Question about Skull Candy Ink'd Stereo Ear Bud Headphones - Pink
Only one ear working
They started skipping and now only one ear is working.
    President:
  • 1,469 Answers
Hi, what makes the earpiece not working, is that the wire inside the speaker area where you put inside the ear is faulty.
Loose the head of that small speaker, you will see the wire that has removed, use a soldering iron and a lead to fix it back.After fixing back, you can start using it again.
have a nice day.
Posted on Apr 29, 2010
I love my SA-PM 18, but my playback has started skipping and repeating. It is not the discs. Is there anyway I can clean this, or have it cleaned?
take an ear sward dip it in an alcoholic solvent ( make sure is not dripping) then wipe the lense. if it doesn't work replace with the same lens type from a local electronics store.... how evwer you can get an equivalent will work just as fine .
Jan 24, 2015 | Audio Players & Recorders
Find manual!
I would start here: http://v-moda.com/manuals/
If you can't find the manual there then I would try contacting the company here:http://v-moda.com/contact/
Aug 19, 2013 | V-Moda Remix Headphones
How much pressure on the needle
This depends on the cartridge. Most cartridges specify this, so you can search online for the specifications of the cartridge you use. Or you can do it by ear. Set the weight to start at 2 grams. and adjust it a bit at a time, testing to see if it sounds right. It should not be light that the stylus skips out of the grooves, nor to heavy to rumble.
Dec 25, 2012 | Stanton T.92 USB Turntable
Cd scraping when played
hi,
did u mean skipping in audio. then ur cd players laser pickup unit have some problem. just try to clean the lance of laser pickup. for that u can use an ear bud. do not use any solutions only ear bud.do no give pressure on the lance. clean gently. after cleaning try again. if problem remains u should replace the laser pickup unit.
ok
Dec 22, 2010 | JVC FS-2000 Shelf System
One of my headphones only makes noise when pressed on with force
Sounds like the conductive cable is about to go bye-bye.
My previous in-ear started to behave like this after about a year and a half of use.At first,if I pressed or moved its body around may solved it.But about a week later,the right ear went completely silent regardless how I fussed on it.
If the symptom gets worse and worse as time goes by,you'd better look for the new earphones.
Jul 24, 2010 | Skull Candy Smokin' Buds Headphones
A folder shows up on startup and notice to contact apple support. 20gb 4th gen
Ipod is not ABLE TO FIND THE OS ON YOUR HDD.
try to bring it close to your ear an try to hear. See if you can listen to clicking sound. if it does click, your in trouble as your hdd is messed up..
nothing much you can do about it, just when its trying to start and it starts clicking bang your ipod ( on ur palm ) as this would help the hdd needle to skip and bad sectors and might work again !
good luck.
May 21, 2010 | Apple iPOD 20GB Toshiba Harddrive for Gen...
When I press the play button, the cd goes around, but it stops
its either you have a defective pick-up lens or spindle motor.
Aug 06, 2009 | Audio Players & Recorders
I'm not getting any audio from my sansa e260
You have 3 soldered points inside. Two are soldered onto the mainboard just slide into the ear plug itself. One is actually soldered directly onto the mainboard. If you are very careful, you may be able to raise the ear plug enough to bend the two that slide into the plastic out just a little. This has worked for me before, but it takes a gentle touch..
You may have to re-solder the ear plug on the mainboard. I have had several off of ebay that I bought that needed to be soldered. Be very careful if you don't know what you are doing when re-soldering.
Feb 25, 2008 | SanDisk Sansa e260 MP3 Player
Skull Candy Ink'd Stereo Ear Bud Headphones - Pink Logo
367 people viewed this question
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Owen Barnes
vimal
vimal
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
