Question about Dryers
Gas dryer is spinning but won't get hot what can I do before calling for repair?
  • 10,319 Answers
Disconnect the vent tubing and check for any clogged up areas. That will prevent the heat to work vis the moister control sensor. Clogged vents are the number one reason why dryers do not heat up while spinning
Posted on Apr 29, 2010
Why is my whirlpool dryer model number ggw9878pw1 not getting hot. What can the problem be?
Yours is a GAS DRYER.
The gas supply has been turned off for a reason, probably by the dryer, and needs to be inspected and repaired by someone who is VERY familiar with gas dryers.
Even if I knew exactly what the problem was with your dryer, I would be hesitant to share the solution with you as a gas dryer is soooo inherently and incredibly dangerous.
I hope no "FixYa.com" contributors chime in with some "better idea" that might put you at even the least amount of risk.
They rank up there as a #1 reason for a house burning to the ground and killing everyone in it.
This is NOT a question that can (or should) be answered via FixYa.com.
I am sorry, but you need to have a professional repairman come look at it.
On the other hand, an electric clothes dryer is much, much safer, and can likely be had for about the same price as the service call and repair of your gas dryer.
Just spend a moment to think about it: an open gas flame and LINT. There is always something wrong with that combination.
Your present gas dryer has failed you. BE SAFE, and replace it with a much safer electric version.
That is the only "FixYa" I can recommend.
http://media.newsnet5.com/uploads/ClothesDryerFiresReportNFPA.pdf
Aug 03, 2014 | Whirlpool Dryers
Kenmore gas dryer won't get hot
gas--- glo bar that lights the gas is bad or the vent to the outside is clogged electric-----wire may be burnt off the heating element or element has to be replaced
Jan 14, 2013 | Dryers
Gas dryer won't heat
Sounds like the solenoid is not opening and letting gas flow. There should be a small plastic plug on the front of the dryer near the bottom. Remove this and start the dryer, look in, if you do not see a flame, this could very well be the challenge. Applianceparts.com sells most parts needed for basic repairs. If you are not comfortable working on gas lines, have a repair person check this for you. Hope this helps.
Jun 02, 2012 | Amana Dryers
I have an Ultimate Care II gas dryer. Model # LGQ7030KQ0 and the drum won't spin when I push the start button.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 29, 2011 | Whirlpool Dryers
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
Sqeaks and won"t spin
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 24, 2010 | Whirlpool LGR5636L Gas Dryer
My dryer spins,but it doesn't get hot?
There is a problem with the heat source of the dryer. If electric, it is probably a burnt out element. If you're handy, you may be able to replace the element yourself. If you're not comfortable doing electrical repairs - don't. Call a pro to do it for you. The heating element is usually accessible when the rear panel is removed.
Gas operated (propane and natural gas) dryers are much different. A plumber will likely be needed to disconnect gas lines from the appliance and make the repairs. Improperly connected fittings can develop slow leaks that can eventually collect and explode from exposure to the slightest spark. This a a job for a pro.
Post again with your dryer make and model for specific help with it.
Sep 27, 2010 | Kenmore Dryers
My dryer does spins and turns on, giving minimal of hot air. Knob usually turns as the load is almost done. knob is now not turning at very hot mark on perm press cycle. Vents are clear.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 24, 2010 | Maytag PYE2300AY Electric Dryer
Dryer does not get hot
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 10, 2010 | Magic Chef CYG2000AWW Gas Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
