Question about Maytag Legacy MAV208DAWW Top Load Washer
Washing machine does not fill up with water, water continues to run, but does not fill. Seems like it is draining at the same time it is filling. Ideas?
  • 1 more comment
  • mobilebipod Apr 29, 2010
    As the washing machine is filling to wash, it is draining out the hose from the back of the washer and into the pipe through the wall. Prior, the water would fill the tub, wash then drain. Water is allowed to drain when it should not. Thank you.
  • Rick Ead
    Rick Ead May 11, 2010
    pull out the hose that goes to your drain check to see if it is actaully draining. Does water go into the tub?
  • 1,998 Answers
Check to see if your pressure switch is working properly if your pressure switch is working in proper order then you would have to look at it being a timer problem
Posted on Apr 29, 2010
I have a W 2104 washing machine , the program seems to not work properly , when the water comes in it straight away pumps the water out again and repeats this cycle
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
And in some modern washers that come with THERMISTORS:
One symptom of a washing machine that thinks it's overheating and thus fills and drains at same time ( possibly because of a faulty thermistor) is if it's filling with cold water and pumping out at the same time. This is covered in this articleWashing machine fills and drains at same timealthough the same symptom can be caused by other faults.
On some models that have belt drive the WIGWAG selenoid could be defective or the spin and agitate bars could be bent or worn, or the spring worn or broken.
By the way my advice is free cuz God is good!
Mar 24, 2017 | Washing Machines
Machine fills, agitator not working, washing machine empties
May 29, 2015 | Washing Machines
I have an Estate heavy duty top loader that continually fills then drains and constantly runs water never initiating wash cycle
Apr 26, 2014 | Estate Washing Machines
The water is continually running in my maytag atlantis it seems like it has lost its ability to stop the fill process at the right time.
Try unplugging the machine then plug it back .. this may reset the electronics .. if not ... call a repairman.
Jul 02, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Water doesnt stop fillinG in panasonic NA F60A6 WASHING MACHINE
Fyi. All new washing maching already tested on their functionality and features but not test run with water intake and drain function. I would like to share My experience last time with this model. The water outlet valve will release by motor when you set to drain mode.it suppose manage to retract back by spring when drain process finish or afte small you change to wash mode.
Take a look on the spring movement.normally it not properly hold valve switch hence the retracted spring not block the valve to stop water drain. Just rectify the alignment of the valve swich which directly connected to the retractable spring.
Dec 26, 2010 | Washing Machines
Frigidaire glws1233as1 water runs continually. seems like a valve is stuck open or something. water is draining as fast as it is filling up.
your drain hose or drain is too low causing water to siphon from the tub as fast as it runs in. raise or loop the drain hose higher than the highest level of the tub.
May 28, 2010 | Washing Machines
Water runs continuously tub never fills My Fisher & Paykel top loader keeps filling and draining at the same time. It never gets full of water. The hose is way higher than the machine, but still drains...
where is water draining into? have u got grey water hose attached to it?make sure u can see end of drain hose, put into bucket at lid level, if it still drains as it fills u have a faulty control module.please reply for more help
Apr 06, 2010 | Fisher and Paykel IWL12 Top Load Washer
Continues to fill, not holding water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
If the above adjustment doesn't produce positive results, replace the control.
May 31, 2009 | Crosley Washing Machines
Water running out when washing machine is filling?
Hi jojolevaokah
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
Apr 07, 2009 | Whirlpool LSQ9520L Top Load Washer
Washing machine filling with water while not running
youll need to replace the water inlet valve, its not seating properly after fill, and continues to leak into machine.part number 8181694. in hte ean time you can turn off water supply to machine inbetween wash loads.A good habit to be in anyway.
Mar 17, 2008 | Washing Machines
Maytag Legacy MAV208DAWW Top Load Washer Logo
276 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
