Question about Bosch 24 in. SGE09A25 Built-in Dishwasher
Dishwash still going after 3hrs and still not completed programme
Put dishwash on the 70 programme and left it. Went to the dishwasher 3 hours later and it sounded like it was still working, I opened the door the timer was showing 1 min to go in the display and there was soapy water in the botton and the plates etc were still. Switch it off and on again and the minutes change to 38, I shut the door for to to continue and left it, came back in after about 1hr opened door and it was show a 1 min left, again there was still soapy water in it and the plates wet still. I cleaned out the basket etc put it on the risen programme (19min), again it was on longer that 19 minutes and when open the door it was showing 1 min left and the condition inside still the same. Please help as I can't find the instruction manual for it.
Rotu
  • 175 Answers
SOURCE: stuck on last minute
I have seen a lot of these dishwashers burn out the control board, and usually the symptom is the timer not working or inability to complete a cycle. Most of the ones I have seen, you can remove the control board assembly and its pretty obvious where its burnt. If you can do the repair yourself, the board is about $150. Hope this helps!
Posted on Oct 26, 2006
SOURCE: Bosch dishwasher
Hello guest. seems you have a leak in the base. Looks as though motor is washing dishes but actually its the drain pump thats been activated which doesnt allow the timer to proceed forward.
Posted on Jun 09, 2008
here2helpBSH
  • 27 Answers
SOURCE: Bsoch dishwasher runs long and displays 1 minute left on timer
sounds like a bad solder connection on the heater relay of your control unit. more than likely you will need a new control unit. part number 266746
Posted on Mar 19, 2009
  • 423 Answers
SOURCE: opened door on cycle, will not continue cycle after closing door
The most common problem for a dishwasher to not restart after the door being closed is a failed door latch interlock switch. Adjusting / repairing it is not too difficult.
Of course this assumes that the Dishwasher power circuit from the circuit breaker remains powered up.
Post back here if you are looking for more details.
Good Luck!
Posted on Apr 16, 2009
SOURCE: My Bosch dishwasher won't shut off. The timer says
Bosch SHE44C06UC
The dishwasher continues to run...I followed instructions and performed the diagnostic...the light above the quick wash was solid, the light above the rinse/hold was flashing...the code displayed in the cycle countdown window was P0...now assuming the machins isn't "pissed-off"..can you help-
Posted on May 03, 2009
Dishwasher restarts a new programme after finishing previous
try to reset program..... hold off button for 2 seconds or so..... until it turns completely off....
it this won't help, try to disconnect it from outlet..... wait few minutes,... connect it back to wall and try again
Jan 13, 2014 | AEG Dishwashers
Dishwasher shuts off during cycle
Since the troubleshooting and repair process is too lengthy to include here, please go to the following link: http://www.appliance411.com/service/repairmanual.shtml
to open [or download] the service / repair manual. It is free.
Scroll about half way down the page, in the left column, under Maytag products, select the Maytag / Jenn Air / Jet Clean II "Tall Tub" Dishwasher repair manual... it covers your model dishwasher..
It includes a troubleshooting guide as well repairing instructions
Best wishes on your project.
Dec 01, 2013 | Maytag MDB9600A Jetclean II Built-in...
Why did my quiet partner II whirlpool dishwash just stop mid cycle?
see this possible causes:
Water-heating cycle
heat, wash, and rinse has the 3 cicle, principal problem is the heat cycle, when the water reach the level ( by heating water elements) test the heating elements , most ot the time fixing this .the problem is o.k
Timer
sincerely. God bless you
May 04, 2012 | Whirlpool Dishwashers
My dishwash inner steel coil of bottom was broken
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Oct 28, 2010 | Kenmore Dishwashers
Dishwash smells like rotten food even after a fresh wash
I switched back to powder (Cascade) from pre-measured gel packs and the smell went away.
Sep 03, 2010 | Electrolux 24 in. EDW5505EPS Stainless...
The dishwash is not washing, it's running but there is no water. The washing cycle is completed but nothing has happen, this recently started.
Sounds like a bad water valve or the water supply is cut off. If the water supply is not cut off then try hooking up 120 volts to the water valve. It should buzz or hum and let water in. If no water goes in then change the valve.
May 15, 2010 | Dishwashers
Why do my dishes no longer seem to get clean? The glasses are spotty and foggy, small bits of food left on the plates, etc. They not completely dirty as they were when I put in to wash, but they're...
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 01, 2010 | General Electric GHDA480N Built-in...
Dishwash
sometimes those dispensers become defective,, make sure nothin is obstructing it from opening possibly dishes or rack attachments,, if not then u will need to order a new dispenseer assembly if this is a whirlpool built kemore,,,( kenmore just puts there name on aplliances, they dont build them) just to let u know if u didnt know already...
deteremine your model number go to sears online check out there parts and service page and research parts by puttin in your model number and determine the part number for your model ,,,, i believe they vary from 20 to 60 dollars ,, this is somethin you could do just have to get part and seperate the panles by removing the screws all around the inside door.. hope this helps
Jan 31, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher backing up
sound like you have a few things going on there.there is a float switch which is located at the front right side of dish washer, make sure this floats freely . also sounds as through your drain line may have become plugged. Ease to fix , remove the line and hard line from the pump with a set of plyers. and remove the debris from the diaphram within the hard line.. before starting this be sure to remove as much water from within the dishwash, easiest way is to use a shop vac.
Jul 26, 2009 | Kenmore 15912 Built-in Dishwasher
Dishwash cycle takes too long.
I am a recently retired appliance engineer of 20 years no that won't help, dishwashers only use one pipe cold water, check fill pipe for kink or low water flow rate filling up,if no problems then check heater element for open circuit, then check for any blockage with water outlet / filters and pump etc well somewhere to start to be going on with, if any of above helped rate me please,
Sep 08, 2007 | Bosch SHV4803 Dishwasher
Bosch 24 in. SGE09A25 Built-in Dishwasher Logo
27 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
