Question about Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher
Gritty/sandy feeling on dishes from dishwasher
After cycle is complete, using any kind of detergent, dishes have a feeling like salt dried on them...why? It's a Frigidaire UltraQuiet 111. Techs have been to the house. Was told it's junk. Got it new in 2006. Can anything help?
    Novelist:
  • 145 Answers
You could only check the basics. Since the dishes are clean, it means they went through the wash cycle. It also means that that the holes on the washer arm are not blocked. If they were salty and dirty the wash arms would be something to check. And since they came out feeling like salt is on them its possible they didn't rinse and its also possible the dirty water didn't drain.Were your drain and fill hoses checked or did the techs just check the dish washing machine itself? Its also possible the water for rinse is not hot enough. Before the rinse cycle comes around try running the hot water at your kitchen faucet. Any other issues may be within the cycling of the machine.
Posted on Apr 29, 2010
Milky water when rinsing in dishwasher & gritty covering on dishes
I have spent many years (47) in the catering industry using catering dishwashers, under counter models, corner- wash stations and also conveyer machines..
The milky water is a by-product of the wash water and rinse water mixing.
The spray are has to rotate freely or the dishes won't wash or rinse properly. They spins a lot faster than you realise and this adds pressure to the water, but also a pulsating effect to remove dirt.
Over doing the salt can cause more problems that it solves. The gritty film may indeed BE salt. I actually prefer Calgon as a softener.
My advice is to remove both top and bottom spray arms. Check the slots/holes for obstruction, and run water through them under a tap, outside to inside (the opposite to how it is in the machine) rocking the arms up and down to allow any obstructions to flush out. Lemon pips and toothpicks are out biggest problem! Put the arms back and make sure they spin freely. Sometimes they just lock up for no apparent reason!
Use CLR descaler in the machine to clean it using the instructions on the bottle. Then run the dishwasher using the recommended doses of detergent and rinse aid.
Jan 19, 2016 | Siemens Dishwashers
Keeps leaving dishes gritty after wash.... Have cleaned everything possible
Do you live in a region with hard water? Most detergents don't work very well with hard water because phosphate is now outlawed as an ingredient in dishwasher detergent. Weird but true. Here's a map to show the water hardness in the US.
http://www.citriclean.net/why-citriclean/
Mar 19, 2013 | Indesit Dishwashers
My dishes come out with a gritty sand all over them.
If you live in an area with hard water, the grit is probably hard water deposits. Dishwasher detergents no longer contain phosphate, so the detergents often leave behind hard water deposits on your dishes. There is a great solution at www.cloudydishes.com
Oct 15, 2012 | LG LDF6920ST Stainless Steel 24 in....
I have used dishwasher cleaners, use Cascade Complete dishwahing detergent but all of the sudden, my dishes come out of the dishwasher dirtier then they went in. The glass glasses have a gritty stuff...
depending were you live they changed the formula in cascade,but they are doin a new formula are you using a rinse agent? claean the machine clean spray arms and soap dispencer,with no dishes run machine with 1cup of CLR or 2Cup of vinegar just pour in tub and let it run full cycle no drying.Thanks
Jul 31, 2010 | Whirlpool Dishwashers
Dishwasher leaving a white film on dishes after wash/dry cycle
Well, that usually happens if the water in the area has too much alkali metals, such as calcium and magnesium.
Try putting some salt together with the detergent before you start the cycle.
And if it still does, try washing the finished dishes again with clean water, i mean, without detergent...
Mar 18, 2010 | Kenmore 16764 Dishwasher
Dishes aren't clean. i have run vingegar and CR through the cycle but dishes and glasses still have a film.
The most common cause of film left behind is a broken heating element.
The heating element is not only used during the dry cycle, but also to raise the water temp. during the main wash cycle to activate the dishwasher detergent. Fixing the heating element should "clear" this problem right up!
Aug 04, 2009 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishwasher leavin something on dishes after washes
gritty ? This can be either the poweder or detergent you are using.Cheap HOME BRAND type. Other than that it is possibly hard water buildup where calcium is now being baked on the dishes in the drying mode.
Try using a Dishwaher Cleaning package by FINISH to see if this helps it
Aug 01, 2009 | MSI 865PE Neo2-V Motherboard
KitchenAid KUDR01TJ Dishwasher Cleaning Problem
Sinder...this sounds more like a water temperature issue than anything else. First, turn on your hot tap. If you can't hold your hand under it after it fully heats (over 125)...you should be okay. If not, raise your water temp or use the sani cycle to raise the temp. Change brands of detergent. Salt...I don't think so. You're using detergent...not soap...which would have been affected. Pressure should not be an issue...once the unit is filled, it makes its own pressure recirculating with the wash pump.
Oct 13, 2007 | KitchenAid KUDR01TJ Dishwasher
Whirlpool ADP 5966 Dishwasher using the complete salt load in 6 washes and coating all the dishes in salt that would not rinse off. I filled the salt and 6 washes later it was requiring a new load of...
Hello, we are sorry to hear that you are experiencing this problem with the Dishwasher. We would recommend having a certified technician out to diagnose the problem. If you would like further assistance you can send your name, phone number, address, model/serial numbers and the date on which you purchased the Dishwasher to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 17, 2017 | Whirlpool 24 in. ADP5966 Free-standing...
Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher Logo
750 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
