Question about Koss KE29A Isolating Earbud (Aqua) Headphones
High. My earphones don't have any sound at all.. What do I do? The cable seams to be fine.
    President:
  • 1,469 Answers
Hi, what makes the earpiece not working, is that the wire inside the speaker area where you put inside the ear is faulty.
Loose the head of that small speaker, you will see the wire that has removed, use a soldering iron and a lead to fix it back.After fixing back, you can start using it again.
have a nice day.
Posted on Apr 29, 2010
No drum sound
check the wires, any leackages may led this, please install new cables.
Apr 13, 2014 | Yamaha Ms40dr Electronic Drum Monitor
Earphone jack on my compaq presario c700 stopped working. How do I fix it?
You will need professional help on this, the laptop must be dismantled down to the motherboard level to access the problem. The earphone jack may have to be replaced and requires a high degree of solder skills to remedy the situation.
Apr 03, 2012 | Compaq Presario Computers & Internet
I have a new windows 7 laptop that I am trying to use my old yamaha MS55D speakers with, but it says there are no drivers. Please can you suggest where I might get the driver or what else I can try
PROBLEM SOLVED: YAMAHA YST-MS55D allows both USB and audio jack. On the back of your subwoof - find the USB ONLY area. Disconnect the USB cable from your sub and computer. Then use the other audio cable to link ur sub with the audio jack on your computer (the earphone plug). You don't need to change the other connections. Your Speaker will then function like an earphone, which means no drivers needed as it is not a USB device anymore.
May 16, 2011 | Yamaha YST-MS55D Computer Speakers
JVC HA-S700 Cable Problem
You might want to check out my tip on dealing with dodgy plugs/cable on headphones.
Jul 08, 2010 | JVC HAS700 Headphones
New Bounty Hunter Discovery 3300 Metal Detector No external sound
Most earphone jacks have two functions. One, to provide signal to a set of earphones or headphones. Two, to DISCONNECT the path that would be amplified and sent to loudspeakers. If that particular contact on the jack is bent or broken, when you UNPLUG the male jack, the connection is NOT re-established!
Apr 22, 2017 | Bounty Hunter Land Star Metal Detector
Sound from 1 side only!
your ear input female jack is stripped try another new pair of earphones if not you may have to take it in for service.
Nov 05, 2009 | SanDisk Sansa E280 MP3 Player
Scratching sound from earphones at high volumes
Sounds like the beginnings of a rubbing voice coil in your MX160. Verify this by trying another set of headphones on your amplifier/MP3 player/etc. If the "scratching" sound disappears then your music source is not the fault. PLEASE REMEMBER...never turn music source volumes up past 60-65% (think of 1:00-1:30 on a clock face). If these setting are not loud enough, use a booster or move up to a unit with more audio output power. On a larger scale...How did I blow my 100 watt speakers with a 50 watt amp? It's easy....clip (overdrive) your amp....Glen
Apr 04, 2009 | Sennheiser Audio Players & Recorders
I plug in the earphones and i cant get half of the music or sound
Your problem sounds like the male end of the earphones is not making a complete with the mp4 player. Make sure the connection is tight
Jan 10, 2009 | Audio Players & Recorders
Lost sound
So there's another icon at top of Today screen - a loudspeaker icon - tap on that and make sure it's not muted or all the way down.
Sep 14, 2005 | HP iPAQ RX3115 Pocket PC
Koss KE29A Isolating Earbud (Aqua) Headphones Logo
98 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steve K
Carlos L. Burgos
Carlos L. Burgos
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
