Question about Toshiba Satellite A135 Notebook
Wireless Disabled, not just in sys tray where I'm used to finding it
I was at Kinko's today, plugged into their ethernet/software and printed some stuff. The software that they used to charge me said that it would need to disable my wireless but would reenable automatically when it was done. Well, got home and now my wireless doesn't work. The switch is on, it says it's connected, but there are no wireless connections in range. It's just blank. Any suggestions?
  • 26 Answers
Check your device manager under network , and look for any YELLOW FLAG, AND ALSO CHECK YOUR NETWORK CONNECTION IN CONTROL PANEL IT MAY BE DISABLE IN THERE
Posted on Mar 24, 2008
  • 58 Answers
Right click your wireless icon then click repair,,,,if that doesnt work go to network connections ,highlight the wireless connection then in the left pane click repair.You can also check by going to control panel then under administrative tools then click services and see if your wireless connection is set to automatic and started.
My print server cannot be reset to the factory default for some reason. I have tried holding the reset button for 10 secs, but without luck.
I have some devices where I have to hold the reset for 20 seconds. So try holding it longer. And make sure the print server is powered up when you do it.
Feb 17, 2016 | Belkin (F1UP0001) Print Server
Cant find my wireless conection on lap top
It doesn't show in Available Wireless Networks? If so, unplug the ISP modem, and the wireless device, Shut down the laptop, Check ALL cables and reseat, plug in the ISP modem, wait for selftest, plug in the wireless device, wait for selftest, boot the laptop. Open the Network Icon in the Tray Notification Area, do you see your wireless? Will it connect if you use a Ethernet cable? Post results
Feb 07, 2013 | Fujitsu Siemens AMILO Pro V1000 Notebook
Can not install software???
I find the built in windows software normally works fine, But it was probably disabled when the software was installed.
You can either plug into your router with an Ethernet cable and download the new software or enable the windows wireless.
To enable the windows wireless configuration right click the WIFI connection and go to properties ,wireless networking tab and then check the top box saying use windows to configure my wireless network settings.
Jan 25, 2013 | D-Link dlinkgo Wireless N 300 Router...
How can I set up wireless printing?
Hi Brenda,
Considering that your printer has an in-built Ethernet feature means no need for external print servers.
  • Take the printers network/Ethernet cable and then plug it into a router/network Hub.
  • Once you've connected the computer to the network,install the printers software in all the[networked] computers that will use it.
  • Now try printing.Note that,the networked computers print jobs will be printed in order received.
Hope this helps.Thanks!
Oct 09, 2011 | HP Deskjet 6940 InkJet Printer
Please i want to know if konica minolta magicolor 1690mf is wireless printer? and how do i set the two sided print.
The Konica Magicolor 1690MF Printer/Copier/Scanner is connected with an Ethernet Cable or USB Cable. It is not equipped to operate as a wirleless printer. It has a 10Base-T/100Base-TX Ethernet interface port and a USB Revision 2.0 High-Speed compliant port.
To do two-sided printing you must have the duplex (double-sided) option installed. This also requires either Tray 2 or the Attachment to be installed underneath your machine. Tray 2 is the optional lower feeder unit which increases capcity of your machine to 500 pages. The Attachment comes with the Duplex Unit.
Only Letter and A4 plain paper (16-20 lb bond) can be autoduplexed. With the duplex accessory installed you can do duplex or double-sided printing automatically.
From within Printer Preferences select Two-side Printing > Automatic. Shoud have choices of Off, Manual or Automatic. Within the Layout Tab for your work you may also be able to specify duplex (double-sided).
Should you have continued difficulty, please reply and advi e if the duplex option is installed and with which software and operating sysytem you are using.
Thank you for using FixYa!
Sep 19, 2011 | Konica Minolta magicolor 1690MF All-In-One...
Hi Everyone! I have a Linksys Model ( BEFW 1154) Wireless model and vonage VT 2142 to be connected ASDL model internet modem with model number (DNA A201BEI). I like to know how to connect the same.
ok then first take a ethernet cable and plug it to the output of the modem and into the input of of router(for the link sys this will be known as the port labeled internet. then use the software for the link-sys and give it a network then wireless connect your computers through that network.
Feb 11, 2010 | Linksys Wireless-G Broadband Router
Ethernet problem
(Re)install the HP software, it usually has a utility to find a device on the network. As soon as it finds the device it will configure it automatically.
Nov 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Wireless hook up
You need to pair it with your router.
personal i would go for the ethernet option of just pluggin it striaght into the xbox and router no messing around then
Feb 17, 2009 | Microsoft Xbox 360 Console
Error message on HP 2600n
Connect to it through usb/parallel from your laptop, If this works then check your settings through your wireless connections,Hope that helps
Andy
Jul 10, 2008 | HP Color LaserJet 2600n Printer
Wireless Connection for Laptop
i assume youre talking about plug n play and not built in wireless.
in your sys tray(bottom of screen) youll see a icon of your wireless connection(blue when connected,red cross on when not) double click on it and select properties.in new window select wireless networks.in new screen uncheck use windows.click ok.you may have to configure is so let me know
Mar 02, 2008 | Dell Latitude D600 Notebook
Toshiba Satellite A135 Notebook Logo
126 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
