Question about Sony Cyber-shot DSC-W55 Digital Camera
Lens isn't coming out.
The lens isn't coming out anymore. The motor is still trying however. On the main screen it just says to turn it off and then on.
    Genius:
  • 1,040 Answers
There is a mechanical displacement in your digi cam. May be due to shock or ****. Digi Cams are very delight, especially small ones. We have to handle it very carefully. Even a small **** can cause problem. Get it serviced as soon as to avoid any further problem.
Don't turn it on and off, it may lead to motor problem.
Please rate the answer if you find it useful.
Thanks for rating.......
Posted on Apr 29, 2010
Hi. my problem with my camera is that my niece play with it and she pushed the lens mechanism while the camera is on. now, the lens was stuck and doesn't comes out anymore. when i'm turning on
Force it out like it was forced in. Try to rotate the lens. Remember it has to be off. As soon as the lens is half way out, turn the camara on and the lens will go to its position. If not, while the lens is out turn it left or right until it's back to its position.
Good luck.
Aug 24, 2012 | Sony Cyber-shot DSC-W55 Digital Camera
When i try to turn my camera on it sounds like its going to turn on but it stops and gives me the message on the screen Lens error 111. then it shuts off. I've been messing with it and i can get it to...
Often times a lens error comes up when the lens extension/focus mechanism has been jammed. It may almost fully function, but then the gears run into a small spot where those tiny gears are jammed, broken, have debris on them, etc. When the motor hits unexpected resistance, the camera kicks back the lens error code and shuts down before it does further damage to itself. Make sure there isn't anything wedged between where the pieces of the lens slide past each other. Past that, the best solution I can offer is to look on ebay... most cameras either die because the lens mechanism breaks, or because the LCD screen breaks. If you can find a donor camera with a bad screen, you can combine the best of both at a pretty reasonable price. These cameras are quite complicated to transplant, but fortunately most lens mechanisms and sensors are a full unit of themselves, and so are the lcd screens. Before investing in the donor camera, take yours apart and see how difficult it appears to be to work on it. Then make your decision. Good luck!
Aug 13, 2011 | Cameras
My player won't load any DVDs; it keeps coming back with Error on the player and a bad disc message on the screen. I've turned it off to try and clear it, but that didn't help. Any ideas?
Hi zorak7824,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can
Mar 06, 2011 | Televison & Video
Wireless woun´t work
  • on the system tray near the system time on the lower right portion of the screen you can see there the single-screen pc
    • double cick it and and from there you can turn it off/on
May 01, 2009 | Computers & Internet
Lens error
Did you try replacing batteries.
will it turn on long enough to restore it?
if this is a new camera send it back it could be a software issue or mechanical breakage.
Also get a can of air and blow the lens off to ensure no debris is holding it back.
YOU CAN AT YOUR OWN RISK try to help the lens come out a bit by gently pulling it in case of a weak motor this can help but eventually it won't work anymore.i've heard tapping it where the usb cover is helps. try to gently tap it on a table as it is powering up.
read this it might be related:
http://www.e18error.com/repair.html
one of the things here might work to fix several problems other than error 18
Apr 23, 2009 | Canon Powershot SX110 IS Digital Camera...
No LCD display
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 21, 2008 | Pentax Optio S4 Digital Camera
My lens does not open or extend.
my camera is doing the same thing but i dropped it once and ever since it won't open anymore... it's definetely broken right? this sucks
Jun 15, 2008 | Canon PowerShot A520 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
154 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
