Question about Kenmore Elite HE4 Electric Dryer
I keep getting the error "E1" & the dryer turns off ...what does that mean?
  • Scarp Apr 12, 2008
    dryer keeps shutting off. the error code is E1. Mod#11092826101
  • Anonymous Mar 22, 2014
    I get the E1 error message on the dryer and it stops/turns off
I've read in other forums that E1 means the thermistor has failed. As far as I understand, it monitors the temperature of the air that is leaving the dryer and entering the dryer vent. If you're not handy, a service call is in order.
Posted on Apr 21, 2008
SOURCE:
What is an E1 error code? what does it mean?
Go to google and ask what does E1 error code mean on a Kenmore Dryer (Model #) and you will get several answers
Jul 29, 2015 | Kenmore Elite HE4 Electric Dryer
Shortly after starting a load in the dryer, the dryer stops, beeps and the lighted code says E1. The grid on back wall of dryer is very hot. I am unable to find my instruction booklet. This keeps...
The E1 error code means that the electronic thermostat is the problem. With what your describing as far as it being very hot and the E1 code,i would suspect one of 2 things;
1) the thermister is bad and needs to be replaced
2) thier is a blocked/restricted vent and or excessive lint built up in the blower housing causing the heat to be retained in the dryer instead of being vented out and across the thermister where its getting a false reading and throwing up the E1 error code
GENE
Sep 12, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Error code E1 what does it mean
The problem is an open thermistor as what error code E1 means. It's either the thermistor is exhibits an extremely high resistance or the wire harness connecting it to the control board is broken or cut open. Click on the link below for the detailed procedure in troubleshooting this error code.
Troubleshooting Error Code E1 on Whirlpool Duet and Kenmore Elite Dryers
Aug 27, 2011 | Kenmore 62602 Electric Dryer
The dryer shuts off, keep getting an E1 code, what needs to be done
It sounds like this is a Whirlpool Duet or a Kenmore Elite Dryer due to the error code E1 being available only on this models. The problem here is an open thermistor as what error code E1 means. It's either the thermistor is exhibits an extremely high resistance or the wire harness connecting it to the control board is broken or cut open. Click on the link below for the detailed procedure in accessing the thermistor.
Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Measure the resistance of the thermistor and refer the table below. Normal thermistor resistance is around 10000 ohms (10K) at room temperature.
Replace the thermistor if the resistance is significantly higher (or lower) than what it is supposed to be based on the resistance table above. Check the wire harness connecting it to the control board, if the resistance turns out good, and make sure the connectors are good and the wires are intact. Replace the wire harness if necessary. Consider replacing the control board if both the thermistor and the wire harness turn out good. The link below might enlighten you further on the troubleshooting of the thermistor.
Thermistor Troubleshooting on Whirlpool Duet and Kenmore Elite Dryers
Aug 21, 2011 | Dryers
What does E1 mean?
Welcome to FixYa.
Can you possibly double check that model number and reply post. I ask because the "E1" error should only pertain to those models which are condensor (non-vented)... "WTL" dryers.
The error indicates either a blocked drain hose or a failed pump. This from Bosch...
E1 Pump failed
(WTL 5400condensationdryer only) Pump failed.
Check voltage at and wiring to pump.
Turn off dryer, measure pump resistance (110 - 136 ?) and replace faulty pump.
Also - Following items apply only to the WTL (Condensation Electric Dryer) models
Cycle is interrupted and ''E1'' appears in display• Condensate hose is blocked in some way. Turn off dryer and check hose.
I'll watch for your reply and try and help you move forward in any manner I can.
Regards,
Macmarkus :)
Apr 14, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Error Code
open the thing up and locate the service manual. once located it should list what that error means. alternatively call bosch and ask them.
Aug 25, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Error E1 mean?
An E1 error message usually indicates that the thermistor (see the following link) is defective and needs to be replaced.
http://www.appliance411.com/data.php?rc=548392
pls rate my suggestion...
Jun 26, 2009 | Whirlpool Washing Machines
My whirlpool gas dryer keeps coming up with E1 error code after drying for about 50 min, model ggw9200lwo. Any solutions to what the probelm might be?
The E1 code means there is an open thermistor. This thermistor is located on top of the blower housing. Access it by removing the bottom panel on the front of the dryer. This device is not repairable, so unless it's just a loose connection or the device is not firmly mounted, it will need to be replaced.
Unplug the dryer before you work on it!
Mar 28, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Error Code E1
replace the thermistor
Dec 20, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet dryer error code E1 keeps coming on after a few minutes of running shuts down dryer.
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Aug 05, 2008 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
344 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
