Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washing machine you turn on washing machine it goes thru all cycles but the water never shuts off
    Sergeant:
  • 351 Answers
Turn power off then turn tap on if water comes in then the valve is faulty,if it doesnt then check the pressure tube for leaks or the pressure switch.hope this helps
Posted on Mar 26, 2008
SOURCE:
Where to put washing powder? there are 3 areas in tray
open the tray when you start a load and watch which tray the water goes thru first,this is the soap/detergent tray,then where the next cycle starts watch which tray the water goes thru and this is the tray for the fabric softener
Feb 08, 2011 | Fisher and Paykel Washing Machines
How do i fix my washing machine interlock hotpoint hvf 344
The door should have a pin on it that pushes and closes the interlock switch. Check to see that the switch is inadjust ment to trip by turning off the water door open and with a plastic rod or a pencil push thru' the hole in the chasis where the door pin goes through and start the machine. If it starts quickly pull out the pencil, unplug the machine and adjust the switch. Plug it back in. It may continue on with the cycle you just started if not better! If not close the door aand start a short cold wash cycle. If it sounds like it wants to start, turn on the water and let it run thru' the complete cycle.
Jun 29, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My dark clothes has lint all over it after it has been washed, Is there something like a lint trap to clean?
need brand and model. on top loader washing machines i"ve used bicarb soda to fix problem. -2 pkts soda ___ select high or large water fill______ select hot water fill_______have no clothes in unit____ put soda into machine____ shut lid __ select wash cycle----- let it fill and wash for about 10 min"s------ turn unit off------ do not let wash water drain----- leave over nite--- in the morning restart cycle, unit will just continue to wash it will not refill----let it go thru complete cycle and that should fix problem.please reply with brand and model.
Apr 08, 2010 | Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Water will not shut off in washing machine
Check to load size selector switch, sounds like tube came off of it. The tube goes from switch to bottom of tube, tells machine what size load and when to turn off water.
Jul 19, 2009 | GE WBSR3140DW Top Load Washer
Washing machine does go thru spin cycle or drain water.
If the washer does not spin, take off the rubber bumbers inculding the little washers attached, inside the lid. It lowers the lid, which takes care of the problem. I had the same problem. Not anymore! Trust me, if nothing is wrong with any other part of the washer, this will work.
Apr 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer doesnt fill water but goes thru all cycles
After contemplating the issue, I decided that the machine "thought" it had filled. That led me to believe that the water level control was not working. I happened to have a control from an old washer that I could make fit. After replacing this control, I'm back in business. Everything is working fine although I now have only 3 water levels to chose from where I previously had 5. I hope this helps. Good luck. Mark
Dec 26, 2008 | Washing Machines
Hotpoint washing machine
INSPECT THE BELT MAKTYBE BROKEN OR CAME OFF ??????????LET ME KNOW
Nov 29, 2008 | Samsung WF337AA Front Load Washer
Whirlpool Washer not going thru cycle
IF YOUR MACINE WONT PUT WATER IN IT WHEN YOU TURN IT ON ITS THE WATER INLET VALVE IN BACK WHERE YOU HOOK UP THE WATER. IF THE WATER GOES IN WHEN YOU TURN IT ON THEN ITS MORE LIKELY TO BE YOUR LID SWITCH. YOU CAN GET EITHER OF THE PARTS AT YOUR LOCAL APPLIANCE DEALER OR EASILY ON LINE. JUST HAVE YOUR MODEL NUMBER HANDY. GLAD TO BE OF SERVICE.
Nov 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
