Question about Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX 4100 - Paper Tray Will Not Insert
The Samsung has been operating very well, but the paper tray will no longer fully insert (with or without paper in it).
It goes most of the way in, and then something on the left prevents it inserting further. At that point the paper is not fully depressed in the tray, but it is just possible to fully depress it with a finger and this does not remove the constraint.
David
  • Samsung Master
  • 19,396 Answers
Checkk that ther is no paper stuck inside
Posted on Mar 25, 2008
  • Ginko
    Ginko Mar 25, 2008
    Try first inserting the tray with no paper inside. the drawer guide has two lateral guides check tha they are free, check also the the tap pushing up the paper inside the try is not stuck and preventing the drawer from sliding in.
  • Ginko
    Ginko Mar 25, 2008
    For reference , here is the exploded view and part list for scx 4521, which is similar to yours.
SCX-4216 "No Paper" message
Check this link it has a step by step solution that you can try http://www.fixya.com/support/t216317-no_paper_error
Hope that helps..........
Aug 07, 2008 | Samsung SCX-4100 All-In-One Laser Printer
How do I insert a new toner cartridge to my Samsung SCX 4600 ? Ken Mallinson.
Hi
The toner cartridge door is located above the paper tray, Just pull it off and remove the toner cartridge.
Jan 13, 2011 | Samsung ML 2010 Laser Printer
How many pages per minute doe it print?
Black Print Speed:--------- 15 ppm***** Total Media Capacity:---- 250 Sheets****** Max Resolution (BW):---- 600 x 600 dpi*********
Being laser-based, the SCX-4100 is a more economical choice over bubble jet printer whose cartridges are expensive in comparison to their durability. But be mindful that the SCX-4100 is a black-and-white device – so no color printing/copying for you, although it obviously scans color documents. The toner cartridge is good for about 3,000 copies, a figure that can increase 40% with toner management software (included).
The device has a main paper tray that holds 250 sheets up to legal size. You can manually feed a sheet at time into a slot right above the front paper tray, and there’s also a rear slot for jam-prone material, like envelopes and transparencies. Unfortunately, the SCX-4100 lacks an automatic document feeder.
Thanks. you can rate this solution and show your appreciation.
May 18, 2010 | Samsung SCX-4100 All-In-One Laser Printer
I have a samsung SCX 4824 FN printer- message
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Jan 19, 2010 | Office Equipment & Supplies
PAPER TRAY NOT RELEASING
After puting paper in the tray you should press the start button. GOOD LUCK.
Nov 20, 2008 | Samsung SF-560 Plain Paper Laser Fax
Printer complains: Insert Paper fully into MPF
Pull the paper tray out and look for any obstructions in there.  Check for broken parts as well such a sensor.  Sometimes they get out of position as well.
Sep 17, 2008 | Dell 3100cn Laser Printer
Printer displays 'No paper - Add paper'
That is if the lens present in your printer ( above the paper Tray) must have filled with dust. just clean the lens and try it out.
Aug 11, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Printing legal documents
Absolutely. Just click on the "PROPERTIES" button found on the "PRINT"menu. Find the "PAPER SOURCE" option, open it and select "Manual Paper Tray" or "Manual MPT". As soon as you confirm your print job, you unit will display a message asking for paper on the manual tray, which is the horizontal slot just above the paper tray. Insert each legal paper manually until your print job is done.
Oct 30, 2007 | Samsung SCX-4016 Laser Printer
No paper error
Your unit has a bad paper sensor. It can give you one of two incorrect messages: (1) no paper when it actually has or (2) no paper on the unit but no error message. Genuine Service Centers can show you actual schematics and Samsung's Service Page on the Internet. Or better yet, visit www.samsung.com and find an authorized center through the SUPPORT link.
Sep 19, 2006 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
89 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
