Question about Hitachi 80GB IDE Hitechi DeskStar 7K160 7200RPM 8MB HDS721680PLAT80 0Y30001 80 GB Parallel Hard Drive
My pc don't detect hdd
My pc donot detect hdd
    Champion:
  • 331 Answers
TechRx, Inc. can fix it, http://techrxgb.com please be sure to rank me too.
Posted on Jul 23, 2010
    Sergeant:
    Novelist:
  • 172 Answers
Hi harbinderkur. If you have data on the hard drive, DO NOT try to use any software to test it, because it WILL stress your hard drive and probably you are going to loose your chances of getting it back.
Try using other computers, if you have a Windows PC try a MAC by getting an external hard drive enclosure and connect it via USB (believe me it works and also the other way around). Im talking about if you dont hear any clicks when starting the hard drive. In case you DO hear clicks (the famous click of death) then could be several things, the System Area, or the logicboard, the heads, the platters, etc (things you cant fix yourself) but please... in case your BIOS does recognize the hard drive, dont use any test software because you might make things worse. Like I said try other OS first. I hope this helps and please don't forget to rate and write positive feedback for our free support today. Thank you :D
Posted on Apr 29, 2010
PC not detecting HD
HDD not Detecting only if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
Thanks..
More Tech Support Contact
http://www.techsupportmart.co.uk/
Feb 05, 2014 | Transcend StoreJet Computers & Internet
Hello. My Lg Hxd5 500 GB external hdd is not being read. It was working properly but now the device manager is telling me that mass storage device is not installed. i tryed updating the driver but it...
Go back on Device Manager, right-click the HDD and choose 'Uninstall'. Go through this then unplug and plug back in the HDD. Hopefully if the drivers you downloaded are installed it will recognise it first time.
May 07, 2011 | Computers & Internet
No operating system found
check the bios setup for hdd detection if hdd detected in bios then reinstall or repair your OS
if hdd not detected by bios setup then you have to open hdd cover
you will find a fpc cable betwen hdd & mother board
just open the connector carefully & refit & apply a small tape pice on the connector lock after reinsert the cable
Feb 19, 2011 | Samsung X05 Notebook
GETTING ERROR: REBOOT AND SELECT PROPER BOOT DEVICE OR INSERT BOOT MEDIA IN SELECTED BOOT DEVICE. WHAT DO I DO?
its not detecting your HDD. on boot enter BIOS & check whether your HDD is being detected by the MB. IF not(most possible) then check the power & data cables to your HDD, Check your SMPS too, if SMPS OK then your HDD is corrupted. GET new HDD
Jan 01, 2011 | Gateway 552GE PC Desktop
Wish to change the HD for HP D5100 SFF
For Changing the HD do the following
1. Take the Backup of all the required file from the HDD to DVD or tapes
2. Shut down the system
3. Remove the power cables first
4. Remove the side cover of the CPU
5. Carefully remove the HDD Power connector and IDE Cable or Sata Cable
6. Un Screw the HDD Screws
7. Remove the HDD Carefully
8. Place the New HDD and Screw it carefully.
9. Plug the Power Connector of the HDD and IDE Cable or Sata Cable
10. Plug the Power cable and check that the HDD Is detected.
11. If detected install the O/S as required by you
12. If not detected check the HDD Power connector and IDE Cable or Sata Cable
Let me know that i Fixya! the problem
Thanking you.
Nov 27, 2010 | HP Compaq dc5100 PC Desktop
If the harddisk conected in your system are not dected
"ASSUMING YOU ARE USING A SATA HDD"
check the bios settings.....
if your hard disk detection is enabled or not...
if yes...(yet your system is not detecting your hard drive)
then....go the manufacturer's site and download the respective sata driver of your hdd (particular model number)...
burn it into a cd...
insert the cd into a usb cd rom/writer.....
then try to install windows.... let the system boots from the cd
at the time when it says "press f2 to install driver"
press f2...
then browse to the location i.i. usb cd - rom/writer and install the driver...
now your system will detect your hdd...
if this info is useful
don' t forget to say thanks...
Dec 16, 2009 | Computers & Internet
My hdd sata is not detected by motherboar.
brohter you should chek you r hardisk and then check ram GOD WILLING YOUR PROBLEM WILL BE RIGHT IM RIAZ AHMED BROHI FROM PAKISTAN PLEASE EMAIL riazbrohi@gmail.com
Jan 24, 2009 | MSI K8MM-V Motherboard
I have 20 GB HDD which can'not detected is any software detect it
try to check it on CMOS setup, and see if ur HDD is detected there, then also check the jumper settings of your HDD, is it connected as master drive, or slave, then check other devices jumper settings for CDROM or other HDD connected to your PC. (do this for initial troubleshooting)
Dec 14, 2008 | Symantec Computers & Internet
My brand new ASUS ee PC notebook won't boot up. Any suggestions?
check in the bios settings if the hdd is detected..if detected,you need to re-install the windows..if not detecting,you must replace the hdd...ahh! i think the hdd for this laptop is expensive..coz i know its something special..not same like normal hdd in laptop,like ide or sata..its small hdd inside the board...half size for the 2.5" hdd sata or ide
Nov 23, 2008 | ASUS Eee PC 900 16G Notebook
Suppend HDD sunddenly can't detect
nahh sounds like bad pcb board of hard disk. check in bios to see if its detecting hdd.
if it is then id say try ubcd4win.com to boot pc with or without hdd to test pc and ram.
sounds like an old hdd.
Jul 22, 2008 | Maxtor Hard Drive
Hitachi 80GB IDE Hitechi DeskStar 7K160 7200RPM 8MB HDS721680PLAT80 0Y30001 80 GB Parallel Hard Drive Logo
141 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
