Question about ViewSonic OptiQuest Monitor
Turns off and then turns back on again on loop
The Flat panel of the screen is good, when you turn on the screen it flickers on for a second (just long enough to read RGB in the corner) and then the screen immediately turns off and then turns back on again on loop.
Can i fix it or is it to throw away?
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Viewsonic monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 29, 2010
Why when I turn on my Bauhn TV the screen flickers for approximately 40 seconds, then it is good. It is out of warranty. Can I personally fix the flickering? I am not financial enough buy another.
I have no idea of your technical skills but I would assume you could not disassemble it repair it and reassemble it. I would go to where you purchased it, they may be able to work something out with you.
May 30, 2016 | Televison & Video
What else should I check on my Sanyo DP42840?
This could be the tuner overheating and sending a signal from the tuner board CPU to the power board to instruct the tuner to turn off. Check that there is adequate ventilation in the TV. Try testing with a fan to see if that changes the behaviour of the loop that you get.
Aug 31, 2014 | Sanyo Televison & Video
Sony 52xbr4 screen flickering
Fault with the main power supply regulator board. Ubnormal DC voltage output from it. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 29, 2014 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Help
Check its back light inverter board and back-light CCFL lamps.
May 21, 2013 | Element Electronics Televison & Video
My Sharp 32 inc turn off suddenly, power green light turn to red, went turn on again screen ok for 5 to 10 second and start blink 3 time and screen turn off and power light change back to red. What...
sounds like something is shorting and the safety on the psu is kicking in.is the backlight behind your screen flickering prior to it cutting out. if so sunds like a cft has gone faulty. can be fixed though
Jun 08, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Aug 23, 2009 | Televison & Video
Dell SP2208WFP Flat Panel Monitor flickers out and goes black.
Hi again,
Any luck with the Dell people?
A favor if I may, at your convenience, would appreciate if you can rate our Live Session as you see it fit.
Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 05, 2008 | Dell 21" M1110 .22DPI 1600x1200 *SUPER...
Computers & Internet Logo
147 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
