009 | Sta Rite Dyna Glass 1.5 H.P. 115/230 Pump
Makes a constant klicking noise from the dard drive
your FAT (file alocation table) (the menu) of your hard drive is bad; try a recovery program on your hard drive manufacturer's website
Jun 03, 2009 | HP Pavilion dv1000 Notebook
5-speed transmission making noise in 3rd and 5th gear
are u sure the alignment (side to side, up and down) of the trans on the bell housingis not out of spec, that will burn the bearings out very quickly.
May 04, 2009 | 1998 Ford Ranger SuperCab
Acer Aspire 5100 PC Notebook BIOS: "Fixed Disk Failure 0200"
I had the Error 0200 problem. First the existing hard drive started to play up, so I replaced it with a new 250GB drive. I started getting the 0200 issue after installing the new drive. I wasn't sure what the problem was, I started to wonder if the old drive had been fine. I took out the drive, and opened up the rest of the covering on the laptop to clean it. I found some fluff around the fan, so cleaned this away. Still the problem existed. I was about to give up thinking it was a motherboard problem, when I came across an article where someone mentioned that taking the hard drive out of it cover fixed the problem. Rather than take the drive out of the casing, I loosened the 4 screws holding the hard drive. I put everything back together, powered it up, and it has now been running for 14 hours continiously without any problems.
Solution, If you have replaced the hard drive, don't tighten the screws holding it in the caseing too tight.
Dec 27, 2007 | Acer Aspire 5100 Notebook
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Acer Aspire One  PC Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
