Question about Craftsman 24 Hp 48" Deck Yard Tractor
Carburation springs on the CV740S KOHLER ENGINE where do they go.
Had an oil leak in the engine, pulled it from the frame fixed it and the carburation linkages fell apart on me as I was awaiting to fix the major oil leak not really looking on how the carburation linkages where assabled or it would not have happened to Me, So I just need A little help on how to re attach it to the motor with no mess ups with out having to take it to a mechanic. It is a rather expensive lawnmower. Need a bit of help. Thanks
    Top Expert:
  • Craftsman Master
  • 80,531 Answers
I would have to look at it.
Posted on Jun 29, 2017
SOURCE: I am getting an error code on my Craftsman VS 4500
SERVICE REMINDER/HOUR METER
Service reminder shows the total number of hours the engine
has run and flashes to indicate that the engine or mower needs
servicing. When service is required, the service reminder will
flash for two hours. To service engine and mower, see the
Maintenance section of this manual.
NOTE: Service reminder runs when the ignition key is in any
position but “STOP”. For accurate reading, be sure key remains
in the “STOP” position when engine is not running.
Posted on Jul 01, 2009
  • 85 Answers
SOURCE: motor dies when sw.to engage clutch is pulled .
Clutch bearing is tight.
Posted on Aug 19, 2009
  • 138 Answers
SOURCE: engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Posted on Aug 24, 2009
  • 491 Answers
SOURCE: Craftmen tractor w/ Kohler engine stalls out continually
Sounds too lean.
Can you cover the air intake with your hand 90% or use the choke a bit and then load the engine to see if it runs better?
If you ever find a carb with manual high and low mixture adjustments that will fit yours......put it on and keep it on.
You can usually get then from older tractors.
Posted on Aug 25, 2009
  • 22 Answers
SOURCE: I have a Craftsman 18hp Kohler engine. What is
there is no clutch drive belt needs replacing cost of drive belt $20.00
Posted on Sep 02, 2009
Lincoln ranger 8 and kohler engine command 20. engine does not pull gas to carburetor. Putting little gas directly in carburetor; machine runs until finish gasoline inside carburator.
engines don't "pull" fuel to carb , it either gravity flows (tank over top carb) there or its pumped there , I do believe the kohler engines from 8 hp thru 25 hp use a vacuum activated fuel pump (three hoses on it) these do go bad over time and need replaced , also there are fuel filters on all these engines that need to be replaced seasonally they are not cleanable there disposable
Dec 15, 2016 | Kohler Electrical Supplies
MTD Snow Blower will NOT start up!
fuel float stuck --- need carburator repair -- to check it has spark then pull spark plug --- if wet blow off spark plug and check spark on plug then squirt a small fuel out of oil can into plug hole and put plug back in -- if engine fires on first pull carburator needs fixing -- check by squirting fuel in carburator with oil can and see if you can keep it running
Feb 23, 2014 | Garden
25 hp kohler liks oil true carburator
Sounds like the valves might be leaking a little bit. Pull the head and do a grind and reseat and new seals and sleeves . If it's a good old 8N, go all the way with a complete overhaul kit.
Sep 15, 2013 | Ford Tractor 8n Front Emblem
Kohler 14hp wont start not getting any fuel
Fuel solenoid, filter blocked, pump, carb leak check those
Oct 22, 2012 | Kohler pa-ch440-3031 gas engine, 4 cycle,...
How big of a problem is an oil leak and a hard left pull while driving??
OIL LEAK BIG PROBLEM.COST MONEY TO BUY OIL.AND COST MONEY TO BUY A NEW ENGINE.NEED FIX IT QUICK AS POSSIBLE. HARD LEFT PULL WHILE COULD BE LOW TIRE PRESSURE OR MISMATCH TIRES ONE TIRE BIGGER THAN THE OTHER TIRE.BROKEN OR SAGGING SPRINGS.WHEEL ALIGNMENT IS OFF.FRONT BRAKE DRAGGING.
May 17, 2010 | 1995 Nissan Maxima
I have a kohler ch22 motor on a zero turn tractor that runs irregular the governor is constantly moving while power running. In order to make it idle you have to choke the engine. It acts like it has a...
Sounds like an air leak. Anytime restricting air to "run better", look for air leak. A quick trick is spray oil on suspected area. If idle changes, then that's where to look first.
Oct 08, 2017 | Garden
Kohler CH20S losing power, blowing black smoke and oil
Sounds like engine is flodding. Have carb float checked, make sure it is at the correct height
Feb 04, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Riding mower engine loud and smoking.
take it to a reputable shop and have them check it over - courage engines had a problem when they first came out - the bolts in the cover plate were not torqued properly and when they come loose, the torque of the engine turning will crack the block - this should be a warranty condition if the block is cracked - just make sure the shop is a kohler warranty station
Aug 27, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman 24 Hp 48" Deck Yard Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
