Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
1 push rod is steel & 1 is alum, which one is exaust?
20 hp B&S intek 1 cyllinder. 1 push rod is steel & 1 is alum, which one is exaust?
    Scholar:
  • 38 Answers
The intake valve is the lower valve and its push rod is the aluminum one, the exhaust is the upper valve and it has the steel rod, there is no rocket science going on here, the aluminum push rod is used to cut costs.
Posted on Jun 04, 2010
The aluminum valve on the intake is to prevent valve lag not to cut cost.
Posted on Jun 10, 2010
  • 2,100 Answers
They should be different sizes. I don't think it is aluminum, or steel, it is some kind of weird alloy that can't be burned. If you used a magnet to test the valves, the magnetic one would be the intake. But not always the case. The science behind it is mind boggling. Check out this website, hope this helps.
http://www.enginebuildermag.com/Article/1171/valve_selection_hot_valve_materials_for_hot_engines.aspx
Posted on Apr 29, 2010
  • cinealfa Aug 02, 2014
    you referring to the valves not the pushrods. The pushrods are the same size but different materials.
  • 31 Answers
The push rods are the same size. The exhaust spring is much stronger and therefore requires the steel push rod.
My question is, would it hurt anything to use a steel rod for each side.
the steel rod weighs .13 and the aluminum one .05, so roughly 2.5 times the weight, but that shouldn't matter should it. I just don't want to have to replace the aluminum one again if I can keep from it.
Posted on Aug 17, 2010
  • Barry Van
    Barry Van Oct 10, 2016
    what is the answer? I have the same thought
    New Friend:
Exhaust valve push rods are aluminum.
From the Briggs repair manual
Posted on Aug 11, 2016
  • Deane Crabbe
    Deane Crabbe Aug 11, 2016
    Thats for the vanguard vtwin, there not always the same
  • Anonymous Oct 10, 2016
    Can you use a steel pushrod for intake instead of aluminium . The aluminium wears very quickly
What are the torques on a 22hp ohv briggs and stratton head and also push rods
VERIFY your engine model numbers
Briggs & Stratton Intek V-Twin
Engine Model Numbers 407777 and 44P777
Cylinders 2 (Dual cylinder)
ITEM N m (Newton metres) lb-in Spark Plug Torque 20 180 Back Plate (to cylinder) 11 100 Blower Housing Screws 9 80 Breather Screws 6 55 Carburetor to Manifold 7 65 Cylinder Head Bolts 25 220 Cylinder Shield 7 65 Crankcase Cover 23 200 Engine Mounting Bolts 48 35 lb-ft Electric Clutch Mounting Bolt 75 55 lb-ft Exhaust Manifold 16 140 Fan Retainer Bolts 16 140 Flywheel Nut 203 150 lb-ft Armature Mounting Screws 3 25 Intake Manifold Bolts 9 80 Rocker Arm Adjustment Lock Nut 7 62 Rocker Support Screws 11.3 100 Valve Cover Cap Screws 11 100 Carburetor to Intake 7 65 Valve Clearance (Cold) 0.10-0.13 mm (0.004-0.005 in)
WARNING: Uneven tightening will warp the head. Tighten Cylinder Head Bolts down evenly by hand. Then using torque wrench tighten in sequence, in 9 N m (80 lb-in) increments to 25 N m (220 lb-in).
Intake valve push rods are aluminum.
Exhaust valve push rods are steel.
DO NOT interchange push rods.
Removal and Re-installation sequence for bolt removal and tightening.
Mar 21, 2015 | Garden
18.5 hp Briggs & Stratton putting in rocker arms back, one goes in to far?
turn the crank see if it rises back up you may have droped one of the guides that ride the cam because youll have to tear her back down
Nov 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Only getting oil in one side of valves ? 24 hp briggs, twin
clean all the passages i usually drain the oil and replace with diesel fuel run for 30 seconds drain and replace with oil sae30
Aug 31, 2012 | Briggs & Stratton Briggs Stratton Intek V...
How to remove piston on B&S 20 hp 4067770139E1
push out threw the top first unbolt rod and if you need to ask its best left to a pro
Jun 06, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have crafsman 48" riding mower with a 24 hp intek motor
Bent push rods are a function of the valve guide coming loose in the head. The valve binds and you end up with a bent pushrod. Fix: Replace head. $94.00
Jul 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Yz 125 exaust bolt size
This bolt is an M6 x 20mm. It also uses an alum flat washer but a steel one will do. Best wishes~!
May 06, 2009 | 2003 Yamaha YZ 125
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
10,197 people viewed this question
Top Parks Optical Garden Experts
colesmowers
Renee Knafel-Bullock
Roland W VanLue
Roland W VanLue
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
