Question about Linksys SLM224G 24-Port Ethernet Switch
Http access on the slm224g is not working via cisco pix firewall? Is this a bug on the linksys not supporting nat?
    Guru:
  • 163 Answers
May ur nat is supporting secure http try using
https://
Posted on Apr 29, 2010
Pix 501 Endless reboot - lights flashing continuously
That was the fix !
It seems when using older Cisco devices, a dead / dying CMOS battery is more of a hazard. The battery's meager attempts to provide power repeatedly reboots the motherboard creating frustration and troubleshooting other paths.
CAUTION: Removing the battery isn't a simple affair since it is firmly clipped and a suitable, preferably plastic tool should be used to pry the battery upwards while pressing downwards on the black battery housing. This is similar to removing motherboard batteries but isn't often practiced since most 2502 batteries will outlive the usefulness of their host PC / Cisco PiX firewall.
FAILING to properly anchor the battery housing while removing it with suitable plastic / non conductive tools can permanently damage the sensitive electronics AND result in the entire CMOS battery housing to break off the motherboard.
The PiX will boot without a CMOS battery or even battery housing, but will fail to retain system time if DC power is interrupted.
Mar 09, 2012 | Cisco PIX 501 Firewall
I have an older Cisco PIX 506 with two VPN connections. One links two offices (PIX-PIX VPN) together, another is for staff to access email & files. The file server on the local LAN the PIX is on are...
It could be a missing route... are the file server and email server on the same subnet? If they are then it is possibly not a routing issue.
Also it would be worth checking the tunneling settings for the VPNs... if you have specifed either only the fileserver subnet or specifically the file server address, then this could be the reason they can get to nothing else.
Hope that this has helped a little :)
Apr 09, 2010 | Cisco PIX 506E 3DES/AES bundle (chassis,...
Replacing a PIX 515E with an ASA 5510
Best way to migrate is to take the configuration of the old PIX and TFTP it to a PC or other server for safe keeping.
Then boot up the ASA in a lab environment and TFTP the configuration to the new unit and reboot. There will be some commands that don't translate correctly, but you can compare the configurations to each other to make sure all the access lists and NAT statements get transferred across.
Keep in mind that the PIX and the ASA name their interfaces differently, so there may be errors when you transfer the configuration. You can edit the configuration offline with something like Notepad and change the names of the interfaces to have it work.
Jan 29, 2010 | Cisco ASA 5510 Firewall
When Firewall powered on the Act/Net not enabling
jus login via console to the firewall and give the this command
Mentioned below is example give the interface number according to your firewall ports
conf t
interface ethernet0/0 100full if its a pix firewall
Mar 21, 2009 | Cisco PIX Firewall 506
Pix 515E inside to outside translation problem
Dear Kiran,
What is the name assigned for isp 1 as well as isp2.
for your reference kindly find the sample configuration......
ISP 1:
interface ethernet 0 100 full
nameif outside security-lvl 0
ip address outside 203.193.129.132 255.255.255.240.
nat (inisde) 1 (local network)
global (outside) 1 203.193.129.133
route outside 0 0 203.193.129.129.1.
regards,
mani.S
Mar 09, 2009 | Cisco PIX 515E Firewall
How do I set up a VPN connection with PIX 501?
No worries. Just give it a try then let us know should you get any problems or follow-up questions.
Oct 15, 2008 | Cisco PIX 501 Firewall
Upgrade firmware on a cisco ASA 5500 firewall
This is for the pixes, I haven't upgraded an asa yet...should be close or the same
* find latest version of code, these are usually *.bin files located on http://www.cisco.com/cgi-bin/tablebuild.pl/pix
* confirm the flash and RAM requirements of the PIX OS software versus what the PIX has (”sho ver”)
* make sure you have a backup of the old PIX OS and PDM to the tftp server (or at least confirm the software is there)
Note: You cannot back them up from the PIX, so you will need to download them and put them on the tftp server * put in a change control form
* once change controls confirms date/time do the upgrade:
wri mem*** only if you save your configs via tftp wri net conf t ca save all copy tftp://your tftp server ip/pix635.bin flash:imageskip this if you don't use pdm copy tftp://your tftp server ip/pdm-304.bin flash:pdm *** if this is a failover pair, upgrade the other pair reboot
Sep 06, 2007 | Cisco ASA 5500 Firewall
Linksys SLM224G 24-Port Ethernet Switch Logo
113 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
