Question about Canon PIXMA MP150 All-In-One InkJet Printer
Error stated E 3 but could not locate where the paper jam. When open the top side, the ink compartment not move. Why? Please help AMANDA
  • 4,041 Answers
Hello there
You may not see a paper jam, You may have something still there sticking.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 29, 2010
PIXMA 450...Keep getting paper jam message and I can't see any paper bits anywhere. Trying to open the machine from the back to look inside. Have removed the 4 screws on the back and still can't remove...
Hi
The paper jammed can be found in the paper tray, remove the paper at the paper tray and inspect the roller for small pieces of paper jammed.
The paper can be found in the ink cartridge compartment, open the cartridge door and remove the ink cartridges, look for posibble paper jammer. Also once remove, check also the cartridge carrier if does not stuck up or jammed (cause this might me the problem). Turn off your printer and then move the cartridge head using your hand moving to the from right to left side and from left side to right side for 2-3 times. Move it gently.
Paper can be found in the rear access door if it is accessible. Inspect some paper jammed there.
Please let me know if you need more help
Mar 10, 2011 | Canon Pixma MP450 All-In-One InkJet...
I have got error 5100 what does this mean
Hello
Error code 5100 describes a physical problem either with a paper jam or an incorrectly seated ink tank. Resolving the error is a quick process that only requires a few standard troubleshooting procedures.
Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
Check the paper feed tray on the front end of the Canon printer to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
But in some other canon printers,Error code 5100 indicates that the waste ink absorber has reached maximum capacity. The Canon i860 printer uses the waste ink absorber to keep ink residue off the printer heads and internal printer components. To resolve this error code, the waste ink absorber must be cleaned out and the error code message needs to be reset.
Open the top of the printer.
Locate the waste ink absorber pad on the right side of the inside of the printer. Grasp the pad and pull up to remove.
Take the waste ink absorber pad to a sink. Run warm water over the pad and wring it out to clean it. Wring the excess water out when done cleaning.
Clean the waste ink absorber compartment with a tissue or cloth.
Set the waste ink absorber pad on a dry paper towel or clean cloth to dry.
When the pad is dry, place it back into it's compartment in the printer.
Close the top of the printer.
Press and hold the "Resume" button on the printer. Press and hold the "Power" button while holding down "Resume."
Release the "Resume" button. Press "Resume" twice. The indicator light will turn amber followed by green.
Release the "Power" button.
Press the "Resume" button four times
Press the "Power" button. The error code is now reset.
Nov 13, 2010 | Canon Office Equipment & Supplies
Hello there
You may not see a paper jam.
Apr 29, 2010 | Office Equipment & Supplies
Alarm is blinking and computer is stating that
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Feb 16, 2010 | Canon PIXMA MP780 All-In-One InkJet...
How do I clear a paper jam in the Kodak ESP-3 can't get to the paper
If you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below. Works for esp 7.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
Jan 17, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have Kodak esp 5 all in one- says I have paper jam--- but no paper inside
backward.
Jan 14, 2010 | Kodak ESP 5 Printer
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
MY Canon Pixma MP 500 Printer won't Print.
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Dec 15, 2007 | Canon MultiPASS F60 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
