The drum on my washing wachine has stopped turning although the motor is still going what could be the problem?
  • Rick Ead
    Rick Ead May 11, 2010
    drive couple which connects the motor to the transmission check under neathin between the the motor you can usually feel if theres a break between the couple not sure which model you have but on most top loaders when you have no spin or agitate this is one of the first things you check for
  • 1,998 Answers
Check the drive couple it connects the motor to the transmission have some one hold the machine up feel with your finger the roud rubber disc between the motor and the transmission make sure the machine is unpluged whenu do this you can aslo remove the motor for a better visual inspection of the area part sells for around 14.00 hope this helps
Posted on Apr 29, 2010
Testimonial: "Thank u!"
  • Washing Mach... Master
  • 3,361 Answers
Your drive belt is broken or slipping on the motor pulley.
Drum won't go round when loaded although will rotate by hand
Can you hear the drum motor running when you switch the machine on? You should hear it running and stopping periodically.
If the motor is running but not turning the drum then the drive belt is either broken or has become detached. It can be replaced by gaining access to the back of the machine.
If the motor is not running then it could be one of several problems - programmer mechanism not working, motor burnt out, motor brushes need replacing etc.
Jan 04, 2011 | Hotpoint Washing Machines
Drum has stopped moving
Hello, these is usually the drive belt,the drive belt is the easiest parts to replace.
Thanks
Jun 10, 2010 | Hotpoint WMM39 Front Load Washer
No drum movement during wash/spin cycle, although it fills/drains
brushes need replacing in motor. Usually cheap enough to buy and do yourself.
Jun 02, 2009 | Hotpoint WMA46 Front Load Washer
Indesit WG1234T washer drum not turning
hi there..by the sound of things,the brushes on the motor are worn out.easy to replace,each brush is secured by two screws at the rear of the motor,and will be black in colour,or a reddish colour.it may be easier to remove the motor to gain access.buy a cheap set from ebay,as generally speaking a repair and spares shop will ask four times the going rate.anyhow,once removed there should be at least 7mm of carbon left to make contact with the commutator(the part of the motor that turns)
hope this helps,steve.ps.the belt could have snapped or come off also....
Apr 13, 2009 | Indesit W 123 Front Load Washer
Drum not turning
If you are certain that the motor was turning, then the only things that come to mind are that:
  1. The belt is stretched or worn-Replace as there is no adjustment.
  2. The drum is stalled, either because it has seized, or there is something stuck in the drum.
  3. The motor brushes are worn, and will not cope with load of drum, check brushes.
Try running it on fast spin without the belt on , if it spins o/k, then that would indicate the motor is o/k.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine WK61420GB drum does not turn
replace the brushes in the motor ( approx £5 parts)
Dec 30, 2008 | Siemens WK61420GB Front Load Washer /...
Indesit WD 10 wachine machine : how to loose the drum
There is usually a bolt on the bottom that holds the drum stable during shipping and who ever put it back on a used washer is goofy!
turn it over and you should see a big bolt
Oct 17, 2008 | Washing Machines
No longer rinses or fast spins...although drum does go round slowly... My WMA 13 First Edition Hotpoint has stopped fast spin, so although the drum does go round, it does not speed up to a fast spin at...
LETS check the DRAIN MOTOR PUMP it could be clogged , open panel of washer to access inside , look for a small motor with 2 hoses connected to it , take it out , clean it , re install and try it again , hope this helps AJ
Apr 14, 2008 | Hotpoint WMA13 Front Load Washer
Open Questions:
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
