Question about Frigidaire GLEQ2152ES Electric Dryer
Want come on
Smelled like it was hot wouldn't turn back on
  • Frigidaire Master
  • 43,501 Answers
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 29, 2010
When a electric water heater smoking and it gits turned off at the breaker box will there be a chemical smell after
No. A water heater is a sealed system it needs to be addressed for the original problem. High sulfur content has been a complaint as far as smell,and I remove the anode and replace with a brass plug because of. Shallow wells in the area largest complaints.
Nov 27, 2014 | State Water Heaters 40 Gallon Select SL...
Fuse rx 570 pioneer stereo
Sounds like you have a much bigger problem than just a fuse. Popping sound and burning smell means something much more serious.
Jun 18, 2013 | Audio Players & Recorders
1997 nissan pathfinder smells hot after running awhile
Check your valve cover gaskets, bet they are leaking and that is burning off.
Jun 27, 2017 | 1997 Nissan Pathfinder
I started it I put gas and it smelled like a burnt metal smell and I turned off then it wouldn't start. When it finally did start I couldn't shift past 2nd gear. I was already low on oil.
Yup! Running it low on oil can definitely cause a "burnt metal smell". It can also totally destroy the engine before you can ever smell it.
It sounds like something that needs to be checked by a professional auto repair technician to me.
Mar 24, 2012 | 1999 Chrysler Cirrus
We purchased a Kenmore Window Type Room Air Conditioner Model 23.70062 about three weeks ago. Tonight, as I was sitting next to it at my computer, I smelled a funny odor which seemed to come from the air...
Well, if you are concerned about the refrigerant leaking, you don't have to be,it's nontoxic- I wouldn't recommend breathing it and it could make you dizzy but not bad in any long term way. if you can handle turning it back on and it still cools, then you probably haven't lost any charge. I would check the filter next-maybe it got contaminated somewhere, or maybe there was some wire insulation getting hot. I wouldn't attempt repair- The store should exchange it for you
Jul 03, 2011 | Kenmore Heating & Cooling
2001 aurora when fan is on high for a period of time it smells like the header is burning.
Not sure what a burning header smells like, but I would expect two possible smells. First, if the blower motor itself is going, you might smell the windings getting hot - like a transformer burning. If this were the case I would expect that the motor wouldn't spin on the low speeds.
The other smell you sometimes get is when the heater core leaks. Then you will get a coolant smell inside the car and sometimes (usually) a wet carpet as well.
Feb 22, 2011 | 2002 Oldsmobile Aurora
Dryer smells hot and back panel near heating
your duct is clogged or the limit snapstat is not working. turn dryer on and go outside to the duct vent , their should be a minimum temp of 10 degrees, and a maximum 15 degrees outside. also sometimes just cleaning the lint from inside the dryer, can cause this smell for no more than 5 minutes. thanks karl
Dec 15, 2009 | GE DBXR453EV Dryer
Hot poinbt gas stove , mouse inside,
We had this happen recently. The smell of urine got to be too much. My wife wouldn't even go into the kitchen. I took the stove apart. the insulation under the range, which is where he was living, was soaked in urine and **** .I removed all the insulation. Spoke to a repair man. Replaced insulation with pink house fiberglas insuation and gave it a good cleaning. Smeel is gone. Repairman said this happens all the time and is a an easy but labor-intensive job. Call someone to do it if you aren't comfortable taking your stove apart.
Oct 22, 2008 | Kitchen Ranges
Frigidaire GLEQ2152ES Electric Dryer Logo
53 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
