Question about Belling 24 in. IDW603 Built-in Dishwasher
Replaced new hinge cord door want close no tention on doorspring
  • biggles_wats Apr 29, 2010
    the spring is ok i just need to know how to get the tension on it do i have to dismantle the whole washer?
  • Rick Ead
    Rick Ead May 11, 2010
    you can order new springs from marcone usally when you replace the cord you should replace the springs also
  • 1,998 Answers
Most of the units I have replaced the the hinge cord on ive had t o pull the dishwasher out almost all the way install the rope first im not sure on your peticular model if you have a double roller or not atm but you end up pulling the spring with your hand to meet the rope and yes it does sometimes pinch your skin inbetween
Posted on Apr 29, 2010
  • 1 more comment
  • Raymond Quirke Apr 01, 2011
    Is it difficult to replace the hinge cord & springs?
  • Rick Ead
    Rick Ead Apr 02, 2011
    nope simply de install the unit and pull the entire unit out on both sides you will see the suspension springs and the cords that attach to each side its about as hard as putting a lego set together if you have any further questions Message me back Thanks Rick
  • lhaye2x Apr 23, 2011
    hi rickhead1, had the same problem.i done what you said in your reply and the door is still heavy.i replaced the brace,hinges ,and the cord.as this is the first time i have done it i dropped the spring with the cord on it attached to the bracket at the top .then attached it to the hinge,but i know i am missing something. the roller beside the hinge ,does that come into play
Why is door still open at top after replacing door hinges on Whirlpool WFE510S0AW0
Well, I assume you have the door hinge clips in the right position,
and the door is seated properly with that 2mm slot that sits on the hinge receivers. If hinges are replaced, then it must be hinge receivers.If the door is crooked, moving the hinge receiver will align the door. Besides hinge receivers should be replaced first, before the hinges, that in my experience rarely break
I dont like the bent twisted story. I bet the little plastic U-roller in the hinge receiver is worn down or cracked. Fix is to replace the hinge receiver (a secondhand one is in plentiful supply) - or find a look alike roller and fit it. Cord pully's at the local hardware store may fit, window slider tracks, or even coins with a small 1 inch by 4mm bolt as an axle will do the trick.
Still not sure. Remove the dorr using instructions, and set aside.
Remove hinge receivers from each side. Are the little wheels in there good, or wobly, worn of missing?
Problem Fixed
May 22, 2014 | Whirlpool RF378LXKS Electric Kitchen Range
SAFELY REMOVING DOORS FOR SHIPPING
Good Morning Jill,
I see that you are trying to remove the doors on your Frigidaire refrigerator, model# FRS23R4A, for shipping purposes. Below are the instructions you will need to follow for both the refrigerator and freezer doors.
DOOR REMOVAL INSTRUCTIONS:
If it is necessary to move the refrigerator through narrow doorways, follow these steps to remove the doors.
IMPORTANT: Before you begin, turn your freezer and fresh food controls to "O" and remove electrical power cord from the wall outlet. Remove any food from the door shelves.
1. Disconnect electrical supply.
2. Open both doors, then remove toe grille.
3. Close doors.
To Remove Refrigerator Door:
1. Remove top hinge cover screw on refrigerator door and remove cover.
2. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
3. Remove top hinge and lift refrigerator door off bottom hinge pin. Set door aside.
4. Remove bottom hinge, if necessary.
5. Reverse this procedure to reinstall refrigerator door.
To Remove Freezer Door:
1. Disconnect water line coming from lower hinge of freezer door at connection located under front of freezer: Press outer ring against face of fitting, then pull to remove tube.
2. Remove top hinge cover screw on freezer door and remove cover.
3. Disconnect wiring harness connector plug at top hinge: place your thumbs on flat sides of each connector and bend both parts back and forth, then with firm grasp, pull both pieces apart.
4. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
5. Remove top hinge, allowing wiring harness to pull through hinge and lift freezer door off of bottom hinge pin. Lay door down flat to avoid kinking water line.
6. Remove bottom hinge, if necessary.
7. Reverse this procedure to reinstall freezer door.
When both doors have been reinstalled, connect water line by inserting tube and push until mark touches face of fitting, replace toe grille and plug in electrical power cord. Turn both temperature controls to center position. Adjust settings as necessary. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS23R4A Side by Side...
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
HELLO.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Thanks.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Oven door won't quite close tightly. I can push it about another 1/4 inch to close it completely.
You need to replace the hinges in the door. Go online to a spares website and enter make and model and order new hinges. You can replace them by unhooking the door, just takes a little effort, you might need to flick back latch on hinge and lift out. Remove inner door panel, usually 4 screws and remove. then change hinges. The 2 big pieces are the hinges.
  • images?q=tbn:and9gcsg1plmaxnucdapg-xpimmjauz_p4kgblmyf6iotcmgyh-hv4v3
Mar 09, 2011 | Ovens
Driver side door does not close. Latch broken and door sits down below catch on body of car.
may need new hinges on door and body of vehicle, if so it is about 600 -700 to replace , may be able to get new bushing and pins , without replacing hinges
Sep 09, 2010 | 1998 GMC Jimmy
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Aug 03, 2010 | Sanyo SR-4910M Compact Refrigerator
Oven door hinge replacement installation
kitchenaid superba oven door will not stay closed.
Oct 22, 2008 | Kitchen Ranges
Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
Mar 10, 2007 | Miele Novotronic H350-2B Electric Single...
Belling 24 in. IDW603 Built-in Dishwasher Logo
811 people viewed this question
Top Belling Dishwashers Experts
mike cooper
Lawrence Oravetz
L Pfaff
L Pfaff
Are you a Belling Dishwasher Expert? Answer questions, earn points and help others
