Blinking power light
My son kept turning the power button on and off ....Now it blinks and the tv won't power up..What is wrong
  • teagues Jun 17, 2008
    we turn it on and the green on and off light just blinks on and off but the tv does not come on we hear the fan but no picture, we had moved it to another location when this started. the lamp looks good and is not too old. what do you think could cause this? how do I tell if the lamp has gone bad or could it be another problem.
    Problem Solver:
  • 18 Answers
Generally, projectors will not power up again until a set amount of time to allow the bulb to sufficiently cool. My Optoma cannot be restarted until a 2 minute cool-down period.
Jim
Posted on Mar 24, 2008
I am having the same problem and it is bigger than you think. You have up to 4 burned out fuses on your power supply (850, 851, 852 and possibly 860 but mine is fine). Not normal fuses either they are 125 watt 5 and 2 amp micro fuses located on the top middle of your power supply. Kind of a bother to fix I am working on mine now. you should also resolder all of the staples (at least 010 and 050), which are the small metal rods that go across the circut card in place of a component. Go here for more info.
tacpservice.toshiba.com/TACP/subpages/pdfs/TechBulletins_TV2002.pdf and
http://forum.eserviceinfo.com/viewtopic.php?p=72332
Posted on May 05, 2008
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
Power button won't turn tv on. light keeps blinking on and off
Main board to your TV is faulty. Check the chroma and video processing section. In most cases, it will be due to an IC fault.
Jul 23, 2012 | Curtis-Mathis Televison & Video
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Sony WEGA Trinitron SRS BBE 32'
Please reply couple of questions about TV to guess what could be wrong.
1- How many times standby light blinks, there would be interval of 3 seconds in blinks so count pause to pause.
2- Please intimate exact model of TV, written on sticker pasted at back of TV. That will help me to check its schematics.
Hit " add a comment" button to reply.
Thanks.
May 03, 2009 | Sony FD Trinitron WEGA KV-29LS35 29" TV
I have a 36" TV that won't work - Red LED light blinks 5 times
The 5 blinks indicates a White Balance Failure. This involves checking voltages and components tied directly to the CRT. I would not suggest any attempt for self repair. The cost for this repair should not be significant. Figure a parts cost in the $30-$50 range at worst.
Dan
Mar 06, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
depend on how U use it and how long is recommended that after 4 hour es of use turn it of 5 to 10 minutes to let the lamp cool off no some laps use are between 7 to 9 thousand hour
Apr 03, 2008 | Toshiba 50H72 50" Rear Projection...
TV Problem
the red blinking light is a code that tells you what is wrong it will blink from 1 to 10 or just blinks all the time
Jan 03, 2008 | Sony KV-32S26 32" TV
Televison & Video Logo
181 people viewed this question
Top Televison & Video Experts
