Question about Dell 160 GB 7200 RPM SATA Internal for Vostro 1500 Laptop (XX225) Hard Drive
Hard drive when my computer boots up it says that theres no hard drive located do i need a new one or can i do anything to the i have
Vostro 1500 every time i reseat the hard drive it works then i turn off the computer and turn it back on it gone again and im ask to reseat again and again
Posted on Sep 01, 2010
  • 46 Answers
YOU NEED TO DOWNLOAD ALL THE DRIVERS AGAIN
Posted on Oct 04, 2012
  • 3,940 Answers
First thing you can do is reseat the hard drive, sometimes they just loose contact.
If you reseat the drive and the drive is not detected and identified in the BIOS, then buy a replacement
Posted on Apr 29, 2010
4 Suggested Answers
SOURCE: I accidently formated my external
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also download driver for your harddrive from below link then install. Click here
Let me know if you need further assistance. Thanks for using FixYa
Posted on Nov 07, 2010
pgh_pa_guy
  • 2992 Answers
SOURCE: i broke the screen on
On most laptops it's pretty easy to remove the hard drive. Usually there's an access door on the bottom, while some others make you remove the keyboard. Once the drive is out, the easiest thing to do is hook the drive to a USB drive adapter. Then you can simply plug into a USB port on the new computer and access the data on the drive. Here's a typical adapter from one vendor so you'll know what you're looking for.
Posted on Sep 14, 2011
ViscamTech
  • 528 Answers
SOURCE: My computer freezes without reason.I have to turn
Yes you can.
Unfortunately you haven't given your OS. I'll answer assuming it to be Windows XP.
Click Start button and click 'Run'. Type 'cmd' and press Enter key. A 'DOS window' will appear.
In this DOS window, type CHKDSK C: /F
This command will check the Hard Disk and try to repair errors found.
Try this and let us know the result.
Good luck!, and thanks for using FixYa!
Posted on Sep 28, 2011
I have an Asus Eee pc R101D netbook, Cant get it to fully boot up, operating system is Windows 7 Starter, I have no Re-installation Disc, Also cant get my external Disc drive to work from the USB slot, I...
your operating system is located on the hard drive if you still have the old one and it works put it back in make a back up copy on cd remove and reinstall new on and load operating system to new hard drive.
Mar 11, 2015 | ASUS Computers & Internet
My computer keeps saying "The last attempt to restart the system from its previous location failed. Attempt to restart again?"
When you boot up, try pressing the delete key to see if that will take you to the bios setup screen. See if the computer recognizes your hard drive, and make sure that it is in the boot sequence. If your hard drive isn't there, it's fried and you have to buy a new one. Next, put your windows disk in your hard drive and see if you can boot from there. There is an option to repair windows if your hard drive is ok. Worst comes to worst, try reinstalling windows. You will loose all your data, but might get the computer back. It's a good idea to keep all important data backed up on a usb drive.
Sep 30, 2013 | ViewSonic E771 17" CRT Monitor
Acer Aspire one 722 windows 7 netbook. "Check cable connection" and "no bootable device--insert boot disk and press any key" are two common things appearing. The computer recognized hardrive, hardr
Hello, it looks like somehow the master boot record was erased from the hard drive, maybe viral? You mentioned the hard drive was recognized in the bios correct? If you need data from the hard drive the easiest way would be to pull the hard drive out and use an external hard drive enclosure to remove the data before you erase everything from the hard drive. If you dont need anything thing you can proceed to do a new install of Windows 7. Turn the computer on then hold alt and the f10 key to perform a factory recovery. This will erase everything and reinstall Windows 7. If this doesnt work then you will need a new hard drive and a bootable usb drive with Windows 7 on it. Hope this helps.
Feb 22, 2013 | Computers & Internet
Can I use the Hitachi Deskstar P7K500 HDP725025GLAT80 - 0A35390-20PK 250 GB Hard Drive as a secondary hard drive if I dont have the boot disk for it? If so, how do I go about setting it up? I'v tried...
You actually don't need a boot disk for this particular problem. What the computer is telling you with that particular error message is that it is not detecting any kind of operating system on the hard drive it is trying to start from.
If you installed this alongside your current hard drive, it's likely that the boot order is incorrect in the BIOS, and it's trying to load from the blank Hitachi hard drive. Here are the steps to figure it out:
1) Restart the computer.
2) As soon as you do, start pressing the F1, F2 and Del keys repeatedly until the lights on the keyboard flash. (If this doesn't work, there should be a message on the screen that says something like F12 - Menu or something, and you should press that key instead. In 90% of cases it will be either F1, F2 or Del.) This should bring you into a blue text-like screen. This is the computer's BIOS. You will not be able to navigate with the mouse.
3) Using the arrow keys, look through the menus for a Boot Devices, Boot Options or Boot Device Order menu. The location and name of this menu will vary widely based on your computer's motherboard.
4) Once you have located the Boot Options menu, there should be a list of devices. Follow the on-screen instructions to order them as follows: #1 CD/DVD drive, #2 Your regular hard drive, #3 Hitachi Deskstar. Anything else can just go below that if there are more than 3 options.
5) Navigate to the Save and Exit option in the BIOS screen and tell it that you want to save changes, if prompted.
The computer should now restart and access your normal hard drive to boot your computer's operating system, with the Hitachi as a secondary drive. Once you get into the OS, you will need to partition and format the hard drive in order to use the space.
Hope this is helpful!
May 09, 2011 | Hitachi Deskstar P7K500 HDP725025GLAT80 -...
I bought a Hitachi z5k320 hard drive trying to install it, and windows, but my computer won't recognize hard drive. how can i get it to recognize the new drive. can't do anything until that happens.
As long as you are sure the hard drive is connected properly with SATA cables to the motherboard and has power from the power supply unit, and that the drive is working, you can enter the BIOS on computer startup and modify the "boot device" look in "primary boot device" for a name matching that of your hard drive (probably "HITACHI .....) If it is there select it as the primary device and hopefully it will boot and ask you to install windows. If it is not there the drive may not be connected or it may need to be replaced. Hope this helps!
Mar 15, 2011 | Hitachi 160GB Travelstar Z5K320 SATA 3Gbs...
Cannot boot from Momentus Ultra ATA 160 GN HDD
it can only clone the windows files and folders there is other files located on a hidden system on the hard drive, when you install and new hard drive these file are fixed to the drive. to make a bootable drive you need to install these files from a windows disc then add clone files over the top so these files don't get deleted.
May 27, 2017 | Seagate Momentus 5400.3 Hard Drive
Toshiba Qosmio laptop with Phoenix securecore util,uses SATA drive. Had to replace the Hard drive, HDD1 password issue After installing the new HD and at boot up, blue screen occurs I get errors F78da640,...
You've probably got to have your computer configured to boot from a rescue CD before it can recognize and install the new harddrive. Also make sure that there is an operating system installed on the hard drive . If not it will not do anything until you install one. This will be automatic if you install a new XP or Vista DVD into the computer's DVD drive the reboot.
Sep 07, 2009 | Toshiba Satellite A135-S4527 Notebook
Boot up error
You may have to open your computer and locate the hard drive. Trace the cable to see where it plugs into the motherboard. If there are other slots that it will plug into the motherboard, try plugging the hard drive into those.
If you have SATA plugins, it will be relatively easy to find a new port to plug it into. If you have IDE plugins, you may want to skip my solution and try other things first.
Apr 16, 2009 | Computers & Internet
How to use Sandisk 4mb Flash drive
1. open my computer
2. open another my computer window
3. now use the first my computer window and go into the first hard drive and find the file
4. ones you have found the file Right click on the file and select copy.
5. now use the 2nd my computer window we opened and go into the other.
6. ones you are there right click on the empty space there and select paste
the file will be duplicated to the new location so you will have two files, one file in the original location and a copy on the other location.
Let me know if you need anything else.
Thanks,
Ekse
Feb 09, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Dell 160 GB 7200 RPM SATA Internal for Vostro 1500 Laptop (XX225) Hard Drive Logo
191 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
