I have replaced my D slave drive, from a Maxtor 150gb to a Seagate ST3500630A 500gb. It shows up in device manager, but not in explorer. I have Windows XP pro.
  • jonnumberone Mar 25, 2008
    Thanks very much. I didn't even know you could right-click "my computer". I guess I'll find another use for that! Thanks again
  • 99 Answers
TRY THIS:
Right click on My Computer Icon on desktop.
Select Manage
Double-click on storage on right side window.
Double-click disk management.
Should see your hard drive listed. Right Click on it and select format. Make sure you select right drive to format as is erases all data.
After formatting close window and see if it is listed in explorer.
Hope this helps!
Posted on Mar 24, 2008
  • Kyle
    Kyle Mar 26, 2008
    Glad it worked. Thanks!
My hd 6y080p0 maxtor shows in device manager but does not show in explorer as a usable drive. I am trying to use this HD as a slave drive.
You will just Change the pata cable as new or fit to HDD tightly and restart the PC.If the problem is same, your HDD parturition has been corrupted unfortunately. so you need to format again from >my computer>manege>disk manager >and format.
If you don't want to loss data dowmnload ontrack boot cd and recover the partition.
http://www.downtr.net/297918-ontrack-easyrecovery-professional-621.html
Regards
Shibuda
Jan 03, 2011 | Maxtor 6Y080P0 80GB Ultra ATA133 7200rpm...
I installed a Maxtor 4R080L0 as a slave drive. My Windows Explorer (XP) cannot "see" the drive. - It is recognized by the BIOS. - It is properly listed in the Device Manager and 'running properly' - Win...
You will need to go into the control panel, administrator, and then disk drive manager. once there you will need to initialize the new drive and then format the drive before the system will see it. Format using the NTFS file system only if you are using XP, After the format is completed reboot the system and your new slave drive should show up just fine and you will be able to log into it or use explorer to view it.
Apr 14, 2017 | Maxtor QuickView (4r080l0-qv) 80 GB Hard...
I am trying to install a Maxtor Basics 500GB External Desktop Hard Drive and cannot see the drive on my PC. I'm assuming it is not installed. I operate a Windowss XP Platform. Help!
Right click on my computer and go to manage, then go to storage, disk manager and see if the disk shows up there, you may need to partition it first, you can make one partition of that hard drive. If it is not in there, check the jumpers and make sure it is not the same as the main HD. The main drive should be master and the second drive should be slave, or make it cable select and do it in the bios.
Jun 21, 2009 | Maxtor MaXLine Pro 500 500GB 7200rpm...
Slave jumper setting
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Mar 29, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Desk top freezes when external hard drive connected via usb
The issue might be with the USB root in the device manager, hope you are using windows XP, try rescanning the the uusb ho9stcontroller in in the device manager.
Please let me know if you have further issues.
Mar 23, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
My slave hard disk is not showing in my computer
Is it formatted ? Does it have a drive letter associated to it? If not then either format it (right click on My computer -> click Manage -> click Disk Management. Now right click the drive if it is showing there and either create partitions and/or format it if it not already formatted.
If it's already formatted, and you just need to assign a drive letter, then in Disk Management, right click the drive and click Change Drive Letter and Paths and assign an unused drive letter, say Z.
Close Computer Management and open My Computer. The new drive should show up now.
HTH,
Deboo
Jan 05, 2009 | Seagate 250GB Maxtor DiamondMax Plus 21...
Maxtor basics external drive
Hi Nuisance101, I recall your running vista. Vista is a nightmare. If you cound only see the troubles we see on a daily basis here at FixYa you'ed understand. It's a common problem with Vista not seeing USB devices, externial devices. It does & then the next second it doesn't. Same for all external devices. I'm am 100% sure the trouble is not your system or your devices. It's Vista. I have gone over dozens of post from vista users. One would think MS has been on vacation since the release of vista. You can look at vista's web site for help for a possible fix, at this link. (I have no faith). MS blames driver software. Your Maxtor drive is external. Henve no driver software.
So it falls into that vista area of one time vista see's the drive & the next it does not.
Either way I though Maxtor addressed vista issues. I prefer Seagate drives myself. Personally know lots of people who's Maxtor's drives have just gone down for no reason. Seagate bought Maxtor.
http://windowshelp.microsoft.com/Windows/en-US/hardware.mspx
Most of the post from vista users, claim users should check vista's updates often. Since Max Blaster did its job, I'm inclined to blame vista.
I wish I could give you a better fix or suggestion but I'm up against vista. That's why I run WinXP Pro. I do not have these problems.
Best wishes Nuisance101!
Mike
Mar 30, 2008 | Computers & Internet
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
