Question about Haier HSP03WNA Compact Refrigerator
The PTC on my Haier HSP03WNA has went bad I contacted Haier and they can only sell me the part if I buy a $300 compressor for my $100 fridge any suggestions? It is just a small plastic part that hooks onto the start and run connection on the compressor and has a single wire going to it the other wire hooks to the overload on the common terminal. I know that this is the bad part because I have 2 of these and removed the 1 from the good one and got this one running. But now I have 2 fridges and only one PTC. Thank you for your time. Kevin
    Sergeant:
  • 239 Answers
Go to parts store and buy RO41. its a univeral relay that will work.
Posted on May 08, 2017
  • 159 Answers
SOURCE: fridge won't quit running and get cold
2 common problems that unit has. 1 is the cold controls go bad and will cause the unit to either run or not run. 2 the freezer drain gets blocked up very easy and when the freezer defrost the water has noplace to go but the freezer bottom and could block the air passages so the cold air will not satisfy the control. so check the freezer bottom by removing the plastic peice on the bottom there are 3 plastic plugs in the front that secure it and some phillips screw in the middle. you can just lift it to check for ice. if there is none replace the cold control. good luck
Posted on Aug 04, 2007
SOURCE: Haier HTQ21JAAWW ISSUES!!!
my refridgerator seems to be workin the freezer is getting cold but not freezing its a top freezer bottom refridgerator the fan in the freezer is also not workin.i had atec come out to check it out. supposedly theres a capasitor that sits next to the compressor that he told me was bad an had to be ordered.its got 2 wires that come off the compressor that plug into this lil box.my question is could this be why my freezer is not freezing an also why the fan inside the freezer is not workin?
Posted on Jul 17, 2008
huuum
  • 750 Answers
SOURCE: Haier HVT 12ABS fan runs, but fridge does not get cool
Hello warmfridge
happy to assist you,
You said,
We've had this wine fridge for about 3 years now, and all of a sudden it stopped getting cold. We still hear the fan turn on and all appears to be running smoothly but it remains room temperature inside. Does anyone know how to fix this? I have no experience, but would like to try rather than buy a new one. thanks!
1. You may need to add freon.
2. It may have a faulty thermostat.
It seems you need hands on service!
Our site has good companies in the repair directory.
Bless you,
please rat me here before you sign off.
Thank You
Posted on Sep 14, 2008
  • 163 Answers
SOURCE: Compressor non start, overload cycling
you may want to try a 3-n-1 hard start for your compressor.the 3-n-1 has overload,relay and capacitor in one unit.very easy to install.it is possible your compressor has froze up.but worth a try.you can pick one up a your local appliance parts store.directions are on the bag.
Posted on Mar 25, 2009
  • 531 Answers
SOURCE: Haier mini fridge runs very loudly!
some thing is wrong
Posted on Apr 07, 2009
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
My Kenmore side by side freezer and fridge sides are warming.
your ptc overload/relay on the compressors bad,unplug the unit and remove this ptc part off the compressor and replace it
May 02, 2012 | Kenmore Side by Side Refrigerator
THE LIGHT COMES ON INSIDE THE FRIDGE, THERE IS STILL SOUND BUT THE FRIDGE IS NOT COOL AND THE FREEZER HAS DEFROSTED.
either the evaporator coil in the freezer wall has iced up and cant blow cold air and needs the defrost heater and thermostat checked(hint:rear wall of freezer will have snow/ice/frost on it)if this is the problem,otherwise the ptc overload relay on the compressor is bad and the compressor cant run correctly,if it just keeps warming up,then this is the culprit and a new ptc replacement easily plugs in where the old ptc was
Jan 09, 2011 | Baumatic BF230 Top Freezer Refrigerator
Both freezer and fridge stopped workin. only the
make sure the overload relay and start ptc are properly connected to the compressor.also check the wiring. if the wiring is good either compressor is no good or you need to replace the over load relay and ptc switch.rare occasions the thermastat switch needs to be replaced.i hope this helps your problem.good luck i would like to here how things went for you
Jan 21, 2010 | Frigidaire Refrigerators
Frige gets hot and makes clicking noises.
Sounds like the compressor is not working very well the clicking is the compressor starter trying to start the compressor. May be low on freon or bad compressor. You can probaly buy one cheaper than fixing this one
Dec 26, 2017 | Haier Refrigerators
Haier hsp03wna not working
The click you heard is the thermal overload. This snaps open when the compressor is too hot.
Unplug the unit for 24 hours and don't move it.
Then plug it in and see if it comes back on temp.
Jun 02, 2009 | Haier HSP03WNA Compact Refrigerator
Haier aficionado model AES44BPG compressor wont stay on
I had the same problem. Mine turned out to be the PTC starter. Checked the compressor coil resistance and it ws fine. Replaced the PTC starter with Item #: 1268268 from Repairclinc.com and it started right up. The PTC starter was an exact replacement.
Hope this helps some else trying to solve this problem. To bad Haier doesn't offer this part!!
May 01, 2009 | Haier (B000194UBA) Compact Refrigerator
Problem has returned to Maytag fridge
I note this is a very old post. The compressor is not starting and what you were hearing was the PTC relay energizing followed by the KilXon thermal overload kicking off the compressor start sequence. What happens is that the PTC relays sometimes get a heated contact. Due to the weakened state of the contact it can cause a buzz. Even with a goo PTC relay you would hear the compressor buzz if it was not starting. In that case the run capacitor may have failed or the compresor rotor is internally locked at which point the start cycle will repeat every 3 to 4 minutes as the thermal overload cycles and the compressor will not start.
Thanks for choosing FixYa
Kelly
Jun 18, 2008 | Refrigerators
Haier HSP03WNA Compact Refrigerator Logo
121 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
