Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
I need to replace vacuum hose
I have a hole close to the electrical end (closest to the vacuum) and need to remove the protective plactic piece. How do I do this without damaging the casing? Is it just a matter of shortening the hose and rewiring once the casing has been removed?
  • Anonymous Mar 27, 2014
    Miele S312i vacuum hose-end removal. Have blockage in hose. End pieces are curved and prevent a stick being poked down hose to get blockage out. How to remove them?
    President:
  • 1,673 Answers
If you have a vise, put the end in to and you want to just squeeze it so you can get to the 2 tabs inside and using 2 flat blade screwdrivers, pry outward and the hose should come out of the cuff. Sometimes you can just cut and rewire, but watch and match colored wires to the right colors, mix them up and you would have a electrical mess. When you put it back together, push the cuff down until you hear it snap into place.
Posted on Mar 25, 2008
Dyson hose is broken how do I replace it
The colored pieces on the vacuum are latches. You can remove most parts. For the hose, you may have to remove the cannister to get to the latch through a hole in the main upright part of the vacuum. You can find parts with a search of the Internet. You will have to get the hose with both ends attached, but one source has it for $21.95.
Oct 20, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a Hoover windtunnel T series. Model #UH70105. The system check indicator was almost red so I cleaned the filter. There are no clogs and it vacuums fine without the hose, but when I go to use the...
You likely have a hole in the hose causing a loss of suction/vacuum in the system. Mine cracked right around the bottom nozzle. There are no electrical wires in it, so I just taped it up with black electrical tape and it worked like new for many more years.
Sep 28, 2017 | Hoover Vacuums
Was using vacuum and sock is now lodged in vacuum hose. How can I get the sock out?
The easiest way to remove an article of clothing from the hose is to remove one end of the hose from the vacuum, and reach in with a piece of wire with the end bent into a hook. A wire coathanger will work well for this. Just straighten out the coathanger, take a pair of pliers, and put a small bend at the end of the wire, in a J, or hook shape. Then, reach the wire into the hose, and when you feel the obstruction, twist the wire, so that the hook gets stuck on the sock. Then, pull it out, and reattatch the end of the hose back on the vacuum.
It doesn't matter which end of the hose you remove, just whichever is easier, and hopefully closest to the clog.
Do not try to push it out, as it will just bunch up tighter. It must be pulled out.
Jun 17, 2011 | Kenmore 31913 Progressive Direct Drive...
Just bought new power head electrolux guardian and
Did you get new wands with the power nozzel? The wires that power the nozzel run through the wands from the hose to the nozzel.The connectors at the end of the wires are fomous for getting too big and making a bad connection. This causes the on/off problem. This will only get worse if you continued use. The wires in the hose handle, the hose and the power nozzel elbow can all be changed out. You will not have to replace the hose handle or the wands unless the plactic has been burned. (A loose electrical connection causes heat). Take your hose,wands and nozzel to the shop for repair. Don't let the sales/service manager tell you that you need new parts until you can see the parts are bad. I think they saw you comming when they sold you the new nozzel.(just my opinion)
Oct 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
My dyson dc07 is does not have the suction it used to. what should I do?
There are a couple of things you can do and it depends on whether you don't have suction from both the wand and the bottom of the
machine or just from one side:
1) First check the suction of the machine to ensure that the motor is still good - remove the canister and look for the two
openings/holes on the spine/frame of the machine - put your hand in front of the hole on the LEFT (higher than the hole on the right)
- if there is suction, continue the troubleshoot instructions, if there is no suction your motor may be damaged - call the Dyson
Helpline, they'll set you up with a repair with the closest authorized dealer in your area.
2) Check for blockages from the bottom of the machine. Remove the:
(i) U-Bend (stand behind the machine and look next to the right-hand-side wheel, it's attached with a rectangular clip next to the
long gray hose - push the clip and pull the U-Bend off, make sure its clear - if there's a blockage remove it and continue with the
blockage check to ensure that the entire machine is clear)
(ii) AI Valve (stand behind the machine and look above the right-hand side wheel, it's attached with two buttons on either side of the
AI Pipe/Valve - push the two buttons and pull the pipe up and off and make sure there is clear - if there's a blockage remove it and
continue with the blockage check to ensure that the entire machine is clear)
(iii) Refit the internal hose on the bottom of the machine between the wheels and make sure it isn't torn and has no holes in it and
that there is nothing clogged inside it - to refit the hose: Pull it off where it sits next to the wheel first - make sure that the
gray piece of rubber is still on the hose (if it isn't, pull the gray piece of rubber off the hole and reconnect it to the hose by
twisting it back on) - next, twist the hose off where it connects to the brushbar - inspect the hose and make sure you don't have any
holes in it - put it back on by twisting it onto the side of the brushbar first - then line the gray piece of plastic end up with the
hole next to the wheel and push and twist it back over the hole. Bring the machine back upright and test it
3) Check for blockages in the wand. Remove the:
(ii) Wand - take the wand off the back of the machine - put one hand on the wand handle and one hand on the gray hose - pull the
handle and push the gray hose down, you'll see a metal rod being exposed, push the hose until it clicks into place - press the
half-moon shape button with a picture of a lock on it (found on the solid gray plastic end of the flexible hose) and separate the wand
competely - point the wand into the air or at a source of light (please don't point it at the sun) and look through the metal rod part
- the handle is bent but you should still see some light coming through the other end - if you don't, there is a blockage in the wand
- use a long object like a stick or a metal hanger to remove the blockage
(iii) Hose - no need to remove it - just stretch it out and make sure that there are no dark spots in the hose (those would be
blockages) - you can also through the top of the hose - if you don't see the ground at the bottom there is a blockage in the hose
4) If no blockages are found on the machine at all:
(i) wash the filter in cold water and leave it out to dry for at least 24 hours
(ii) blow out the cyclone from the bottom (open the door on the bin door - you can now look into the cyclone) - blow it out with an
air compressor or a leaf blower
(iii) Wipe all the small holes off on the cyclone with a dryer sheet
When the filter is dry, test the suction again. If there still is no suction on the machine, call the Dyson Helpline, they'll set you
Jul 03, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
The hose is disconnected, new bag in unit, new filter, unit runs when hose is detached but immediately turns off when hose is attached but hose has no obstruction, etc.. i was told i need some sort of...
There is a vacuum hose that attaches inside the unit to a round clear plactic piece. In most cases you can simply cut the small vacuum hose and it will fix the problem.
Apr 16, 2009 | Electrolux Epic 3500 Vacuum
Is there any way to patch a small hole in the lower hose of my hoover windtunnel bagless? I think my rabbit nibbled on one of the ridges.
Usually any kind of strong adhesive tape will do like electrical tape or carpet tape. A small piece should do it fine but if you can try and put a piece inside the tube so that the hole is sticky on the outside of the hose. Then put another piece over the hole on the outside to seal it. Its a tricky operation but if you are patient easy enough to do but needs very close attention. Also make sure that the tape is sealed across a flat part of the hose, not across metal ridges as when the hose is stretched the ridge part that usually has a metal coil inside will stretch and is no good for any hose if a hole has been made against the metal part.
Apr 01, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Vacuum is losing suction
Feb 21, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka Capture Vacuum
Either the filters are clogged, the hose has a clog in it, or the dirt inlet down by the brush roll is clogged. Pull the hose off and see if you have suction at the end of the hose, that will tell you which way to look for a clog.
Feb 18, 2008 | Eureka Capture Upright Vacuum Vacuum
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
95 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
