Question about Microsoft Windows XP Professional SP2
I log on my computer when come this error strtdb80.exe.How to solve this error
    Problem Solver:
  • 12 Answers
Some virus has detect you OS u need new OS install
Posted on Apr 29, 2010
How remove error STRTDB80.EXE
*First goto "X:\Program Files\Oracle" -> find and run Universal Uninstaller
OR
*Search and Delete all Oracle entries in the registry and then delete "X:\Program Files\Oracle"
Quote: HKEY_LOCAL_MACHINE\SOFTWARE\ORACLE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSeT\Services\EventLog\Application\Oracle.oracle * Delete
X:\Documents and Settings\All Users\Start Menu\Programs\Oracle - OraHome80"
*Start->Run->Services.msc and see if any Oracle services are running then disable it. Then find and delete the services entry from registry:
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services
Sep 10, 2011 | Microsoft Windows XP Professional SP2
Tip
Desktop Short Cut Missing
Hello,Some times your Desktop shortcuts or Start Menu Disappeared.It is happening due to Error Occurred in Explorer.exe. You can Clear this Error without Formatting.Just Do Following..
  1. Copy "explorer.exe" from other clean computer (from C:WINDOWS)
  2. And Paste it In your computer go to C:WINDOWS
  3. Show hidden files from (Tools - Folder Options - View - Show hidden files and folders)
  4. Delete existing 'explorer.exe' and any other files start with explorer...
  5. Put the new file (explorer.exe)
  6. Log off / Restart
  7. Log on
OR Just try this Solution.Close all your Opened Windows/Programs(OR Restart PC). Just Run this Dos File.It will Restore your Desktop Surely.. I/we need your valuable Feedback...Keep Using FixYa
Check this Link............. "Unable to Open Theme Corrupted" in Nokia 6300 Click here
on Apr 11, 2010 | Computers & Internet
After installing oracle 8i after booting the desktop it shows strtdb80.exe error how to remove this error
Press the windows key and the R key on your keyboard at the same time,
(The windows key is the flag key usually between the ctrl and alt keys)
In the Run Menu type msconfig and click ok
In msconfig, select the startup tab
Find the program strtdb80.exe in the list and uncheck it
click apply, Then ok
Upon the next boot you will get a different message saying system configuration was changed, To prevent this from re-showing click the don't bother me again option in the bottom left of the info box and click ok.
Aug 28, 2011 | Computers & Internet
In my system i instaled winxp sp2; but one error is coming strtdb80.exe Application error please solve my problem
Looks like previously your system invoked strtdb80.exe automatically during startup. But now , since you have formated and installed new operating system, the file got deleted. May be that file was a virus component, dont worry for it. And If you want to get rid of the error message, you can go for a PC tuning tool like Tune up Utilities. This tool will defragment the registry and resolve all problem.
May 20, 2011 | Microsoft Windows XP Professional SP2
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
Strtdb80.exe-application error
Sounds like a case of spyware or malware infections on your PC....
Read this thread @ http://tpsconsulting.com/spywareinstructions.htm
Hope it helps.
Mar 28, 2011 | Microsoft Windows XP Professional SP2
Strtdb80.exe
Go start menu, press "run", and type in "services.msc" (remove apostrophes). look for "OracleService", right click it, and change the "startup type" to manual.
If this doesn't work (meaning it was already on manual), then go to "Program Files" (my computer > C drive), and select and delete the "oracle" file. (by uninstalling or just removing (permanently deleting).
Please try the first option first to avoid data losses.
May 03, 2010 | YouTube Videos
How to solve strtdb80.exe has stopped working problem
You might want to check with Oracle Support for this problem. I've looked into this, and most of the cases related to this error message was with running an older version of the software (in your case, possibly with the developer 6i) on XP.
There may be some compatibility issues. To be sure, you can check with oracle (www.oracle.com) to confirm.
You can also try to reinstal the software.
Regards.
Feb 22, 2010 | Microsoft Windows XP Professional SP2
Plz solve this error
Do you have Oracle installed on your computer?
Ryan Frame
Creative Energy Associates Technical Center
Nov 10, 2009 | Computers & Internet
Microsoft Windows XP Professional SP2 Logo
85 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
