Question about Onkyo TX-NR905 Receiver
Tx-nr905 internet radio problem
Morning,
i have a tx-nr905 that i haven't been able to connect to internet radio. took it in for service and tech said it works. my home network is behind a linksys firewall. any troubleshooting tips would be welcome
thanks,
dssax
2 Suggested Answers
  • 103 Answers
SOURCE: I have an Onkyo AV receiver model TX-NR509 and the internet radio stopped working. I have a good internet connection. How do I fix this?
I see on Onkyo's website that the iMerge service was discontinued in late 2008, Stating that:
"the selection of Internet Radio stations available through Net-Tune will decrease and eventually will cease."
You may want get on the Onkyo website and see what services are available for that receiver.
Posted on Dec 07, 2014
Receives,no Tx
Many possibilities:
1: The radio took a hit and broke the PCB or the connection to the RF out jack.
2: Some other PCB joint failure
3: The RF output IC is toast
4: The driver is toast
5: The tx oscillator is so far out of whack it cannot develop the frequency it is set to.
6: You have a bad cable or antenna connector
7: You have a bad battery, battery contact or power connection
8: You have a power supply or other problem
Sep 26, 2015 | Icom IC-T7H VHF/UHF Handheld Dual Band...
Dec 07, 2014 | Onkyo TX-NR509
Onkyo tx-sr803
Try assigning the HDMI that you changed. in other words where ever you had that RCA assigned to, change that assignment to HDMI
Aug 28, 2017 | Onkyo TX-NR905 Receiver
My tx-nr905 recievers output audio goes out when connected to my projector and a dvd player, but its ok with any other output combo; proj/sat or tv/dvd or tv/sat etc..... bought new about 4 yrs ago, has...
Semantics maybe, but sources are INputs. OUTputs are speakers, audio to other devices.
A DVD is always an INPUT.
So what's different? IOW, how are the DVD and Projector (Really? It uses a video OUTput) connected for audio? Have you looked at the manuals? Digital sources must be assigned, for example.
Aug 25, 2011 | Onkyo TX-NR905 Receiver
No sound from front channels under all sound modes. All wiring looks to be in tact.
Check to see if the speakers "A" are selected.
Look in the upper left corner of the display screen for something that says a or b. Let me know what it says.
See the manual here @ page 11 box 3 for more info.
http://www.intl.onkyo.com/downloads/manuals/pdf/tx-nr905_manual_e.pdf
Nov 22, 2009 | Onkyo TX-NR905 Receiver
HT-1000 has low Tx audio and programmed PL doesn't
While there are some adjustments which can be made in the RSS, doing so would not necessarily solve your problem, as it may create another. These setting would require the radio to be adjusted by a service tech using a service monitor. Your PL problem may simply be a programming issue. Double check the PL setting in the radio, also check to see if it is to be inverted or standard PL. If your radio is Transmitting low to other units, you could also be mixing narrowband and wideband radios. If so, one will talk softly to the other, while the opposing radio will be very loud talking back (among other things). And one other simple thing to check when having Tx issues is the antenna. Be certain you are using the correct antenna, the antenna is free of dry cracks or damage; and the antenna is attached properly.
After checking all the above, if you do not solve the problem, contact your local dealer or service center.
Best regards.
Sep 19, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Receiver will not recognize a 5.1 input
Have you selected the digital input through the audio setup? You can assign different digital inputs to various video inputs and this may solve the issue
Jan 17, 2009 | Onkyo TX-NR905 Receiver
Low Volume regardless of input
Front L/R and Surr back L/R are the termianls used for BI-amping
Check page 27 of the manaul
http://www.onkyousa.com/download/own_manuals.cfm?cat=Receiver
you can find it here
Dec 24, 2008 | Onkyo TX-NR905 Receiver
Onkyo TX-NR905 Protection Circuit Activated
The problem is not with the inputs. This unit is in protect because a problem has been detected in the output section. Try disconnecting the speaker wires and turning it on. If the unit remains on, there is a short in one of the speaker wires. If the unit still shuts down, there is an internal problem that will require repair. It sounds like this is a new piece. If so, it should be covered under warranty.
Keep us posted,
Dan
Jul 28, 2008 | Onkyo TX-NR905 Receiver
Wrong valtage
I am not sure what your question is but if you purchased the U.S. version and it is 110V and you are somewhere where there are 220V, you will need to purchase a stepdown transformer for it to work properly.
Apr 20, 2008 | Onkyo TX-NR905 Receiver
Onkyo TX-NR905 Receiver Logo
200 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
