Question about Zebra Z4M Printer
Is it possible for my Z4M printer to automatically rewind rather than going through the menu and manually setting it to rewind each time? It says saving permanent changes but I still have to change it for each print job.
  • 4,234 Answers
The best way to do this is to set the printer via software. This can usually be accomplished by prepending a "format" to the print job. The specifics for this are documented in the programming guide. This way all of the settings are defined for each print job. This will completely eliminate the need for any "permanent" settings.
Dan
Posted on Apr 29, 2010
Z4MPLUS doesn't recognize the MEDIA(LABEL) automatically.
you should recalibt=rate the printer.
Are you sure that your previous label was not longer?
With the autocalibrate function activated the printer should try to detect the correct length. If it doesn't the yoou have
- A problem with the label border
- Preprinted stuff which the printer detects as to fo feed
Dec 09, 2013 | Zebra Z4Mplus Label Printer
Zebra Z4M won't print whole label
Did u try system restore?It will restore all of ur settings to how they were when it was working...
Oct 08, 2007 | Zebra Z4M Printer
Hey.. the zebra printer z4m is sayin "ribbon out" but it doesnt take ribbon. So how do i fix it?
go to the setings, and check Direct Termal or Termal transfer, Have to be Termal transfere, then run manual calibration, if still going, try to go tu Ribon sensor and change the number, possible is to higth 250...?) change to low number, and try to calibrate again.
Nov 23, 2010 | Zebra Z4M Printer
How do i get a mac address for the zebra z4m plus
plug in first to the network, and if exist comunication, go through the settings, and you be abel to see the net configuration, (IP selection, IPaddress, SubnetMask and Gateway.
check behind the printer nex to the net connectio, possible have a stiker, if not, try the stiker at the logic board.
Sep 21, 2010 | Zebra Z4M Printer
Z4m printer will miss labels in jobs. I've saved the job in the spooler and if I resend the jobs the blank labels will print out so I know the job is good. Any suggestions welcome.
Check the label size is set correctly in the application. Try using a driver from Nice Label or Seagull Scientific websites to suit Z4M (Not Z4M Plus). Recalibrate the printer and try again. Remember to setup the driver correctly because the driver will override the printer settings.
Nov 30, 2009 | Zebra Z4M Printer
Z4M take up spool not working
I loaded defaults, then set it to Rewind, saved settings as Permanent and it worked
Nov 20, 2009 | Zebra Z4M Printer
My Zebra Z4M stopped rewinding the used liner
This could be something simple like not having rewind (peel) selected in the setup menu. Or you could have a bad rewind motor or main logic board. Remove the cover and make sure no plugs have come loose. There isn't an easy way to check the motor or logic board unless you have a spare that you can swap.
Jun 25, 2009 | Zebra Z4M Printer
My Zebra z4m plus
in the setup menu there is an option to choose what the machine does on powerup and head close. Yours is probably set to calibrate. Just change that setting to "none". Same thing with the pausing. there is a setting to pause after printing each label. Just change that option.
Nov 02, 2008 | Zebra Z4M Printer
Zebra Z4M Printer Logo
181 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
