Washer starts to spin and drain then stops smell a burning smell
  • BRIAN
    BRIAN May 11, 2010
    THE MOST COMMON THING IS SOMETHING IN THE PUMP. MORE INFO WOULD HELP IF YOU WANT TO DO THIS. I NEED A MODEL NUMBER.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Apr 29, 2010
Loud noise while running
Hello. Did you get an answer to this inquiry. Mine is doing the same thing. Smell of burning plastic; continues to fill and drain at the same time?!! I have to manually shut of water to stop the water and then manually set to spin so it will drain!
Mar 22, 2014 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Wahser stopped after wash cycle, burning smell
Hi, it is possible that something got into the pump and stopped it from turning. Let the drain hose down so that it drains into a bucket or a floor drain if possible.
If water does not drain then it is deffinetly plugged. Once you get the water out of the washer, tip it against the wall and try to remove the pump off the motor. There are two clips that hold the pump on. You will also need to remove the hoses.
With the pump off, you can set the washer back down and try to run the spin cycle. If the motor runs, it must be the pump.
Please let me know if I can assist you further.
Thanks
Vic
May 23, 2009 | Roper RAS6233KQ Top Load Washer
I have a 4 years old GE top loading washer - model number 2090D... it was fine till last night that it stop at the last ''drain and spin'' cycle... and I smell a burn smell too when I notice the washer...
  It may be possiblr by the way you explained the symptoms, that the tomer may have shorted out .That would be the most likely problem of the burning smell,and the case of no water entering the tub .
May 02, 2009 | Washing Machines
My ge washer starts spining to drain water then stops
Sounds like the belt is loose. The burning smell is the belt heating up. The motor shuts down because it's heating up from spinning on the belt.
Apr 30, 2009 | Washing Machines
Machine won't spin
Motor part number is 8529936 about $200.00 any appliance parts store can order it. You can replace it your self. Also replace the direct drive coupling when you change the motor.part number 285753. Be sure to inspect your wiring harness and check the motor wire continuity before you put $200.00 into it.
Mar 27, 2009 | KitchenAid KAWS850L Top Load Washer
NO Agitator, draining or spin
Since the breaker did not trip i am going to assume that the washer stopped because the motor overload switch tripped or contacts burnt. Was there any smell of any burning (electrical burning)?. It could have stopped because a contact on the timer got burnt too. Have a look also at the water level swirch
Regards
Oct 04, 2008 | Whirlpool LSB6200KQ Top Load Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
