Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Cool on light is blinking and the a/c isn't turning on!what do I do?
  • dillon2 May 11, 2010
    Is this on the thermostat?
  • Brian Niten May 11, 2010
    Is this something that just started? Some therostats have a built in delay (~5 mins) before the a/c will kick on.
Blinkin light
Turn the main power to the unit off, leave off for about 20 seconds then turn back on. Unit should restart. The blinking light is a fault light that can be reset by turning main power off. Most times it will restart no problems but if the fault re occurs there is a problem with the unit itself. If the fan starts and runs for around 4 minutes on cooling mode then stops and blinks there is a problem with the outdoor unit.
Mar 31, 2014 | Daikin Mini Split Ceiling Suspended Units
TV power lights blinks on after turn on.
you need to post make and model#
Dec 31, 2013 | Televison & Video
Power supply isn't working
dOES SET COME ON WITH POWER LIGHT ON AND A FEW SECONDS LATER SHUTS OFF?
WHEN it turns off press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both.
watch for power light to blink a two digit error code like 1 blink, 2 blinks and then pause and repeat the code for about 5 times .
Let me know what code you find .
Dec 21, 2012 | Mitsubishi VS-70707 70" Rear Projection...
My sony lcd tv model kdl40ex400 red light blinks six times and does not come on .what is the solution.
My TV did the same thing. According to Sony the Bulb or lighting mechanism is bad when 6 red lights blink and your TV fails to turn itself on properly.
If you have a warranty they'll likely replace the television set as they said "it isn't cost efficient to fix this issue."
Nov 03, 2011 | Sony KDL40EX400 40 in. HD-Ready TV
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
The filter light keeps blinking. the filter isn't dirty. the filter is in the front and slides out either side. we keep it clean. so.. how do i get it to quit blinking? is there some regular...
Pam, be sure tat the filter is properly installed. Whenever you remove the filter for cleaning, be sure to turn the unit OFF, before removing it. And back ON after it is cleaned and reinstalled.
For the blinking problem. Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. Once the time has elapsed, plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the unit's electronics reset themselves and reverted back to the original factory settings. If so, the filter light should have stopped blinking, if the filter is installed properly.
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Whirlpool ACQ122XK Air Conditioner
My camera will not turn on or get charged. HELP!
hi your statement isn't clear. would you give more detail. (like outside of shape, lens out position, when switch on how it respond momentarily--light blinks? etc..) Thanks
May 22, 2011 | Kodak EasyShare V803 Digital Camera
I have a red light on my xbox and it told me to look for consumer support. what do i do
How many lights are blinking??
Two blinking red light's on the power button means that your console has insufficient ventilation. The red light will continue flashing until the console cools down.
Let your console cool
  1. Turn off your console.
  2. Let your console cool for one hour.
  3. Turn your console back on.
If the solution worked, your power button should be green.
If your power supply cords are not plugged in securely, you may see one flashing red light when you turn on your Xbox 360 console.
Check out this site and follow along according to the symptoms face by the xbox360.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/flashing-lights-wizard.aspx
Feb 11, 2011 | Computers & Internet
Sony KDS50A2020 Blackout
Replace the lamp, clean the fans, seen it a hundred times, I know "the lamp light isn`t blinking" replace your lamp and you`ll be back up & running, gl, video-tek
May 29, 2009 | Sony KDS-50A2020 Television
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
352 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
