Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Tablet salt I have a water softener installed - can I use the same water softener salt tablets in my dishwasher?
  • Anonymous Mar 25, 2014
    plugged venturi
    New Friend:
    Problem Solver:
  • 12 Answers
No, you can't do experiments without prior consultation with a technician cause that will hurt your water softener and you can even lose it from working normally.
Posted on Dec 22, 2014
  • 869 Answers
No unless you can find that tests were made and confirm that it is safe .
Posted on May 23, 2008
SOURCE:
Do you need to put salt in the dishwasher. If using tablets detergent ...where to put it ?
A lot of dishwashers do not have salt dispensers. If it does, the salt is added to a container which has a lid on the base (floor) on the inside under the bottom basket. Unscrew the lid and add the salt. Use normal pool salt. It is the same as "special dishwasher salt" that you pay a lot for. When full, the salt will last for 12 to 18 months. Most machines that have a salt container, also have a warning light on the panel to let you know it needs refilling. Dishwasher tablets do not add salt to the machine. Make sure you wipe up any salt that you may have spilt on the base of the machine, it will stain or rust the cabinet.
Sep 25, 2014 | Dishwashers
Built in water softener
really don't know have you got the manual. Normally you have to test the water ph level and then adjust the dish washer to that ph level and then fill the salt reservoir. Not sure on your model of dish washer . However you could add a water softener to the water inlet to the dish washer . Just search for
Water softener device
see
http://www.uvguard.com/hwc-home-series/
Oct 29, 2017 | Magic Chef CDB6100 Built-in Dishwasher
Waterside water softener model MC250 Dear Sir, Salt level did not go down during regeneration. I poured 2 pints of warm water to break solidified tablet salt, I found moist salt, but very little water in...
the salt in use should water softener salt and nothing else
there is water added to the salt crystals up to the overflow hole
during regeneration that salty water (Brime) is drawn into the unit and upon finishing the process that reserve is refilled for the next time
there is little salt actually used during the regeneration process ( around 4 regenerations to a 25 kg bad )
Apr 13, 2017 | Dishwashers
My new dishwasher leaves a white residue on my pots. pans and stainless flatware. I have not changed soap. Could the water not be hot enough?
Check the incoming water quality. If water is hard and having calcium content this could happen. Use water softeners in the inlet water to the machine.
If dish washer salt compartment available fill with the special salt meant for dish washers.
Check rinse aid compartment and fill rinse aid. Or use two in one soap tablet.
Sep 19, 2010 | Whirlpool Dishwashers
My Dishwasher leaves a white film on dishes.
check inlet water quality. If more calcium deposits in the water this could happen. Try using water water softeners.
If provision for dish washer salt check and add salt. ( not kitchen salt )
Finally check whether rinse aid compartment is filled with the liquid. If you are tablet, extra rinse aid not needed. Try all the above.
Aug 17, 2010 | Whirlpool Dishwashers
What kind of salt do I buy for use in the Danby DW?
Well Dishwasher salt is a particular grade of sodium chloride salt, and is used for recharging the built-in ion-exchange resins of the water softener in dishwashers that have a built-in water softener. The salt particles are larger than the size of table salt particles, and dissolves slowly enough that it will not clog the softener unit. This salt does not have added iodide salts, and it should have minimal amounts of iron and manganese salts. Some dishwasher detergents are marketed as not needing dishwasher salts. These detergents use higher levels of phosphate that increases the solubility of hard water ions. Never use table salt or detergent in the salt compartment of your dishwasher as this will damage your water softener unit. You can purchase the dishwasher salt from the below link -
http://www.mysupermarket.co.uk/grocery-categories/Dishwasher_Salt_In_Tesco.html
Good Luck!!
Thanks
Jan 07, 2010 | Danby 17 in. DDW1802W Designer Series...
Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Feb 22, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Salt for DDW1805 Danby
I use ordinary household water softener salt crystals, not pellets, or table salt. The table salt often is not as refined as softener crystals, and can damage the dishwasher's softener in time. Also, the water softener salt comes in a large bag (around 25-50 lbs) for about $6 US.
Jul 12, 2008 | Danby DDW1805W Designer Series...
Miele dishwasher film and crust on the inside-
Hard water has this "crust" which are minerals floating around that ionically attach to everything. Some machines from Miele have a water softener inside the machine. Special dishwasher softener Salt is added that cleans minerals off Xeolite beads. When cleaned they attract mineral ions. If you don't use the salt then the beads fill up on minerals until they can't hold any more minerals. The salt is used in the regeneration cycle. It washes the mineral ions off the xeloite replacing them with salt ions. As new water enters the machine mineral ions slowly knock off the salt ions and attach themselves to the beads again. This whole process keeps the crust off the dishes and the walls of the machine.
Use a dishwasher cleaner that removes scale. And if you don't have a salt light on your Miele you can instead purchase soap tablets that contain water softener built in. Miele dishwasher tablets have it. You can order them online or call Miele.
Dec 17, 2007 | Miele 23 in. Novotronic G841 Built-In...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
142 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
