Question about Whirlpool Washing Machines
Have a Whirlpool AWO/D 6042 front loading washing machine that shows a "clean pump" indication. Drain hose is not kinked, but don't have an "Instructions for Use" Manual and don't know where the filter is so we can check it. Can you help?
Hey did you find out the answer as im having the same problem?
Posted on May 04, 2010
  • 1 more comment
  • amarildo Dec 22, 2012
    no but i think the circuit board
    Actually i think is a chip to the circuit board with 7 pin no lnk304pn
    i can not find it, to bay here in albania
Machine not working (whirlpool duet fron load) error code f21
This error code indicates that drain times are longer than expected. This could be a problem with one of the washer parts including the drain pump itself, how the drain hose enters the stand pipe, or maybe something is stuck somewhere in the drain system and is preventing the water from flowing properly.
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
Remove the three screws that hold the lower access panel in place. Here you will find the pump and the all important sump clean out, or as we like to call it, the coin catcher.
Jun 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F09 in a AU AWO 5761
F09 Error = Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds
an Overflow condition will occur. In an Overflow condition, the Door will remain
locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed
twice and the Display is cleared. Unplug the unit to service.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and
Central Control Unit (CCU)
• Check/ Clean Drain Pump Filter of foreign objects
• Check for Drain Pump Failure
• Check the Inlet Valve for proper shut off
• Check the Pressure switch for proper operation
Dec 29, 2010 | Whirlpool AWM8143 Front Load Washer
What are the codes for a front load whirlpool washer F21
Hi
Thanks for using FixYa. Error F21 indicates long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have the front loading duet washer. The code F
F2 indicates a long drain usually caused by blockage in the filter, remove and clean out filter.
Also Check the drain hose and make sure it is not plugged or kinked.
Check the electrical connections at the pump and make sure the pump is running.
If the above does not correct the problem, replace the pump
www.appliancehelponline.com
Apr 09, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool washer model ghw9150pw0 has an error message of f2. The washer does not go thru the cycle and now the door won't open. Help whats wrong
or
or
This error code indicates that drain times are longer than it should be
Is the drain hose kinked or clogged?
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose from on the drain hose, and secure the drain hose.
The most common cause of a slow drain is the drain pump screen is clogged with lint. Unplug the washer and remove the bottom front panel with 3 screws on the bottom. The drain pump will be right in the center usually white in color. There will be about a 3 inch piece that can be unscrewed by hand. Have your wet vac ready because when you start to unscrew this all the water in the machine will come out here. Once all of the water is empty completely unscrew and pull out. You will now be looking at the drain pump screen which with the f2 should be full of lint or debris. Clean the screen thoroughly and reassemble. If this does not fix your problem you will need to check all the hoses going into the drain pump for anything blocked in them. If all is clear you will need to check for 110 volts at the pump when the washer is in drain. This should only be attempted if you have had training with live voltage. If 110 volts exists the drain pump will need to be replaced.
Thank you
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F2 error code
check your drain hose for kink,,when you cleaned filter did you check for coins in the impeller..also check drain pipe for slow drain problem,,check the pump connection and make sure its not slipping off..onthejob
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWO 3761/S
Faulty pump (most likely clogged).Remove the pump hoses and clean out the pump.Please leave a rating.
May 16, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Washing Machines Logo
714 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
