Just had 2 outside light bulbs replaced ; now i have a indicator light on my dashboard that looks like an upside down antenna with a half circle next to it. Not sure what status this indicates.
That is a common problem when one of the turn signals bulbs is out. check the light bulbs on the side that is not working or the side that the dashboard flashes quicker. replace the light bulb front or rear. take a good look at the light bulb filament inside. some times is not easy to detect some other time the light bulbs will be light black powder inside if they are bad. if the light bulb does not fix it also check for the fuses may always be fuse as well.
you need to disconnect the speedometer then remove the 6 or 8 screws that hold the instrument panel to the dash.if its an automatic you will have to unhook the shift indicator cable from the shift colume.then pull the instrument panel out of the dash,turn the panel upside down and you will see the bulb sockets.replace all the bulbs at this time so you won`t have to do this again for another bulb.when hooking up the shift indicator cable make sure it indicates the properly selected gear when moving the shifter to each gear position.
Look in your owners manual, see how to replace tail light bulbs. If they are removed from the light assembly and changed from within the trunk, then open the trunk, turn on the lights and pull the bulbs out one by one. You may find that more than one bulb is used on each side for the tail light, and though it looks good from the outside, one could well be burnt out. Read the instructions closely, you may have to turn the light socket 30 degrees or so to pull it out of the asembly.
This is a warning message about a burned bulb of a car lamp. Check all car lightnings: tail lamps, headlamps, turn lights, stop lamps, reverse lamp, fog lamps, ... Replace bad bulb(s). That's all.
Circle with dashes on the outside is brake pads worn indicator. The light bulb looking one is exterior bulb out indicator, the triangle if you have it is ASR slip.
