Question about SanDisk 4GB microSD High Capacity Memory Card
I have been using a 4gb micro sd memory card when i format card its showing windows was unable to format & displaying 30mb size of card
    Genius:
  • 1,234 Answers
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Accepte my greetings
    Posted on Aug 27, 2010
    My 4gb memory card showing 30.1mb and can't formatted
    My 4gb memory card SD showing 30.1mb and can't formatted it{Transcend}
    Jul 23, 2014 | Transcend TS4GSDHC6V 4GB Micro SDHC Flash...
    Windows was unable to format
    Perform the format from the camera's setup screen. If unable to format still, then memory card is bad. Replace it.
    Nov 22, 2013 | Kodak SLICE Touchscreen 14MP Digital...
    4gb card showing 30.1 mb unable to format
    my sd card is of 2gb but its size is showing only 45.6 mb
    please give me solution on sandip.955@live.com or on 9560709358
    Nov 10, 2011 | SanDisk 4GB microSD High Capacity Memory...
    4gb sd card not format problam format uncomplet
    I'm assuming you are having a problem formatting the memory card?
    The soultion would be to connect it to a PC or laptop that has a card reader installed, then format the card via Windows.
    If it is a micro SD card, you may need an adapter to convert it to a SD card.
    Thanks,
    Aug 11, 2010 | SanDisk 4GB microSD High Capacity Memory...
    UNABLE TO ACCESSMY 4GB MICRO SD CARD
    Your memory card reader lacks SDHC compatibility. You must either update your pc card reader to one which is compliant with SDHC or use a cheap external card reader to do the job.
    SD and SDHC cards look the same and fit the same slots, but they have significant technical differences which older readers cannot handle.
    Jul 22, 2010 | SanDisk 4GB microSDHC Memory Card
    My USB says that it is 4gb, but when i go to properties, it says that over half of the space has been used, yet there isnt anything in my USB!!!???
    Hello...Pal! You will have to format your disk using your computer so that it works properly. You have two options to format for micro sd card. One is, you are to open my computer and right click on the sd card drive and choose format option. This will display a window, there is a option of quick format, make a check sign to this and press format button. Second is, go to start menu -> Program Files -> Accessories -> and choose command prompt. when command prompt window opens, type e.g, "format K:" and press enter, if it ask for volume label, type its drive name like Personal (C:), only type the name e.g, Personal, and if it does not ask for volume label, press enter one more time, then this will show a surity message, type Y and press enter, your micro-sd card will be format successfully.
    Oct 25, 2009 | Kingston 4GB Secure Digital High Capacity...
    I am not able to format my micro sd card.
    try to format it using ur phone.. if still showing sum error thn card is corrupted.. it will be replaced
    Sep 06, 2009 | SanDisk 4GB microSD High Capacity Memory...
    8 gig micro sd unable to format
    you should download memory retriever it fixes your memory card and retrieves your data. i had the same memory card and i thought it was from the memory card acting up so i got a new one. but it was kind of from both the phone and memory card but i downloaded the program and = ] my new memory card wasn't formatted so now am all good! both of them working because my san disk memory card wasn't working and it deleted all my data. so now it retrieved and now is working! give it a try! and tell me what happens
    Mar 21, 2009 | Electronics - Others
    I ve bought a new meory micro sd 4Gb card for my
    Be careful, if you use the USB cord to plug the phone up make sure that your not formatting the entire phone.
    Did the Micro SD card come with the bigger card to plug it into making it a standard size SD card ? If so then you can plug that into a card reader if you have one go into MY Computer, and right click on the drive of the SD card click format.
    Those are the only other ways of solving said problem if you can't do so on the phone itself. Also the phone may not accept a memory card of such size.
    Mar 17, 2009 | Samsung Cell Phones
    SanDisk 4GB microSD High Capacity Memory Card Logo
    118 people viewed this question
    Top SanDisk Electronics - Others Experts
    Piyal Perera
    Piyal Perera
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
