Question about Enterasys Networks TRAPEZE DUAL BAND OUTDOOR AP (TRPZ-MP-620) (TRPZMP620)
Trapeze AP MP 620
Hi , I have Trapeze AP MP 620 , didn't appear at switch as connected i tried to check the connection by easy way take AP outside alone connect it to it adapter the connect adapter to port at new switch working proper but the led of the switch off , then the switch after bit minutes begin many leds on it turn on random and hanged totally.
  • Mario Rasmy Apr 29, 2010
    Dear ,
    Actually i found tthis reset button inside the AP after removing the external case , THEN I CONNECTED IT TO MY TEST switch its working , But after i install it again at it place onsitte doesn't work again , So i doubt the problem now at ehternet cable length so i will make fluke test for this cable at sunday and reply you back .
    Thank you very much for your support
  • Mario Rasmy May 04, 2010
    Thank you for solution , It was need reset actually
    President:
  • 4,070 Answers
Hi! Please try this, If you can find a small hole with a button that only a paper clip or pen can fit that would be the reset. You may press this button for like 5secs. to reset the system and it may go back to its normal working. HOpe this helps and have a good one!
Posted on Apr 29, 2010
  • dj_relly999
    dj_relly999 Apr 29, 2010
    Alrighty, hope to here from you soon, good luck!
How do I recover the enable password on my Trapeze mobility exchange mx-8. Or how do I do a factory reset?
Hi Mate.
In case you still need to do this, or in case someone else stumbles on this problem and needs an answer, below is the the solution.
Connect to the MX device via console cable and recycle power.
Interrupt the boot process by pressing "q" followed by the "Enter" key when prompted.
at the boot> prompt enter the following command:
boot> boot OPT+=default (NOTE: This is case sensitive) and press "ENTER"
Presto, your devices boot with factory defaults.
Aug 28, 2012 | Juniper Trapeze Networks Mx-8 Wlc8r...
I have a 2002 Ducati 620 that will not start. All lights and guages work and the motor turns over but will not fire up. Help!! Thanks, Brian
Hi, Branda844 and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
2005 Ducati Monster 620 Wont Start
My 02 620 won start
2004 2006 Ducati Monster 400 620 Motorcycles Service Repair Manual Highly...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
May 27, 2011 | 2005 Ducati Monster 620
I have a HP ProCurve MSM 410 AP. It will accept clients and then in 20 minutes it starts dropping connections..and will not let them back on with a restart. I have poured over the specs for both AP and...
I'm having a very similar issue with 5 MSM410's (at 2 differant locations), purchased at the same time, from the same vendor.
With 2, when connected using PoE Injector, the AP gets hot (at the Data/Poe port), and only permits 3 devices to connect before the devices start losing the ability comminicate beyond the AP (i.e. I can logon to the AP with the Web Interface (WI), but cannot ping the DHCP server or even the Gateway device on the other side of th AP from the devices, but can ping both directions without issue from the AP's WI). HOWEVER; when connected using the PoE from a Cisco ASA-5505 (port 0/6 or 0/7) the devices work flawlessly.
- For this site, I replaced the Power Injector first, then replaced the AP. No change
- When connected to the PoE on the Cisco the unit does not run "Hot".
With 3 others at another location, they only allow 3 devices to connect and will disconnect any devices previously connected. These 3 are supplied PoE from Dell PowerConnect Gigabit Switches (also used to supply power to the VoIP and PoE Security Camera's), and also run Hot at the Data/PoE ports. We have not tried power injectors at this site.
I've tried to find any indication of how to adjust the PoE and Data Port settings to resolve this, but cannot find anything, and this appears to be a unique issue, as noone I have contacted has ever experianced it.
- Mike
Mar 28, 2011 | HP ProCurve MSM410 (J9426A) Pre-802.11n...
2005 ducati monster 620 will turn over but not start
Hi, Corydurham50 and the usual suspects are:
1. Fuel tank empty.
http://www.ducatimonster.org/forums/tech/209511-monster-620-dark-turns-over-long-time-but-wont-start.html
Ducati Maintenance
Dec 25, 2010 | 2005 Ducati Monster 620
Failed to connect to no response from ap...what is
What worked for me was to go into SETTINGS then NETWORK SETTINGS select CONNECTIONS then click your routers name then scroll down to NETWORK KEY type in your password and then SAVE then try connecting! hope it helps!
Nov 26, 2009 | Cell Phones
Connect belkin f5d7130 to homehub 1.5
You need to connect all pc's and homehub to a switch so they can talk to one another. Then use the AP as a wireless access point to connect all wireless laptops, and connect the AP to the switch with ethernet cable, and you have a network. Just make sure that only your HH or AP supplies IP addresses or they will clash.
Oct 19, 2009 | Belkin Wireless (F5D7130) 802.11g/b...
No internet linksys connected to catalyst 2900 XL
check the vlan settings of the port on the switch to where the AP is connected, and check the vlan of the AP
Sep 13, 2009 | Cisco Catalyst 2908 (WS-C2908-XL)...
I lost the manual to the canon MP 620 printer and i would like to connect the printer to my new Mac I have connected them with the USB cable I have tolled the Mac to go connect to the canon MP 620 and...
I am sure there is one to download but did not found anything with google...
If search engines are no help, just ask some deep web specialists, e.g. http://manualfox.com - I found it on their website.
Aug 31, 2009 | Canon PIXMA MP620 All-In-One InkJet...
How do i connect so my computer is wireless
Check out this MicroSoft article that outlines the four steps to connecting wireless. They have the steps broken down very well!
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Jul 10, 2009 | Belkin (F5D9230-4) Wireless Router...
DLINK DWL-2100AP
check whether DHCP is enable on ur main AP.
Apr 21, 2009 | Computers & Internet
Enterasys Networks TRAPEZE DUAL BAND OUTDOOR AP (TRPZ-MP-620) (TRPZMP620) Logo
76 people viewed this question
Top Enterasys Computers & Internet Experts
George Nalley
Level 1 Expert
Marcin
Jax Planet
Jax Planet
Are you an Enterasys Computer and Internet Expert? Answer questions, earn points and help others
