My washer will not spin.
One fine day I was doing my wash and it filled up with water, but would not go any further than that. I called the Roper folks and they said it sounded like a timer issue. Checked the lid switch. Nope. Checked timer, then replaced timer. Nope. At a loss and laundry is piling up. Please help!
Roper Washer, 6 years old, model # RAS8244LQ1
  • Washing Mach... Master
  • 43,501 Answers
Have you checked to see if you have power going to the motor?? May be a motor...if you have power there and no go...if not follow the wiring and see where the power stops at...there is your problem.
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 29, 2010
  • 12,061 Answers
Http://appliancejunk.com/forums/index.php?action=downloads;cat=16
OK go to the above and get a service manual, they are all very similar, so it doesn't really matter, and perform the troubleshooting procedures, and you should be able to find your problem. It is possibly your pump, or a sensor.
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Jan 07, 2014 | Roper Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
Washer fills with water, will not do anything else.??help
machines wash with lids open or shut they don't spin when lids are opened. post your model number for further assistance
Mar 27, 2009 | Roper RAS8445KQ Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
My Roper won't fill with water.
you need to replace the water inlet valve on the washer that the hoses go on,it is stuck closed,have you tryed hot water only to see if it comes out?the valve has a hot and cold water supply valve,you can get one by going to sears .com click on parts out in your model number and order your part,let me know if you want to try it and i will tell you how to get into the cabinet-mike
Nov 18, 2008 | Roper RAS6233KQ Top Load Washer
Roper washer top loader spins very slow
if the appliance has a induction type motor could be that the running capacitor is failing coul be the motor itself
Sep 16, 2008 | Roper RAX4232KQ Top Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Oct 27, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
