Question about Neovo AG 17" LCD Monitor
The cable is broken and its changes colors - Neovo AG 17" LCD Monitor
  • 61 Answers
Replace cable.
Posted on Apr 30, 2010
How can i change cable in touch screen of sewing machine
if the touchscreen cable is broken or damaged, the only fix is to replace the touchscreen assembly with a new unit which includes a longer and more robust amber color cable . I suggest that this repair should only be done by an authorized Viking dealer.
Apr 20, 2014 | Husqvarna Designer I
T.v. problems
I suggest check the cables first. The color changes are almost always a faulty wire in the cable. Try working the cable back and forth near both connectors. If this causes the color change you could have a broken wore in the cable, or a loose pin in one of the connectors.
Jun 26, 2013 | Health & Beauty
Display cable of hp500 got damaged
If damaged it can get worse--consider the cost, age and value of this unit and MAYBE either live with it or go shopping for a new unit.
Jun 14, 2012 | HP Computers & Internet
Screen burry wih clors
remove the cable from the monitor and check whether you get the no connection display in the monitor if you get that connect the monitor to the computer and switch on the computer still if you have blue color in the monitor move the monitor cable up and down slowly and see whether the color changes if the color changes the problem is with the cable from the monitor
Apr 01, 2011 | Toshiba Computers & Internet
I have a multi-media monitor. The blue light is on but I can't get a blue screen. What do I do?
your monitors signal cable is broken shake the cable if there is change in color then change the signal cable
Feb 23, 2010 | Computers & Internet
My monitor is not showing red colors? how do i fix
There is a number of possible reasons why your monitor lost the red color. A good guess, however, is a broken cable or connector. Check the plug and socket of the cable for bend or broken pins. If everything looks OK, try to change for a different cable.
If the problem persists, a pin of the connector soldered to the PCB internally may be broken. This is an easy repair for a service technician but I really recommend you do not do it yourself.
Feb 05, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
Yellow display
vga- display cable is most likely broken, definitely if color changes when cable is moved or turned.
replace the cable between computer and display.
Jun 22, 2009 | Intel D845GVSR Motherboard
Not displaying full colors
I had a bad M1 to VGA cable. The blue video channel in the cable was broken.
Apr 22, 2009 | InFocus LP70+ Multimedia Projector
No color
does the tv use Svideo as an input from whatever device you're using on the main screen? if so , try changing out the cable for a new one, svideo carries 2 signals, color and brightness (ie color and black signals) if your cable is bad or broken, you may only be getting one of those signals ( the black one) try a new cable if it's s-video. if it's not, get back to us.
Sep 13, 2007 | Hitachi 50SBX78B 50" Rear Projection...
DOESN'T PLAY DVD MOVIES IN COLOR
ok they have 4 causes. 1.laser lens 2.flex ribbon wire 3.video drive 4.change motherboard. OR CHECK THE PALSECAM AND NTSC SELECTION ON YOUR REMOTE CONTROL. THAT IS FIRST IMPORTANT! CHECK YOUR SYSTEM (PAL or NTSC).
Dec 27, 2006 | Panasonic SC-HT920 System
Neovo AG 17" LCD Monitor Logo
37 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
