Question about Sigma Zoom Telephoto 170-500mm f/5-6.3 APO Aspherical Autofocus Lens for Canon EOS
I have a sigma 170x500 that is getting stiff how can I get it apart far enough to lube it?
  • 1 more comment
  • rickb7246 Apr 29, 2010
    My question was how do you get into it not what to use, I have no idea how to get to the slide
    I would like partially take this lens apart enough to get some graphite base grease on the slide and the other parts that need it but I have no idea how to get it apart can you give me any clues its a Sigma 170x500 for a AF Canon
    I will not use WD40 as it likes to gum up to bad.
    Thanks
  • rickb7246 Apr 30, 2010
    Thanks removing the rubber grip and the three screws and I used three drops Hoppe's gun oil did the trick
  • 10,319 Answers
The rubber grip that surrounds the barrel comes off which is very hard to remove without stretching it out of shape. Once off the screws can be removed to add a few drops of solvent to loosen the stiffness
Posted on Apr 29, 2010
  • 12,061 Answers
We used to warm the assembly slightly, and then use graphite grease very carefully, on the slide...work it in & out, a few times... a good quality penetrating oil can also carefully, applied too, & can free up and make it run smoother. Just be gentle. but firm.
  • 10,865 Answers
Hello. Get an aerosol can of a penetrating lubricant called WD-40, with a tiny spray tube attached. Use it sparingly and apply a wee amount around the part that you can reach. Reapply as needed. Joe
My delta shower faucet has gotten very stiff and squeaks when turning on and off, how do I fix?
The the faucet out and take it apart and clean off the deposits of calcium and rust from the moving parts and then lube the parts with Silicone grease and reassemble
Oct 11, 2017 | Delta Home
Where can I find out how to take apart a Sigma 150-600mm contemporary lens?
Taking it apart is not the problem - re-assembling it will be. Unless you have access to an optical laboratory, where laser instruments can measure the exact tolerances required, don't even think about it. You will be left with a pile of optical components, and a far higher repair bill than if you had just let the experts sort out the problem in the first place.
Dec 03, 2016 | Sigma Cameras
Shift cable replacement
have to remove the shifter panel and the covers. most times its a few screws and a couple clips and then have to get it back in the same way you took it out and apart.
Oct 19, 2014 | 2004 Chrysler PT Cruiser
Freezer fan makes sounds like rubbing back wall
Two things come to mind - either the fan has accumulated enough dust and debris to make noise or, more likely the fan's bushings are worn out and/or the original lubricant has dried out. The fans usually have sealed bushings and once you take the freezer apart far enough to get to the fan to service it, it is much easier and cost effective to replace the fan. If you take the fan itself apart and re-lube the worn bushings your "fix" very likely won't last very long.
Oct 07, 2014 | GE PSS26MGPBB Side by Side Refrigerator
Hello, I have a Yamaha R-15 Version 2.0 2011
It sounds like the service you got forgot to lube the cable or the rod to the brake also there should be a service cap screw on the freont fork to lube it also and check your front axle bolt to be sure it is at the proper tourque. If either is to tight or loose it could be dangeraus. As far as the water is concerned the bike shouldn't have a problem there. Good luck and be carful.
Oct 11, 2013 | Motorcycles
Honda crf 100
You possibly have corrosion or contamination built up in the lever pivot point. Disconnect the cable and try lever - if it is stiff or difficult to move, you'll need to take the handle off, clean pivot and contact points with a SOFT wire brush ( brass brush recommended) lube it with white lithium grease and re-install. check for freedom of movement before re-installing cable. If it moves ok but cable is stiff, you'll want to next lube the cable with a liquid spray lube - sometimes the new cables are not properly lubed!!
Apr 27, 2013 | Motorcycles
Singer stylist E2 error code bobbin winding
I have just repaired a 7258 with a frozen bearing unrelated to the E2 code except that I thought I would lube the entire machine while it was apart, and through my ignorance, I greased the clutch that releases the mainshaft when winding the bobbin, and then when the clutch wasn't working correctly, caused the E2 error. I can say the E2 error is not caused by a plug not seated correctly, too much tension in the bobbin thread, or God having a bad day. The E2 error code is thrown when the bobbin holder is in the wind position, and the mainshaft rotates. There is a clutch just behind the hand knob on the right side of the machine, and if it has too much lubrication with a stiff grease, or on an older machine, if the lube has dried out, the clutch will not release properly. I took the clutch apart, cleaned the grease I put in it, and then lubed it with bicycle silicone oil. It now works as designed. The hardest part of the repair was figuring out how the plastic cases split apart! If anyone in the SF Bay Area has a 7256, or 7258 that gives the E2 code, I can fix it - it's actually kind 'a fun...
Feb 08, 2013 | Singer Sewing Machines
Starter moter wont stop running 1988 harley 1200sportster
your starter plunger is sticking you can take it apart and lube it or drill a small hole in the side case big enough to get a skinny screw driver trough lube through that hole and work the plunger back and forth make shure you dissconnect battery first
Feb 14, 2012 | Maisto Harley Davidson 1997 XLH Sportster...
Dust
HI
If this is not the DG type what you do is to remove the name ring you can pleel it of it will restick
under the name ring you willsee two holes to use a compus to undscrew this ring do not put
to much presher on the ring when unsewing it next you will be able to unscrew the front element
just clean and blow out the dust out then rescrew all .
Jan 10, 2009 | Sigma 17-35mm f/2.8-4.0 EX Aspherical for...
Sigma macro lense
If it doesn't turn correctly, that strongly indicates you didn't reassemble the lens properly. Take it apart and try again. And I hope you have a lens collimator and other tools to ensure you get the lens elements aligned properly.
Aug 22, 2008 | Sigma 28-80mm Mini Zoom Macro Lens
Sigma Zoom Telephoto 170-500mm f/5-6.3 APO Aspherical Autofocus Lens for Canon EOS Logo
81 people viewed this question
Top Sigma Cameras Experts
M_Butkus
Steve
Doberman
Are you a Sigma Camera Expert? Answer questions, earn points and help others
