Question about Lexmark C510n Laser Printer
Line on paper - Lexmark C510n Laser Printer
    Scholar:
  • 118 Answers
turn on/off, unplug, plug inline on paper - 2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck. check rollers
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats and remove lines.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Posted on Apr 29, 2010
Line comes up vertically on scanned paper on colored paper only.
have you tried to uninstall the last upgrade? Sometimes they're not working as expected
May 29, 2015 | Office Equipment & Supplies
I WANT TO SET PAPER 15'x12' . KINDLY HELP SIR
Press START - Printers and faxes - right click Tally Line Matrix T6050 Printer - select Printing Preferences - find menu Paper size, select paper with size 15"x12". If not found, select used define or customize - insert paper size (width and height) - OK.
Set paper size on Microsoft office word 2007 - select Page Layout - Margins - Custom Margins - select tab Paper - on Paper size, select Custom size - insert height and width paper (15"x12") - OK.
Hopefully help
Sep 23, 2011 | Tally Line Matrix T6050 Printer
Lines in paper
if lines are wite, so toner is empty,
if lines are strong and two lenght left and right paper, so need clean cartriadge,
and if there are many small lines in all or part of paper but all vertical, or lenght of paper in step 3-4sm so need change drum.
Jun 13, 2011 | Brother MFC-8460N All-In-One Printer
My hp laserjet 2015n is printing a black line down the paper, what is this and can i fix it?
Hi:
One way to determine what is causing this is to do what is called a "panic stop" while printing a document. As the paper is starting to be fed into the printer shut it off and remove the toner cartridge.
You ideally want the paper to be under the print cartridge. Examine the image on the paper. Is the line visible on the paper at this point? If so, then the problem is with the print cartridge and it will have to be replaced. If the line is not showing up on the paper then the most likely culprit is the fuser section. This is were the toner on the paper is fused to the paper by heat and pressure. The heat roller or heat sleeve could have a line on it which would correspond to the line you are seeing on the paper.
Andrew
Mar 23, 2011 | Office Equipment & Supplies
I have tried everthing in "Lexmark X5495 Help"
Sounds like you just need a new printer. Some times the encoder wheel can get dirty with aerosolized ink and it will start to skip lines. The encoder wheel is a small plastic wheel on the paper feed of your printer. Around the edge of the wheel are hundreds of small thin black lines. As paper goes through the printer it counts these lines as the wheel turns to know how far to push the paper. If ink or debris gets between the lines over time it can start counting two lines as one and thus advance the paper too far, causing blank space between prints. See the below picture of a printer encoder wheel for reference. My professional opinion is to not purchase Lexmark. New Canon printers are very reliable with a high quality output, look for one that uses CLI-221 cartridges. Or most any HP.
Oct 29, 2010 | Lexmark X5495 All-in-One &USB...
When I am faxing do I put the paper print side up or down?
Most printers are different even from the same monufacturer. The easiest way to tell is look for the icon near the place where you load the fax. There is what appears to be a sheet of paper with a corner folded over. If the icon shows lines across the main part of the icon, and there are no lines on the part that is folded over, then the paper goes in the machine face up, or lines up. If there are no lines on the main part of the icon but there are lines on the part that is folded over, then it signifies the paper being loaded face down, or lines down.
Sep 12, 2009 | Canon L120 Fax Laser Printer
HP Laserjet 3380 line the length of the paper.
Lift up the document feeder and clean the small scanner glass.
Mar 10, 2009 | HP LaserJet 3380 All-In-One Printer
Black lines on photo
Are the lines always in the same places? If they are, then I would try using different photo paper. Humidity plays a big factor when printing with any kind of paper and buying new paper would be a good start. Make sure that the paper is made for your printer specifically. You might also try printing on plain paper to see if you get the same results.
Jan 17, 2008 | HP PhotoSmart 7760 InkJet Printer
Konica Minolta Magicolor 2430DL--black line on right side of paper
Sry but you have to change drum cartridge, the line is caused form drums cleaning system, and it cant be repaired.
Oct 18, 2007 | Konica Minolta magicolor 2430 DL Laser...
Lexmark C510n Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
