Question about Raymarine Type I Linear Drive M81130
Clutch failure of Raymarine M81130 linear drive
When autopilot activated, motor runs but linear drive not gets out.
Assume clutch does not operate.
  • 64 Answers
Try putting 12 vdc directly to the clutch circuit. You should hear the clutch engage. If this is operating properly, then the course computer circuit has failed. If this is not working then the linear drive needs to be rebuilt.
Posted on Jun 14, 2010
  • 38 Answers
You can also check if the clutch wire is not broken outside or inside the unit,use a multimeter to check resistance of wire and clutch inductor.
Posted on Jun 22, 2010
Leaking hydraulic fluid
Sounds liek the seal is not seated properly. If it is new and leaking, take it back and ask for a repair/replacement. There should be a warranty in place.
Jul 20, 2013 | Raymarine Type I Linear Drive M81130
Have a 2009 Catalina 375 sailboat. It has a raymarine st6002 S1 linear autopilot. When I set to auto on the st60, it may work for a while then quit. Other times, it says it took over but doesn't. I...
Your description of the motor running but no output certainly does sound mechanical. Sometimes things get stripped. Usually there is some other sounds, sometimes not, based on the number of teeth, etc.
I would be tempted to open up the gear case of the unit.... One detail of interest to me, do you have an opinion of the position of the device when it fails? For example: extended or retracted always has the unit stop.... The reason is imagine a tooth missing at one position, ....if you somehow got past that position, presto function....until the unit went back across the problem position....
I expect that there are electronics that decide what your auto pilot should do, but it boils down to a motorized unit, and IF, as you describe, that units' motor is actuated, I would expect output of some kind. The picture shows what looks to be a tiller mount controller, also there are other designs that may connect to your wheel, or some connect down at the rudder post...All need to go one way or the other when the motor is energized.
Do keep after and make this unit work, I think it helps you be able to run the vessel with less help....
Doc
Jul 08, 2011 | Raymarine St6002 S1 Sailpilot Linear Drive...
My st4000 mkII shuts off from auto mode whhen i engage the clutch lever and the wheel turns for a second. the screen goes blank and just displays "st4000" . voltage is fine and all wires are connected....
CHECK THE POWER SUPPLY WIRING ,If it worked before ,could be corrosion or lose wire connection,or terminal bad crimped,or terminal loose inserted.
If it is new installation ,power wires could be undersized,or battery discharged .
Normally autopilot shuts off from auto and restarts when power supply voltage drops under the reset voltage ,when the wheel turns ,the motor current increase and the power voltage drops when the power supply wires are not OK.
Apr 06, 2010 | Raymarine St 4000 Wheel Drive E12093
Service Manual for Autohelm's st4000 Wheel Drive Autopilot
Hi, If you are looking for Autohelm service manuals you may find them at http://sdmarine.online.fr/Service%20Manuals/Autopilot%20Systems/
Dec 18, 2009 | Raymarine St 4000 Wheel Drive E12093
Autopilot shows "no rudref"
The rudder sensor works like a light dimmer, so you get 5V and ground on the outside two connections and a varying voltage between about 1 and 4 volts depending on rudder position
847-746-0100 www.technicalmarine.com
Jul 07, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
Raymarine autopilot swings hard over immediatly i select auto
CHECK RUDDER REFERENCE UNIT FOR CONTINUITY(IT IS A POTMETER) CHECK IF MOTOR IS RUNNING IN THE CORRECT DIRECTION ,CHECK CONNECTION OF RUDDER REF UNIT.
Apr 04, 2009 | Raymarine St8002 Smartpilot Autopilot...
Installing a Raymarine 8002/6001 on my 2005 Sea Ray 270
If you have a basic knowledge of electronics and can follow instructions. It's easy the hardest part is connecting the pump and bleeding the system.
Feb 19, 2009 | Raymarine St8002 Smartpilot Autopilot...
Raymarine Type I Linear Drive M81130 Logo
502 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
