Question about Vizio L37 Television
No sound after I change the channel. If I turn the
No sound after I change the channel on Vizio. If I turn the TV off, then back on, sound is ok. Using Verizon FIOS
There is an incompatibility between Fios and Vizio audio. To fix the problem, on the Fios box, press "Power" then "Select" then "Menu", one right after the other. This accesses a secret menu on the Fios box. Using the arrow keys on the front of your Fios box, arrow down to "Additional HDMI Settings" then press the right arrow. Another menu will appear (may take a few seconds). Arrow down to "Audio Out" and press the right arrow to change from "Auto" to "L-PCM". Press the Power button to exit the menu. This should solve your problem. Thanks to Vizio tech support for the answer.
Posted on May 01, 2010
  • 2 more comments
  • aztimmy805 Dec 30, 2010
    I am experiencing the exact same issue with Verizon Fios and my Vizio 37 inch SV370XVT and tried to execute the "power" then "select" then "menu" steps to get to the secret menu. Since there is only an "OK" button on the actual box (as opposed to a "select" and/or "menu" button), I pressed "power" then "ok" twice. This took me to "Diagnostic Menu" and gave the following options - none of which are the "Additional HDMI Settings":
    d01 General Status
    d02 Purchase/Poll Status
    d03 OOB Status
    d04 Inband Status
    d05 Unit Address/Security
    d06 Current Channel Status
    d07 Upstream Status
    d08 Code Modules
    d09 Memory Config
    d10 Audio/Video Status
    d11 Interface/Port Status
    d12 User Setting Status
    d13 DVR/HDD Status
    d14 Application Specific Information
    d15 Interactive Status
    d16 Connected Home
    d17 Keypad/LED
    E Exit
    I figured that the d10 option "Audio/Video Status" was the closest, so I selected that option. I did not see any options here to change any "Audio Out," or any of the other options for that matter, so I decided to comment on this post. Here is what appears on the "Audio/Video Status" scree n just in case this helps:
    SPDIF: Dolby Digital LFE: 0
    Audio Mute: On
    Video Mute: Muted
    Captions Detected: 608
    608 Default Primary Lang
    Digital Subtitles Status
    Enabled: No ISO Lang: eng
    Enhanced: No Rendered: no
    PiP Focus: N/A
    Output Format NTSC
    Input Source N/A
    ADP Lock: N/A
    Audio Mode: N/A
    VP Lock: N/A
    Input format: N/A
    Can you please help?
  • theshocker9 Jan 04, 2011
    You have NO IDEA how much this helped me. I had the exact same issue
  • aztimmy805 Jan 07, 2011
    Just figured out that in order to access this FiOS Secret Menu on the newer Verizon FiOS box, you must press 'Power' followed by 'OK' both on the box itself, and then press 'Menu' on the FiOS remote. This will take you the Secret Menu with the "Additional HDMI Settings" option. Otherwise, if you press "Power" then "OK" twice on the box itself, you get to the Diagnostics Menu which is of no help. Phew - thanks for the original post tester527! HUUUUGE help!
  • Ken Jan 11, 2011
    @aztimmy805..... Do you have to hold the 'OK' button on the STB while you press the 'Menu' button on the FIOS remote? Please give me step by step instructions. Is the TV on? Do you press the 'Power' button on the STB to power off the STB or to power on the STB.
    Thank you for your help
Hi, for the new fios box, the three button should pressed discretely, i have just tried.
cheers
Posted on Oct 03, 2012
Why does the sound on my Vizio tv keeps turning off ?
There are 3 possibilities, is the mute icon showing when the sound goes out as you change channels? if so then something isn't right with the remote or the remote sensor circuitry..if that looks ok chances are its a bad main board however if the supply voltage to the sound circuitry is falling off then the power board could be at fault, best chance though is a bad main. If you would have listed the model I could pull up a schematic and see if the voltages that feed the sound are local to the main or if they come from the PS.
Nov 01, 2017 | Vizio Televison & Video
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
Can't change to channel 3 to use the dvd player
Your Vizio TV should have provisions on the rear panel for direct connection of your DVD player. Use those connections and select your DVD player as a video input.
Mar 08, 2018 | Vizio 42 in. LCD TV
When I turned on my vizio vo37om this morning, there was no picyture, screen is black. Sound is fine
Dim the lights in the room, turn on the set. Shine a bright flashlight on the screen, do you see a faint picture?
Feb 11, 2013 | Vizio VO370M LCD TV
I have a VIZIO LED/LCD VF551XVT hooked up to a motorola HD DVR with a HDMI cable. When I switch from standard Def to High Def channels I lose the sound. If I turn the TV off/on the sound returns but if I...
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Feb 01, 2010 | Vizio VF551XVT 55 in. HDTV
Vizio 32" Channel Scan Issue
The problem is a defective main board, the EEPROM on the board is defective.
May 30, 2017 | Vizio VW32L 32 in. LCD HDTV
Picture but no sound on my Vizio L37 Flat Screen
I had the same thing just happen and I used the following instructions from the Vizio Website for "humming sound" on tv and it worked. My sound is now working!!!!
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on.
Reset the TV settings.
Jan 29, 2009 | Vizio GV42L 42 in. LCD Television
Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Oct 22, 2008 | Vizio GV42L 42 in. LCD Television
Vizio L37 Television Logo
3,028 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
