Question about Cuisinart DCC-1200 Coffee Maker
How to fix cuisinart leaking around carafe seal...
4 Suggested Answers
SOURCE: Coffee not going into carafe
doesnt matter what filters we use this coffee maker is dumping coffee and grounds everywhere
Posted on Dec 28, 2007
SOURCE: Cuisinart DCC-2200 14-cup Coffee Maker Problem:
Actually, cuisinart does sell the lid for this carafe separtely for $5. Check out their webite under parts for the DCC-2200.
Posted on Oct 23, 2008
SOURCE: Cuisinart DGB-600BC - water inside the carafe shell
I had this problem, but was able to take it apart using the instructions in an Amazon review. Plus, taking the handle off and popping the top off completely allowed me to wash it inside. I didn't want to heat it up.
Posted on Jul 11, 2011
Lately whether I put in pre-ground beans or whole beans, 1/2 the pot while dripping, leaks all over the counter, Help!
If water is leaking from the very bottom of the machine, your unit is broke and you need to call Cuisinart. If it is just overflowing the caraffe/basket:
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Drips after brewing from where coffee comes out
I have this model as well with no problem, but it replaced a proctor silex (i believe...) that did have this problem. there were replacement seals supplied with the Proctor Silex, but not with the Cuisinart. A quick look at the Cuisinart website turned up no part readily for sale. I would call the company to see if they can supply one
Jul 10, 2009 | Cuisinart Coffee on Demand 12-Cup...
First off, do not submerge the carafe in cold water when it is hot. The water will rush past the seals. This solution involves heating the carafe. Be careful to avoid steam burns
1. Place the carafe on a stove top. 2. Slowly heat the carafe. (make sure you are wearing oven mitts -- avoid steam burns) 3. As the carafe heats the water inside steam will escape the area where the seal allowed the water to get in there in the first place. Steam should appear very quickly, If it does not stop the process right away! Pressure can build up and cause the Carafe to explode! 4. Check the carafe from time to time taking care to avoid steam burns. 5. Once the water has been steamed away, remove the carafe from the stove and allow it to cool slowly. DO NOT place the carafe in water or on a very cold surface until it has cooled. The rapid cooling of the left over steam will cause the carafe to collapse on itself if it is placed in cold water while it is still hot from this procedure.
Apr 04, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Thermal carafe clogged
I was once able to disassemble the top of the carafe and clean it thoroughly. I've had these clogging problems before, and it has not been the filter chamber that is the problem, but the vent in the carafe being clogged. When the air from the inside of the carafe can't be displaced faster than the coffee is draining in, the coffee stops draining into the carafe, fills the top, and spills over the side.
Will probably end up buying a replacement lid, as I can't figure out how to open the top without destroying it. I must have gotten lucky the time I was able to take it apart.
Jan 03, 2009 | Cuisinart Thermal DGB-600 Grinder
Dcc1100 carafe
You can get them at www.cuisinart.com or by calling Cuisinart
Oct 25, 2008 | Cuisinart Coffeemakers
Broken carafe
I called cuisinart customer service, they have a replacement (she said 3 models were compatible with the dcc490). It took me 2 minutes, will be shipped within a week, and cost $18 plus shipping ($26 total)
May 23, 2008 | Cuisinart DCC490SA Coffee Maker
Water is leaking from bottom of base.
I just had good luck pulling the grinder bottom piece forward while pulling directly up on the blade mechanism. Hope this helps.
Dec 25, 2007 | Cuisinart DGB-600 Coffee Maker
Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Nov 30, 2007 | Cuisinart Coffeemakers
Cuisinart DCC-1200 Coffee Maker Logo
561 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
