Question about Canon FAX-JX200
I need a user manual for a FAX-JX500 please paul
    Sergeant:
  • 166 Answers
I could not find your particular model. I did see a FAX-JX200 though. You should be able to find all manuals at:
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Posted on Apr 29, 2010
JX500 says "rec'd in memory" and "auto print
I can email you the user manual for future use. LBrown18062@hotmail.com Lawrence Brown
Printing All Unprinted Documents in Memory
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select .
4 Press [Start/Copy].
The fax prints the documents one at a time, after each the reception number is displayed on
the LCD.
5 After printing, the LCD displays .
6 Press [*] to delete the previous printed documents.
If you want to keep the documents in memory, press [#].
Sep 29, 2011 | Canon FAX-JX200
I need a copy of the Fax-JX500 Instruction Manual
http://printer1.blogspot.com/2009/05/canon-fax-jx500-users-guide.html
hope this helps.
Good luck
Nov 04, 2010 | Office Equipment & Supplies
My canonfax-jx500 wont fax it has5100 on the screen and i dont ma
The carriage did not move
up or down properly.
You need to remove covers, manually move the carriage in home position, manually rotate gears to put scanner in home position, clean gears, use wd40 to neutrallize grease, ink, dust on clutches and gears,...
or replace:
- PR lift shaft - Sheet feed unit
- Main Board ***'y
- Carriage lift sensor unit
Jul 01, 2010 | Canon FAX-JX200
Lost User's Guide of Canon Fax JX500. Anyone can help me?
my fax says autoprint off. how do i fix it??? have not been able to receive any faxes. thanks.
May 03, 2009 | Canon FAX-JX200
FAX JX500
Mary:
Given that the last question I responded to for you related to a Fax JX200 - and this to a JX500 - I am not certain which model you are actually asking about. The information that follows relates to the JX500. Further, if you need information in this regard on the prior post in order to feel that the previous response was a FixYa level response, please let me know. I responded based on the information you provided...
Based on the fact that you are getting a constant 5-ring situation, it appears that the machine is in TAM (tel-ans mach) mode. The purpose of 5 falls into remote recovery of messages - toll saver results in the phone answering after 2 rings if there are messages to retrieve, and 5 if there are not. This is done to prevent long-distance charges if there are no messages.
Two ways to accomplish an 8-9 ring objective. (1) Place the machine in manual mode, which means answering every call and sending faxes to the machine. Additionally, a "fail-safe" on this mode is that it will switch to TAM/automatically answer (if there is a recorded greeting message) after 15 rings - below. (2) The incoming ring - ring count - can be set (under Fax/Tel Auto) to ring 10 to 60 seconds before the fax picks up. (3) Alternatively, the Incoming Ring ring count can be set to have the fax ring 2 to 30 times, depending on the country specific parameters.
Re TAM: When the fax is set to <MANUAL MODE> and <MAN/AUTO SWITCH> has been set to <OFF>, TAM MODE will be activated if the fax rings 15 times and the call is not answered (only when an outgoing message has been recorded). When the call is disconnected, the fax returns to <MANUAL MODE>.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding your specific needs, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 04, 2008 | Canon FAX-JX200
Fax jx500 displaying rec'd in memory. have tried to print it but it says remove document when i do so. what do we do?
Does anyone know how to fix a check 600 on a Cannon JX500???...I have no idea & am finding it very frustrating...Thanks
Jul 21, 2008 | Office Equipment & Supplies
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Loading paper in fax machine
Relax ti mal- the rollers are not picking up the paper because they are dirty or worn out.
Try this clean the rollers with alcohol and try, are the rollers smooth or do they have a rough feel? if smooth replace and it should be good as new.
Good luck
Nov 29, 2007 | Philips PPF-575 Plain Paper Inkjet Fax
Canon FAX-JX200 Logo
419 people viewed this question
old marine
old marine
