Question about Fuji FinePix F610 Digital Camera
The zoom is jammd
The zoom lens is jammd part way out
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 29, 2010
How do I zoom in and out on a photo?
This camera has a 9mm lens, and while shooting, you can't zoom. For that you need a zoom lens. You can buy one from Samsung.
I checked the manual, and it also does not show how to zoom in on a picture when it is on the display. So I guess, you should view it on a computer, or tablet ant use the picture viewer on that device to zoom in.
Be aware you have a great camera and the result with a prime (one focal length) is superior to the results make with a zoom lens.
But if you don't like to move around, to farm the picture, a zoom lens can be convenient.
Oct 07, 2014 | Samsung Nx Mini Smart Camera With 9mm Lens...
Best telephot zoom lense for my canon 1000d
That's a decision only you can make. What's most important to you? Long focal length? Wide zoom range? Lens speed (maximum aperture)? Weight? Cost?
Also, what do you want to do with the lens? The best zoom lens for taking wedding pictures is not necessarily the best zoom lens for taking sports pictures.
Jan 25, 2011 | Canon 75-300mm f/4-5.6 III USM EF Lens
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
How to zoom in using Canon EOS Rebel XS?
Zooming is done from the lens on a DSLR, assuming you have a zoom lens on the camera. For example, if your camera came with the 18-55mm lens, you should see the numbers 18, 24, 35 and 55 on the lens barrel with a white index line next to one of the numbers. Turn the barrel to move a different number next to the index line. 18mm is wide angle, 55mm is 'zoomed in'.
Mar 12, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
How to achieve full zoom with a Nikon 55-200mmf/4-5.6G ED lens?!
1) What camera body are you using?
2) I do not understand your assertion that it automatically zoomed in. Zooming is a manual function. The automatic functions of your lens pertain only to focusing on of the subject so that your picture is sharp and ensuring that the correct amount of light is admitted so that you have a correct exposure.
3) Are you sure you were turning the zoom ring and not the f-stop ring? The zoom ring is labeled 200 on one end of the scale and 55 on the other. It is also the widest ring on the lens barrel. When you rotate it, the physical length of the lens will lengthen as you rotate it clockwise (viewed from behind the camera) and shorten as you rotate it counter-clockwise.
4) For reference, at 200mm the angle of view on your lens should be 10 degrees and at 55mm about 40 degrees.
Dec 27, 2008 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
Zoom lens is "locked"
Is there a little lock switch on the lens?? My Nikon lens all have a tiny little lock and if it accidentally gets pushed into lock position it will not zoom. Barry Brown www.coralreefphotos.com
Aug 18, 2008 | Quantaray Tech-10 70-300mm f/4.0-5.6 Lens...
Optical zoom
Hey needacamera,
The range of an optical zoom lens refers to how wide angle to telephoto the lens covers. An example of a 6x optical zoom would be an 18mm-108mm lens, which covers wide angle to telephoto. An example of a 3x zoom lens would be an 18mm-54mm lens, which would provide a capability of capturing images from wide angle to normal views. To calculate the x factor of an optical zoom you would divide the largest number by the smallest number on your zoom. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 31, 2008 | Cameras
Zoom Lens doesn't Zoom
Check you haven't accidentally got the camera into some fixed-zoom mode ("Super-Macro" is a favourite for this on Olympus cameras).
A.
Apr 06, 2008 | Olympus Camedia C-765 Digital Camera
Zoom Lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2008 | Fuji FinePix A303 Digital Camera
Fuji FinePix F610 Digital Camera Logo
41 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
